79 Nautique rebuild? |
Post Reply | Page <1234 6> |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5780 |
Some boats had one, two or none. Must have been an option. I have 2 in my boat and although they narrow up the floor space I am able to store a pair of double skis, my barefoot boom, paddle, fire extinguisher, sun block,etc... in them and keep all that stuff off the floor. Some rip them out some keep them, adding them would be easy and I can post a few pictures of mine if you like. |
Waterdog
My brothers 84 2001 has them my 86 2001 dosen't. He keeps a lot of stuff off the floor with them.
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1423 |
Also if you have them leave in when you do a stringer job good for tools and odd bits, and great to keep the beer on as you work + hide the empty from the skirt
Lets have a go
79TiqueRebuild
Senior Member Joined: January-21-2009 Location: Kansas City, Mo Status: Offline Points: 238 |
Mine are going stay in. I can't wait to get beyond this grinding. It sure is hard to drink beer with this mask on.
the grinch
Senior Member Joined: November-25-2008 Location: Lexington, NC Status: Offline Points: 150 |
I think I'm going to wait till I get a little farther along with the floor before I decide whether to add some or not. I can see the benefit, however, I only have the skis in the boat when the kids are with me and I'm really never that far from the dock if I have a bunch of crap in the boat. What I really need to do is come up an ideal means of holding a cooler and a hydrofoil out of the way but easy to get to. The grinding does wear hard on you on one of these projects. My forearms resemble POPEYE's I've done so much of it, but I'm almost ready to put that baby back in the tool box!
It takes a big hole to bury an elephant.
Kirk Miller [URL=http://www.correctcraftfan.com/forum/register.asp?FID=7]KIRKS79/URL] |
79TiqueRebuild
Finally had some time to work on the boat tonight.Jeremy converted the cad file for the main stringer that roger sent. Thanks both of you. I purchased a test piece of 2x6 so I could figure out that scribe thing. I feel pretty good about how it came out. Hopefully I'll get to work on the real one this weekend.
I'm planning on a plywood floor was thinking about 1/2" for main floor and 3/4" for removable behind engine cover. any recommendations? |
WakeSlayer
I used 3/4 all the way around. not sure if I would want to go less. Maybe 5/8's.
Mike N
1968 Mustang |
uk1979
Good Work Monty glad it works,on the floor Mike is right 3/4 or at a pinch 5/8 as the ski pylon is bolted through the floor on your year SN and is the main support so a good multi ply (WBP grade) would be good coated all over with CPES & epoxy ( when you coat it up do all over at the same time on a thick plastic sheet, will help to keep it flat and not pull one side,they say epoxy has a low shrink rate/ to dry! ) as for the sides that was fiberglass which was over the ply/wood then over foam, lots of schools of thought and all good Mike's post shows the ply way well, the back middle section was 3/4 ply that you could remove with screws for ease to work on.
Lots to read up on here for floors Foam or no Foam, if no then there are Mike's pool noodles right up to empty soft drink bottles (caps on) to ping pong balls. At the end of the day its your boat and do it as you feel happy with which could be a combo of all the above or a new twist. Keep it up and keep the new wood work skills under your hat and on here, if the skirts find out you will soon have lots of new jobs which = less boat time. |
Lets have a go
uk1979
Thinking about it Monty I would add a extra piece of 3/4 ply under the floor around the pylon epoxy & screwed on.
Lets have a go
the grinch
My 79bfn is alot like the 79sn in and around the pylon. This was a huge failure point in the floor system on mine. I wish I had taken pictures of this part of the floor before tearing it apart. If like mine, the only attachment point for the pylon is the socket in the bilge (which has no pin), and of course the floor. With the exception of my daughter, everyone pulled behind my 81sn was 200#s plussss. With the simple laws of physics, the attachment down at the floor and its close proximity to that socket in the bilge, there is alot of force or leverage created at the attachment points. I would tie that floor around the pylon in with more than screws. If the floor attachment starts to fail, then that socket in the bilge is going to get wallowed out. I would use more than screws to hold that part of the floor in.
79TiqueRebuild
I got the real observer side main stringer fit to the hull.I started laying out the top side of it and I think I will go with the 3/4' floor and under the pylon sink in a 2x8 across the main stringers. One of those engine cradle would be nice.
While I was Measuring out the top I remembered that when pulling the motor there were 1/2 oak shims under the front motor mounts.Has anybody seen that or is that part of a p.o. stringer replacement? I was going to add a 1/2 inch to front mm height to do away with them. Kirk what do you mean use more than screws to hold floor around pylon? |
uk1979
Monty yes a good solid bit of 2x8 under the floor sealed and epoxy on with a good snug fit around the pylon along with the 4 bolts through the welded top plate down to the under plate to give a 3/4 ply and 2 inch depth should be fine, not sure what Kirk's mean's as I am thinking you are putting the front floor in as a big slab not unlike he shows in his post, you could put some off cuts of ply under the floor where you fix the seats too all epoxy on,then I would coat the tops of the stringers with wet epoxy and screw down or if its a removable job just more screws no wet epoxy.
As for the shims I too had them 11/4 at the front and 1/4 at the back I may be wrong my guess is the stringers were set as a one size fits all on the engine package you had, and its easy to just shim up, you have 351 and I have 350 and the early 70's boat may have had something different. |
Lets have a go
the grinch
I was referring to some layered plywood underneath the center floor slab. The layers would be placed to butt against the front bulkheads to create more dispersed load against the bulkheads when force or load is on the pylon and floor. I haven't quite made it that far in my rebuild, but I'll post pics when I get there. Should be towards the end of the week. I also built a cradle to help with this force as well. It may be overbuild but my original floor had failed here for whatever reason. Don't want it to happen again so adding a little xtra.
WakeSlayer
Dammit !! For the pylon mount, and I do realize this is a different boat: Mine was two pieces of 3/4" ply peanut buttered and screwed together. One went between the stingers and one went on top in a notch. Then my floor. so it is 2" plus total of surrounding cross support. |
Mike N
1968 Mustang |
79TiqueRebuild
Thanks I will go back and check that out again.
I always liked that episode of mythbusters. I just haven't checked in to quanity and prices. Do you think a ping pong paddle would pass water patrol requirements for a paddle?? |
uk1979
Monty as Kirk and Mike said the pylon fixing is a weak part on our year boats, and the engine cradle type is the way to go with all the extra things/ways now around to pull. I would think the later cradle may fit with a small amount of work and setting the stringers for one, may be worth a post on the parts wanted list or mail Paul
he has lots of parts he helped me out and sent over to the UK if not a cradle you may need some other CC parts. nautiquefanatic pcarpenter2@carolina.rr.com or call (980)581-0006 Mike you could go ping pong on your next boat |
Lets have a go
WakeSlayer
Just the thought of dumping 8000 ping pong balls in the boat makes me laugh. Hit a big roller and have like a dozen of them pop out of nowhere and bounce around.
Mike N
1968 Mustang |
79TiqueRebuild
Thanks. I sent a E-mail to Paul about a engine cradle. Does anybody know what years would work on my boat? I want to beef up the pylon area as much as possible as the boys want to Wakeboard with that stripper pole.
I got the files for the other stringers from Jeremy. Thanks so much!!! to you and Roger. Have to make a trip to lake this weekend to check on things and thought of my lift right now is setup for my runabout do you what changes will I have to make for the CC? |
the grinch
Monty it looks like all you may have to do is raise the bunks straight up. Measure width of bunks and then take that measurement on the boat. From that point, measure down to the lowest hanging point on the boat, (the rudder) and that's how high you need to raise the bunks. Of course the rudder may overhang the lift and may not be a factor, so it may be the prop shaft, or so forth. I guess it really depends on how far forward the boat will sit on the bunks. I don't have a pic, however, I built a stop on the lift at my previous house to keep from pulling boat in to far and the prop or rudder hitting.
79TiqueRebuild
Pardon me for being dumb. But do I need to buy new Taller brackets? or is there a way to make these work? I know I'm a long way from this issue but want to get this figured out while I'm there or at least know what to be looking for. Monty
the grinch
I don't know if you have a local shop that builds docks and has some type of brackets that would work. I rebuilt my own for my 81sn but it was a little different (overhead lift with chains down to a cradle) application. I had to cut the rear section of the cross member that is like yours and weld a dropped section in btwn the bunks. You can't do that with yours, so it would be easiest to just raise the bunks front and rear. You might be able to have some brackets made to raise the bunks that you could bolt onto the cradle. Really not to difficult to do with the right materials. Don't worry to much about the galvanized steel. You can use mild steel and then paint with galvanizing paint. It worked fine for the five years I had the house.
79TiqueRebuild
Thanks I'm not too far from lake of the Ozarks lots of lift dealers there. I measured boat so will see if I can come up with taller brackets.
WakeSlayer
I think you are stuck on the height of the brackets. I do think they need to be brought in quite a ways together. That may help part of that. Depending how they are attached under the bunks, perhaps you can put a spacer of some sort in there. I don't think you need to go much higher. Maybe 4" lift at most. Just my opinion, make sure.
Mike N
1968 Mustang |
uk1979
Monty, just looked back through your post and the cradle came in 1980 so a 80/81 would make a good starting point as its the same hull,they may be the same in 2001 boats, need a 2001 guy to size one up for you.
Nice lift by the way. |
Lets have a go
Monty, It took a while and then i seen the airline, pretty cool, do you have to bring an air compresser with you? or is there one on site?
79TiqueRebuild
There is a electric blower that is mounted in a fiberglass box, flip the lever in the box to release air and switch on blower to raise it. The fancy ones are remote controlled so you can raise it back up for rough water. Then lower when returning. We are on a Corp lake and have to use a generator for electricity. The valve on the tank is a safety I installed. After looking today I think I can raise my bunks with some 2" square metal stock. more fun.....
lake lifts |
79TiqueRebuild
I took the day off today, I was inspired by the lake and got some fitting and a partial mock-up of the observer side. Then I cut out old drivers side.I'm not as fast as the rest but I'll keep plugging along.
the grinch
Monty, that's looking good. I bet you are thinking, "If I could take a month off of work, I'd have it finished in no time!" Good luck.
BuffaloBFN
I like the 'extend-a-level'!
79TiqueRebuild
Here's what came out on exhaust back plate.
This is the biggest piece of template I had. Woo ho. Did some more fitting for mock-up. How come the phone only rings after you get in the boat? I wonder if anybody kept track of times entered and out I'd probably set a record.. Kirk, Our contract is up Apr 4 @ midnight I may have the time to work on boat But I've been kind of holding off placing order for fiberglass materials$$$$$ |
