  New Posts New Posts RSS Feed - Gel Coat Prep
Gel Coat Prep
 Post Reply Post Reply Page    <1 678910 13>
blink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blink Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2009 at 3:57pm
Did you ask them if we could wet sand in the rain There might be a 1994 nautique in the driveway this weekend that could use some attention , look at the bright side we won't need buckets
BTW looks like I lost my 82-2001 to sanity
sanity View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:04am
Sanity needs attention too
skinaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skinaut Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:09am
If you are going to wet sand her i want pictures blink!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:27am
Hey Lee, need some muscle here! Can't get the dang gel coat gallons opened! Lids must be gelled on. Co-worker stopped by and he couldn't open them either. Guess I'll bring the channnel locks home to loosen. Just wanted to see what it looked like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skinaut Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:35am
A fricking 12 gauge!
what else would you use?
quote from Napoleon Dynamite
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 10:25am
Blink, Forget about the boat this weekend, you better take michelle over to Cabella's
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 11:18am
I would gladly go to Cabella's! I could use a few "fishing" items.
Eric, I'm sure you'll be be at home working on your scrap book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 11:34am
Michelle,
I don't recall ever discussing reducers (solvents) unless it was way back when I mentioned always going with what the manufacturer of the gell recommends. I know I mentioned fluid tip size recommendations and it's relationship to viscosity. Did you get the solvent too? Did you get reduction specs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 11:55am
Good Morning Pete,
I purchased the reducer that the manufacturer recommended and supplied. You are correct.
A few manufacturers recommend not using a reducer with their gel coat. Blink bought a gel gun that came with #6 and I purchased additional tips #3, #4 & #5. I can't recall the mm sizes off hand, but again I purchased what was recommended. #4 was the recommended size, so I bought 1 size up and 1 down. The specs are 5% on the reducer, but depending on the weather, they said (as well as the specs) that you can add more or less. Longer dry to "tacky" time if you add more. The MEKP works the same way.
If the gel gun isn't working for me, we have the auto paint gun too.
Chelle'
Post Options Post Options   Thanks (0) Thanks(0)   Quote skinaut Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:01pm
Or you could take her down to the river, dunk her and then wet sand her. with photos please!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:03pm
Michelle,
I shouldn't have even asked!!! You have been so thorough with every step - I admire your ambitions!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:20pm
Thanks Pete. My biggest worry is getting the gel to match. The application will be pleasurable work. I can mix the tint in the gel beforehand and store till ready to apply. I'll try mixing a pint and see how it goes. It surprised me to find out that you "must" use 1 oz. of tint per gallon, yet you can add as much as you need of any or all colors to reach your desired shade. It's a poly paste and it won't alter the gelcoat as far as using the reducer or MEKP. That doesn't make sense if you "must" use one oz.
I picked up some measuring spoons at the dollar store for this.
Chelle'
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:24pm
Pete, Do you think the "must" use 1 oz. has something to do with opacity? I bought the neutral gel coat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 12:50pm
Yes, The 1oz. is a minimum otherwise you end up with a translucent gel.
I'd tint the whole 1 gal. batch so you don't have to worry about small quantity color matching.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 1:13pm
Sanity, gotta admire anyone with that muck "SPUNK".
I talk to Dr. Pete almost everyday, he helps me thru the "hills and valleys".
May have a new twist on the DR. thing, we could have a 1-800-275-7383= 1-800-ASK-PETE.
He could do it like one of those 1-900 numbers and charge 7.00 a minute.
There have to be ways to supplement our income in these trying economic times, this could be your "calling" Pete........Boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 2:07pm
LOL...as long as there is a toll free number for special friends and family.
The "spunk" is called "INSANITY" and too much coffee.
Chelle'
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 9:42pm
Originally posted by boat dr boat dr wrote:
1-800-ASK-PETE.
I tried to send him a few donna cd's...
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2009 at 9:54pm
Sanity, I also am enjoying your 'get-after-it-ness'! You are an inspiration even to those of us who are as Pete might point out(and might be?!!?) a touch over the line!
I'm still waiting on the official definition of over the line...    LOL
Seriously, I have gel-cote in my future so please take lots of pics and post your notes!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2009 at 12:32am
Thanks Greg. I will take alot of pictures. I have been documenting everything. Still waiting on the rain to go away.
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2009 at 12:50am
Want to trade for the 4-7" of snow predicted tomorrow? Good thing, it cant last too long!
Cant wait to see "The Mix"! take those pics!
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2009 at 11:02am
So, I have been patiently waiting and watching the weather daily for the rain to go away. I see a break on Saturday and Sunday. Keep your fingers crossed. If the sun shines all day as predicted on Saturday, Sunday should be good. My cut line is from the rubrail. I'll sand, buff and wax on weeknights, then we can flip back over and I'll gel the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2009 at 11:23am
we pray for rainy days, keeps the dust down even in the booth, Rainy days and Sundays always makes us frown (upside down) for painting
is that a song?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2009 at 11:57am
Michelle,
You may what to consider getting a dehumidifier
in your gel "tent". This time of the year (spring) it will maintain a consistent humidity. It's not a bad idea for summer ether. In summer, I use the "red neck" method for keeping my garage/shop cooler and drier - a box fan in the doorway from the air conditioned house!! It surprisingly does a great job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2009 at 12:03pm
Pete, that's a great idea. There is a dehumidifier in the basement that the previous owners left. I never even plugged it in. Additional security!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2009 at 1:10pm
First thing first..check picture size!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2009 at 1:16pm
OK, so it was scary when I saw what the neutral gel coat looked like.
I had the Color sample on hand to match my magic mix.
The yuckytan match (my match) in a bucket and ready to gel
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2009 at 1:17pm
WOOOOOWWWWWW! You ever think about getting rid of that ugly color...you know, maybe painting it red?!
NICE !!! how'd it spray?..fill us in on the details!
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2009 at 1:19pm
cans with my magic mix
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2009 at 1:22pm
Hmmmm....I don't think I ever looked better. OMG..
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanity Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2009 at 1:24pm
Hey Steve!
OK, I'll get to the details. Let me finish with the pics then I'll tell you all the fun stuff!
