1993 Nautique Excel Questions |
Post Reply | Page <12 |
Air206
Yes!! but the wax rope goes into the gland which connects the prop shaft to the hull thru-way. It is a bit of a bear to get to as it is under the V-drive (where the prop shaft disappears into the hull).
You use a combination of wrenches to loosen it up. There are some good threads on wax vs synthetic packing. There is also a good discussion on cutting the pieces on an angle- which I found intriguing........too late for my project though... You will be good to go!!!! |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21183 |
Sounds like the v-drives might be set up differently. They can be installed either way on the direct drives, depending on whether you have a LH or RH engine. Installing it backwards is actually fairly common. |
LKG_
Groupie Joined: June-18-2008 Location: United States Status: Offline Points: 90 |
^^ Now that I think about it I don't think that could be causing my "whine". Mine was doing it while idling in neutral. There has to be something else because the prop shaft shouldn't be turning then.
Oh yeah, water was coming in where the rudder goes through the hull at a rate of about 1 drop per second. It was actually dripping from a couple of inches above the hull around the bushings. Is there a seal there that I can replace? |
Air206
The shaft could still be spinning at idle - not fast, but will spin still. It is a very distinct musical whine....
The rudder has a packing nut and floss (packing gland) as well..... that wax rope can be used there too..... useful stuff, huh? |
LKG_
Too many projects, not enough time...
I started replacing the carpet this past weekend even though I really didn't want to. I originally planned to push the carpet replacement to next year, but I got a huge roll of really nice marine carpet, a bucket of glue, and a trowel for free so I had to go ahead and take advantage of it. I got the hull stripped on Saturday and finished stripping all the removable panels on Sunday. All the old carpet came out really easily in whole pieces so I used the old carpet as a template and just left an extra inch on each side when I cut the replacement pieces. How do you guys normally go about gluing in the replacement pieces for the hull and gunwales? There is a rubber strip that joins the gunwale carpet to the floor carpet. It has a channel that the floor carpet pushes into. I'm thinking I should glue in the gunwales first, trim them with a razor blade, glue in the rubber strip, glue in the floor carpet trim it, and then start stuffing it into the rubber trim piece. Does that sound right to you guys? btw...The loud whine turned out to be the shifter linkage on the transmission vibrating. I can grab it and muffle the sound. I need to take a video. You guys aren't going to believe how loud this thing is. I guess it is resonating at just the right frequency to be a lot louder than you'd ever expect. You guys will get a kick out of this; the boat didn't have a thermostat. Just two (or three) thermostat gaskets stacked up and an empty hole. All I can figure out is that it may have been the previous owner's solution to the blockage from the water pump impeller that came apart? I mean, it was probably only getting 20% of the water flow from the water pump, but then the thermostat was a gaping hole that was always open so I guess it worked out for him. So strange that it ran perfectly fine last year and then I start finding these things when I start taking it apart. The boat was in the right temp operating range last year when I bought it, but it was running at ~100 degrees after I fixed the blockage. I thought I had a bad temp gauge until I saw that there was no thermostat! |
BuffaloBFN
There's a good write up on that trim that TRBenj posted. Try a search for carpet, I think it's in the 'common questions' section.
WakeSlayer
i had the exact same thing in the Mustang. I was out in water that was 35* or so the day the ice went off, and the gauge would not register. NO stat. Then, I inadvertantly installed the thing backwards.... All better now.... |
Mike N
1968 Mustang |
LKG_
Got the carpet done and it looks great. I need to get some pics up.
Now I'm concerned about the alternator. I've only run the boat a few times this year and I had to throw in my second battery last weekend to get it to crank. Normally I wouldn't think anything of it, but I noticed that the volt gauge was reading less than 12 volts while the boat was running. Is the best way to find out for sure just to pull the alternator and take it to Autozone/Advance Auto for testing? If I do need a new alternator, is this the right one: http://www.skidim.com/prodinfo.asp?number=RA097006 How would I know if my boat has the external regulator that they're referring to in that link? ps, I still haven't given her a good wash/wax job, but here is a pic I took of her last week while we were swimming: Olympus waterproof cameras are ftw! |
kapla
Before taking out the alternator, if you have a tester you can test it in place and compare the reading to the gauge..maybe you have bad ground on the gauge and get low reading...just my .02
LKG_
What's the best place to test it? I have a multimeter. I'm guessing I can check voltage at the battery, crank the boat, and check voltage again. If the alternator is working it should go from ~12.0v to ~13.8v, right?
LKG_
The alternator was bad. Just got it back from a rebuild by a local shop. I think he said the rotor was bad. He rebuilt it with new brushes, bearings, etc; sandblasted it, and painted it for $125. Seemed like a good deal.
Lake Gaston/Raleigh North Carolina |
critter
I would use 5200. Better for marine use. You can find it at ACE Hardware stores or any Marine store. |
1980 Ski Nautique
1966 Barracuda |
I HATE SILICONE!!!! (I need to add the statement to my signature line!!) It didn't stick and work once or even twice when it was the "shade tree" mechanic glopped on more so don't expect it to work a third time. Stick with the 5200 as mentioned. Do check the condition of the wood glassed into the transom. There's a reason the brackets loosened up and the wood may be the problem. |
LKG_
Is there wood in the transom of a 1993? I'm pretty sure this boat is all glass.
A solid glass transom wouldn't have allowed the washers to cup like you mentioned. I'll bet there is ply in that transom! |
TX Foilhead
My 93 has what looks to be some wood backing plates on the transom. There is also carpeted wood panels under the dash and the speakers are mounted to plywood covered with upholstery. That's all I've found, and I looked everywhere.
If you have a little rotten wood on the transom it should be very easy to fix, and I would think that you could even replace it with a suitable non wood plate. |
LKG_
With a fiberglass floor and stringers I'm pretty sure there is no wood in the transom. iirc the washers weren't cupped. I don't remember what was wrong...maybe flat washer bolted to angled surface or maybe the previous repair had damaged them, but I don't have the boat here to look at it. In any case, when I looked at it I thought it looked like something that should be replaced when I took them off.
I'll definitely pick up some 5200 and use that. Thanks for the suggestion. |
LKG_
Anyone know off the top of your head what size bolt holds the air cleaner on top of the carb? Dropped mine last week and it disappeared under the engine. I'm going to take a telescoping magnet to try to fish it out, but it wouldn't be a bad idea for me to pick up a spare before I get all the way to the lake. If nothing else it'll appear near the drain plug after I run the boat for a weekend.
I believe the thread is 1/4-20. The length will depend on the height of your flame arrestor. |
LKG_
Bringing back the old thread for a quick question...
Anyone know the specs on the allen bolt that holds the exhaust manifold on? Need to know the length, size, and thread pitch if anyone knows. Does it take any particular grade bolt? I was changing the plugs this past weekend and noticed that I'm missing one. Never noticed a exhaust leak, but I do want to get one in there. It's the black bolts at the bottom right of this pic: The boat has been great. Still running really good. Waterdog was helping me put a new power valve in the carb a couple of weeks ago and noticed that it only had three bolts holding it down; none of which had washers. Apparently someone did some monkeying around with this boat before I owned it, but it seems to be holding up pretty well. ::knock on wood:: |
what too lazy to take a bolt out and use that as a reference? BTW you don't have to have washers on the carb studs. |
Bri892001
I was looking at pics of Nautique Excels and stumbled across this old post. I would recommend this as a replacement for that bolt: Aircleaner Thumbscrew. I'm planning to get one next time I order anything else to I'm not paying shipping just for that. They mention here Holley Aircleaner Stuff that you may have to cut a little off the threads unless you're using the plastic air cleaner cover thing like the one they show on this page. |
yuanyelss
Newbie Joined: January-07-2011 Status: Offline Points: 3 |
I use it in my 93 Excel. All the other fluids should be correct, don't know about the impeller, I get mine from Discount Inboard Marine, but it is a Sherwood pump.
