battery recomendations |
phospher
Gold Member Joined: July-19-2007 Location: United States Status: Offline Points: 557 |
Posted: April-10-2009 at 3:01pm |
i know this has come up several times here but i'm not having much luck with this sites search function.
351W no sterio, battery only used for starting and filling fat sacks. what battery should i get? i'm not looking to spend the money to get an optima. right now, i have an AC Delco voyager deep cycle. thanks, |
well you need a non-deep cycle battery version of the voyager or the optima, Dekka suppose to be decent, heard others like interstate batteries too.
I'm parcial to Delco's mainly because I used to work for them but the battery business is now owned by Johnson controls and GM is out of the battery business, except for lithium ion and nickle metal hydried (sp) battery's |
TX Foilhead
I've had a Red Top Optima in my boat for 4 years with no problems, and I have never put a charger on it (use it at least every other week in the winter). You might want to reconsider the no Optima thing.
Randy_in_Ohio
ditto on the Optima...
bkhallpass
I don't know if it is a good battery or not, but the battery that came stock in my boat was a Nautilus and it lasted 8 years. BKH
Livin' the Dream
phospher
ok, i'm sold on the optima. the redtop 34R 800CCA?? should i get that one?
BLUE TOP NOT AUTOMOTIVE RED TOP
phospher
ahh, but aren't the blue top deep cycle?
phospher
should i get the optima blue top 34M? looks like that's a starter battery.
Phil,
You won't go wrong with ether the red top, yellow top or the marine blue top. All the optimas due to their design can handle lots of pounding and vibration. The red top is recommended for off road so it sure will handle the abuse of marine service. I'm running a red top in my Tique without any problems. The yellow is a cross between starting and deep cycle so if you are filling sacs, it's not a bad choice. Yes, the blue tops are a deep cycle and should be used for such but are also listed as a dual purpose. The blue top does have the stud terminals as well as the lugs. Confusing isn't it!! |
phospher
yeah, it is a bit confusing. i'm going to go buy one today and i don't know which one i should get. so which are the cheapest? lol
Phil,
If you don't need the dual connections (stud and lug) that's on the marine blue top and you are using it primarily for starting (you'll probably have the engine running when filling sacs) then I'd go with the red top. |
TX Foilhead
There are 2 versions of the blue top, one is dual (like the yellow) and the other is deep cycle. My Optima that has lasted so long is a red top, no stereo in that boat so no need for a deep cycle.
phospher
well, in the end i cheaped out and got a everstart maxx marine from walmart. 875 CA's. I figured since i'm planning on a new boat next year it wasn't worth to spend the extra cash.
so i picked up my boat from storage and threw the new battery in it. she fired up pretty quick after her long beauty rest. but she was ticking for a while until the oil got up there then she quieted down. the valves were probably ticking for 20 seconds or so... i took a few hot laps around my lake and took my 7 month old on his first boat ride. boat ran perfect as i expected. for some reason i always hold my breath when i go to fire her up for the first time of the season. but after she starts, i'm reassured again that a correct winterization pays off. |
lonestar
Senior Member Joined: August-17-2008 Location: Lafayette N.J. Status: Offline Points: 290 |
OK here is a newbie question. Why no deep cycle ?
lonestar
Deep cycle batteries do not have high amp delivery capability, so they do not work well for starting a V8 engine. They are good fro trolling motors & stereos, however.
pwningjr
Groupie Joined: December-07-2007 Location: IA Status: Offline Points: 36 |
To clarify (I can do that; he's my dad ): Deep cycle batteries are designed for low amp draws over extended amounts of time, starting batteries are designed for high amp draw in a very short time. Using a deep cycle battery as a starting battery will [significantly] shorten its life span. |
Jay
"Proud to be a geek" Big Heavy (stephan): One can't always be perfect when water dancing on your shred stick. |
He's getting close to overtaking me!
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 759 |
i do find it helpful to have the blue top d34m with the extra ring terminal spots for stereo hookup and whatever else i want, its funnny how the red top is 3 yr free replacement and the blue is 18 months...i always get them free replacement in my diesel 7.3 since it just kills batteries like a duck running into steel shot.
Are you putting the blue or red top in the truck? |
you need a catapiler battery in that thing and you'll be fine. |
