  New Posts New Posts RSS Feed - righty schematic
righty schematic
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: righty schematic
    Posted: April-30-2009 at 5:26pm
can anyone come up with a schematic on where number 1 sits and firing order?
351
critter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 5:39pm
The PMC Manual has this picture on Page 11.
It shows Front of Motor with Cylinder Number and Firing Order for Fords
1980 Ski Nautique
1966 Barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 5:39pm
The cylinders are always in the same spot, Eric! Front left cylinder as youre looking at the front of the motor (the most forward cylinder on the starboard side of a direct drive boat). RH firing order is 18456273.
Edit: Roger- fix your diagram so RH is correctly labeled. Not sure if the firing order you referenced is from the manual, but it looks like the 289/early 302 firing order to me. Later 302's (like my '71) and all 351w's used the 13726548 order, which would be 18456273 if its a RH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 5:42pm
snip picture...
This does not do it for you ??
It shows Front of Motor with Cylinder Number and Firing Order.
Ahhh you were looking for a Righty..
Sorry.
1980 Ski Nautique
1966 Barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 5:51pm
Roger, that diagram is screwy.
The diagram on the left (15426378) is a LH Ford and the one on the right (18736245) is a RH... so the label on the right is incorrect.
Both firing orders are for the 289 and early 302's (and presumably the 260 and 221 that preceded them), but the later 302's and 351's used a different firing order. The correct one is 13726548(LH)/18456273(RH).
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 6:02pm
Thanks for the clarification Tim
EDIT: As I hate to see incorrect informtion or diagrams online, I have corrected the diagram in my post to make corrections referenced by Tim.
Tim, would you verify that it is now correct. Thanks
1980 Ski Nautique
1966 Barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 6:37pm
Roger, looks right to me! Hope my memory is good...
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 6:48pm
you guys threw a fcn curve ball and i dont confuse easily, so we get this right, it is a counter rotating ford from the front 351, I did not drop in the distributor yet.
what is the correct FO and dist rotation? from this post out i will understand
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 7:01pm
RH 351w FO is 18456273.
All Ford dizzys spin counterclockwise as viewed from the top (the gear is cut opposite on the RH's to allow this). Just figure out which post is cyl #1 and follow the firing order around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2009 at 10:14am
got it
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2009 at 1:13pm
WTF? im loooking at the cam card and in pen from thier hand writing it has a note, and it reads.......fire order 13726548...
im going to blow a cork, as I read I keep seeing LH.....to the phone
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2009 at 1:16pm
That happened to me one time when I ordered a long block. I had everything done and went to drop the dizzy in...
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2009 at 1:42pm
what year boat is it later models use a LH with a 1.23:1 tranny, ealry models with the 1:1 are RH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2009 at 4:30pm
Oh it was a righty, i reconfirmed the firing order and the card was wrong, plus I compared the dist drive gear on the new cam and it is the same as the old. thanks for the replies
