V-drive 2001 SN |
Luchog
Posted: July-09-2009 at 1:31am |
http://www.the2001.com/index.php?name=PNphpBB2&file=viewtopic&t=1184&postdays=0&postorder=asc&start=75
it's beautiful!!!! I wonder on gear reduction, he might need a 4 blade now! |
TX Foilhead
Wow, I just found it on Wake World. I thought more people here would appreciate the work that went into it as well as the fact that he tried to make it look as classy as the original, and he even kept the ring. I expect we'll see some more of these conversions next spring.
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3400 |
That looks awesome!!
A real beauty! Great work. |
phatsat67
Thats bad ass I love the wood deck on the back. And he didnt put a tower on it :)
Luchog
look at this guys exhaust assembly...
I wonder if the manifolds could have been interchanged or the risers put backwards at least to save for that 180º curve. |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
You'd still need the same bends no matter which way the risers face. If you turned them around, there would be no room for mufflers.
kapla
changing belts and impeller i guess it harder on that configuration.. hull looks it was stretchened a little bit right?
I looks good though.. I always wonder how hard is to do that conversion.. how about a 1992 sn vdrive? I´m at point that could turn to it.... I need a v-drive and engineer the back deck...But the euro tail would sacrifice some space though... |
BuffaloBFN
Do yall know if he put the swimdeck back on?
storm34
Grand Poobah Joined: November-03-2008 Location: Dexter Iowa Status: Offline Points: 4493 |
No room for mufflers= no problems!
The swim platform is there, take a closer look. Must be in the original place but sunk due to the added weight in the back. |
skimzone
Groupie Joined: July-12-2009 Location: Pensacola Fl Status: Offline Points: 47 |
Dammit Man!!! I am going to re-think my whole boat build now!! That is Freakin sweet!!! Its like an old barrel back or utility and modern ski hit each other and- here's what happened. I've got a couple junk v-drives layn around- HMMMMMMMMMM, wonder what it would cost. I wish there were some pics of the foward engine compartment work- I would like to see the joint behind the seat. Dam nice lookin.
'78 ski nautique
'01 sport air nautique |
kapla
skimzone
I had the same thoughts when I saw this!!! |
Luchog
skimzone you better do this on a 2001 hull, since the older SN hull were quite narrower and I dont think it could end up well.
Luciano; The early Separators when they first came out had the manifolds reversed. The exhaust was straight out through the transom. Then, evidently CC thought they were too loud so the manifolds were reversed, the elbows added and the exhaust went out through the transom just at the water level like a DD. The Separators/Torinos were among the early V drives just as boat builders like Donzi were. I'd have to say that even with the bends, it's less restrictive than a I/O with through prop underwater exhaust. |
sam57
Senior Member Joined: December-07-2007 Location: North Canton, O Status: Offline Points: 360 |
I had a 82 CC Riviera V-Drive with a Chevrolet PCM. The risers were on backwards and went thru 2 90deg elbows with a 8in metal tube between, then into a heavy metal muffler about 14in long X 6in dia then thru the transom. And yes, it was a S.O.B. to work on the water pump, alternator, or belts. I had to remove the rear seat and battery and lay beside the engine so I could see what I was doing.
Luchog
at least he installed a dripless seal so he wont fight the packing gland!
TX Foilhead
Looks like he has created some maintenance issues trying to get the motor as far back as possible. My Excel has a giant Invertaflow between the engine and the transom, so it is almost as easy to get around everything on the front of the motor as a DD. Bad thing is it costs me some interior space.
The plumbing doesn't look good either, raw water strainer on one side, and the transmission cooler on the other. I'd like to see the other side to see how that works. |
SN2001fan
Newbie Joined: June-12-2008 Status: Offline Points: 26 |
that is so cool!!
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
Ok Yeah... That's Awesome!
I'm not a big fan of V-Drives in general & i can't say I'd do that, but I love that the guy did it & did it well. It looks clean & classic. I love the engine hatch. Very Nicely done! Nate |
skimzone
I wonder how the 90's slow down exhaust performance- if any. I guess its a short run- but for sure it takes thought to work the bugs out when planning this type of build.
'78 ski nautique
Chopper
Could a composite constrution SN be converted to V drive.?
Luchog
I guess it could be done, the issue with the 93' and newer would be deck cleareance I think. |
Luchog
I'll bring this back to life as there's other 2001 being converted to Vdrive.
quinner
84 Resto (Dan)
Your boat turned out awesome! Curious what Lake you are on. |
Chopper
Do tell.! Details.? |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
Andrew, Discussed here in the "maintenance" forum. |
84resto
Newbie Joined: September-30-2009 Status: Offline Points: 13 |
Luchog, sorry i havent replied to your questions. I copied them form the other thread and will answer here.
Do you have any pics of your boat running? did it end up too bow high? What prop did you finally put on? and what kind of performance are you getting out of it? Does it porpoise at high speeds? if so where at? Did you consider a different route for the exhaust pipes avoiding the U bend? I do have pictures of the boat running including wake pictures, and a ton of pictures of us surfing. I will do my best to post this week. My prop is an Acme 650 4 blade. I get some porpoising over 35mph. Im going to put an adjustable wake plate on over the winter to help shape my surfwake and should eliminate porpoising at higher speeds. I dont see how i could route the exhaust any other way. If the risers were flipped around there would be no room for the exhaust. I didnt notice any negative effects from adding the extra 90 degree elbow and making a U. |
form&function
Senior Member Joined: August-21-2009 Location: OK Status: Offline Points: 342 |
Resto,Does the boat porpose when your ballast are full?
Second I am trying to design a layout under my floor and the ballast weight front to back is a bit of a mystery.I guess your really the only person in the world that would know?At this point I am assuming 50/50 unless you tell me otherwise. Thanks |
84resto
The boat porpoises with ballast completely empty at around 35-36 with a slight very gentle bounce then get worse from there as you go faster.
I wouldnt put any infloor ballast. the amount of space in your floor is minimal, the amountof work and $$ involved wouldnt pay off for what you get. Plus if somethign goes wrong and you get a clog or something youd have to tear the floor up. If you are desperate for more weight if make some openable hatches and throw lead under the floor. -jmho s far as porpoising when ballast is full. When i have ballast int eh boat i never go close to full speed. Max is 22-24 for wake boarding. Now, you can easilly fit more ballast in teh back of the boat even with the engine taking up room back ther ethen you can fit int eh nose. So with ballast full it would make the porpoising problem worse. When i wakeboard i seriously didnt need to put much weight in the boat. the wake is already jacked up from stock with the difference in weighting position due to engine move. Max i would add ~ 400 pounds to the rear bags and then try and balance that with filling the nose. What is your plan as far as ballast setup, seating, fuel tank? what do you use the boat for? Wakeboarding or surfing or a combo? Which one do you do more of? |
Luchog
I'd try putting on the fuel tank as forward as possible, for every inch you move it forward you get less bouncing. It would also help soften the wake a little.
Then I'd have a hard tank or bag under the bow for those times when you are loading it on the back or you really want to mellow the wake. You could also add 2 hard tanks on the engine hatch under the gunnels. |
form&function
Wakeboarding is the main focal point of our boat and space is our main issue.We ride heavy and as a family so ballast and storage layout are very important.From my ruff calculations I can fit 25 gallons of fuel and 50 gallons water under the center up into the bow without compromising flooring.If I raise the floor a few inches under the bow it should allow enough ballast to compensate the rear lockers and still have room for life jackets and what not.
For seating we will probably stick with the wrap around and gain a little storage under the seats. About the porposing I wouldn't worry about it to much,I have owned half a dozen wakeboats and they all porpose to some degree.Thats why almost all new ones come with wakeplates. |
