Help, Please! |
dan.houston
Newbie Joined: April-21-2004 Location: United States Status: Offline Points: 2 |
Posted: April-21-2004 at 11:59am |
I have recently acquired a Correct Craft Mustang. I think it is a 1964 model. Two questions....1) Where do I find the hull identification number. 2) What is the approximate value range of a boat such as this? Thanks for any information.
Dan Houston, Charlotte, NC
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
Dan I would look at the reference section and see which boat from which year it resembles The ID Plate should be on the stringer next to the Transmission. Also the engine make and model and pictures would help us ID it. As to value they vary from free to around 10K depending on the ocndition Most in good condition would be around 4K here in California
dan.houston
Thanks for the info Rick.
reidp
Dan,
Any luck on finding that Hull I.D.? Many of them strangely disappeared over the years. There are other ways to narrow it down such as engine type/size, etc., in case the ID wasn't still there. If it was there, call Correct Craft in Orlando and they'll tell you exactly when the boat was built to the day. I'm just up in Mooresville, and would love to check out your boat sometime. |
66polyhead
Senior Member Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
I found my hull I.D. tag when I replaced my exhaust hose, it was against the transom underneath the exhaust thru pipe. I also found a nice diamond ring, and a gold tie tack.
