  New Posts New Posts RSS Feed - returning point ..back on track!!!
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2009 at 3:34pm
Awesome! What's your plan for bbreaking it in? Have you thought about puuting a oil filter magnet on it? I put one on my new boat before the break in and was really suprised on how well they work on new motors.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2009 at 3:36pm
Damn Kap, so much work and stuck on a starter...that's like buying a car with no wheels!
It'll shake loose.
1988 BFN-sold
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2009 at 4:02pm
What are guys doing there LOL..ah yes its winter up there lol..
I will replace oil filter next time I go..all metal shaving should be trapped by now in the filter.....
I will also check on a hard drive magnet..adn stick it to the filter..los..
I still need to remove the exh manifold on the starboard side to adjust the valve cover that its leaking some oil...
I have to do some carb adj as I the neutral to forward is not smooth is you don't give some throtle it stumbles..you will se it in the video...then I think I will have to re-check alligment as I'm having this thuuuuuu sound (like its in all the hull) in the 1800-2200 rpm range... no vibration at all just this anoying sound...
also I'm concern about this new shaft seal I put with o-rings its running hot....I will ask to the manufacturer if its normal (I guess its not)...
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2009 at 10:28pm
Kapla so cool to hear you and the Nautique this morning on the phone!!!
I was barely awake then... that sound you mention I think it's the new shaft seal and packing being too tight!!!
congratulations!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2009 at 8:33am
I guess it will wear a bit and loosen up..as its not adjustable.,it works with 3 o-rings and its lubricated with grease...anyway on monday I will call the manufacturer and ask about the Tempurature if its normal they run hot...if it was not the case it would have toasted and melted the o-rings right away and start driping..thing that in my case didn't happen..not a single drop its comming from the the seal...I can say I have dry bilge..for the first time since I own the boat...
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2009 at 2:14pm
Kap...very cool! I know you'll work out the details on the small stuff. I bet it is exciting for the boat to operate like a boat again. I'm looking forward to that, myself, in 4-5 months.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2009 at 6:24pm
some pics of saturday maiden voyage..I can feel the ride is much stiffer and quiter than ever no noises at all when going thruog wkaes chops etc... stern sits 4" above the surface with the stern seat in place..I will set it as I used to do it to compare..as for the engine I will be abel to tell the diference when I get to use it with ballast or WOT..fro now its runs very good....
I met my friend Hernan who was also In the maiden voyage of this baby..he bought it used with 300 hours last month, but was delivered last week
edelbrock powered
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2009 at 12:06am
just wanted to say you guys TIM, ALAN, Eric, Pete, Greg, Lucho and all the ccf member for helping me out with my project!!!
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2009 at 3:01pm
Seb,
That look on your face in the mirror... priceless!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2009 at 3:48pm
yes I know!!
well I got some input on the shaft seal issue..I spoke with the manufacturer.. It seems its to tight thus making the shaft to rub in the seal..thats why I get the reaised temp and the noise..I will have to take the seal out so he can put it in the Lathe to make it a little bigger....
BTw is the size of the nut that holds the shaft 1" 1/16? As it seems I will need to buy the tube as I don´t have one that big...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2009 at 1:28am
well went yesterday got the seal out..using the bolt hub extractor system I got the shaft out..
first time I did the job myself..after some attemops with the right length of tube I got it out
took it to the machine shop..and reassembled it.
today I went to do a test drive..it seems its running a little cooler but I still got that noise in the 1800 2200 rpm range..so I might lean I have some shaft to strut misaligment....
boat going to sleeep
another friend boat here....
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 1:23pm
Stranded again with the starter..It worked fine for the last 3 outings but yesterday we force it a little bit as we were working on the carb...and crank it more than other time..It seems it got hot enough to cause new short...
About the carb it squirting uneven fuel while idling...and thus it shut off....under load or at cruise it runs fine...So we adjusted the primary float level but finally could not test it as it would not start again...So off the starter went again to the shop....
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 1:35pm
are boats like woman?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 2:06pm
yes some times they are...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 2:43pm
Sorry to hear you're still having trouble. Keep at it...if she's like a woman, you just need to push the right buttons to get her purring like a kitten ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 4:43pm
Sorry to hear about these problems Sebastian...
Yes boats are like women. Chantal sometimes calls ours a real b*tch LOL...
But in the end it will all work out, after a few more beers and lots of cursing
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 5:00pm
Beware its not the evenness that is the main issue, you should not be seeing fuel from any venturi at all, at idle.
River Rat to Mole
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2009 at 5:08pm
Seb I'm not surprised the starter let go again, with the views you showed us in your other post, how can man concentrate!
Sorry to here your news, time to enjoy the views.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 12:07pm
Actually you got me right I meant it was spilling raw fuel at idle on the primaries....Now we adjusted the float..but will be able to test it once I get the starter again...for the 3rd time to the rebuilt shop..now they send it to have all the copper core wiring re-done....
If this doesn´t work I will end up putting a new..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 12:40pm
Hahaha, hey kapla, this is when I sell or trade.......
skicat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 1:41pm
You mean when you "GET TRADED"
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 2:51pm
LOL
one thig I noticed with the engine, its now running cooler than it did previous to the rebuilt...it did run before in the 160-170 range..now its running in 150...no matter the rpm so far....Im running the same t-stat and impeller so no change there. Is it possible that now water is flowing better due to the clean up of the block and cylinder heads? I remember the water passages had some junk build up when I teared the engine out?
Or more hp thus the engine is running with less effort?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 3:10pm
The clean up of the block and heads may be part of it- I doubt the added hp has any effect. More likely, your hoses are all sealed better now, having removed and reinstalled them all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 3:16pm
I guess so then...and say 150 is a good Tº or is it a little bit Low?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 3:25pm
I run around 150-155, so Id say youre good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2009 at 3:31pm
LOL
You probably have a better ground than before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2009 at 5:35pm
no luck with the starter..I might buy a new unit and forget..Its strange...I now doubt about being the alternator not charging enough as the first days with the new battery it started right up and now after some days no turn....but I could not test it as I didn´t take the tester to read..lol...
Tomorrow I´ll know best as the guy that did the starter rebuilt will go to the boat and test the starter there insitu!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-22-2009 at 10:12pm
well was a rainy weekend so I was able to go today in the morning to do some testings..So first attemp..the tic sound as when thers no tenough juice in the battery and the starter doesn´t kick in. we out another battery and the same....but the rear relay di some ticking sound...I gues I´m having a faulty switch there...We put the battery directly to the starter and it turned just fine..then with the engine running I was able to get some readings..the alternator is not charging readings are in about 12v with the engine runnning.
So we went to the carb tunning then...its still dripping lots of gas while at idle..adjusted the 2 floats and they are ok.. It seems that we are having a problem with the power valve? the original one that was replaces had the 4.5 stamped an the one that came in the kit is 6.5...that may be the cause of the rich running carb I guess...
So finally we removed both the carb and the alternator to have them check in the shop...
will report back...At least starter is working...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-23-2009 at 1:11pm
Nope, the change in power valve wont cause the dripping out of the mains at idle. I bet youve got some debris in the needle/seat.
While you have it apart, Id consider swapping out the PV though. With the newer higher flowing parts, the engine will pull a little less vacuum- so you want a PV that opens easier than before (larger than 6.5), not harder. Im running a 7.5 PV and have great throttle response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2009 at 3:19pm
odd..went today after putting back the old 45 power valve which was in good condition....put the carb in the engine..jumped wires to the battery with a fresh fully charged battery..pumped fuel to fill the carb..one turn of the key..and she fired right up and kept idling with no adjustemnt done....a little high on the rpm as it was set before ..lower the screw adjusted mixture and thats it..now it idles fine..around 800-900 rpm...
so out we went to a little test drive....she is nearly hitting the 10 hours of use...I give it a little more than other times and now I feel the difference in the take off..she is really pulling....
then went back to the marina..turned off and tried to turn it with engine hot..it started perfect..no hesitation at all.
Alternator is in the shop to be rebuild, starter now works like a champ...maybe a new starter relay is needed or a new wire from it to the starter..at least I narrowed the problem to that two things....
