  New Posts New Posts RSS Feed - Lifting rings
Lifting rings
Tom_Madison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom_Madison Quote  Post ReplyReply Direct Link To This Post Topic: Lifting rings
    Posted: November-25-2009 at 1:59am
I am done sanding the hull and deck, ready to have the gel coat applied. I'm sure the shop doing the gel coat is going to want to use the lifting rings. The front steel that the ring bolts to is rusty and the fiberglass that is along that rust has totally delaminated. I was able to detach and clean up the long bolt. I'm guessing that the bolt is tied into the bow eye and some structure below, but the delamination has me spooked. The rear ring is also bolted to a totally rusted metal brace, which is also a bit bent up. I trust the place doing the gel coat to make the correct call on this, but anyone else deal with this rusted/delaminated support stuff?
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2009 at 8:09am
Try this post.
Lifting Rings
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Marauder71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marauder71 Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2009 at 2:21pm
I have a quick question for you all while we are talking about the lifting rings. Do you think it would be ok to tow a skier/wakeboarder with the stern lifting ring? I know it is built for lateral load characteristics but could it withstand horizontal stresses as well. My problem is I do not have a pylon and anything forward of the motor will be difficult due to the hardtop.
connorssons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2009 at 2:29pm
I have a 71 mustang and been using the rear ring for all its life with no proublems. good luck! buy the way i love your boat. jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marauder71 Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2009 at 2:41pm
Thanks for the imput Jeff.
I should have said vertical instead of lateral...wasn't thinking.
I found a thread on this site about pulling with the lifting ring and there are mixed reviews. I know this is not what it was designed to do but I don't know that I have much choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2009 at 8:41pm
David - I had the gel coat crack next to my front lifting ring because I used it for the extended pylon cable attachment. So while I don't think using your rear ring for towing would be unsafe, you might end up with an appearance issue.
