68 Wildcat 440 Project |
Post Reply | Page <12 |
wild blue
Newbie Joined: October-01-2009 Location: va. Status: Offline Points: 33 |
Gary S,
Washed it with Soft Scrub to get rid of the fungus growth and it totally removed the rust stain on the starboard bow caused by an old tire rim left sitting. The hull ( I think) is in good shape except for some chips and gouges. Top side has allot of spider cracks, but not as bad as some I've seen on this site. The plan is to focus on the 440. Been sandblasting removed engine parts and painting them several a day. Did not get the engine lifted out past weekend, hope to soon. Mike S. @ SML |
mike stoher sr.
Waldo
Senior Member Joined: July-09-2009 Location: Iowa Status: Offline Points: 262 |
Mike. Neat boat. I love the boats with the squared off windshiled.
Waldo |
wild blue
Thanks Waldo,
The pics I have posted are where I found her sitting. I knew it was a classic and loved her looks, but when I found this CCF it made me want to invest the time and $$$$$. I wonder if CC factory appreciate this following? I see you are an IOWAN, me too,however I was transplanted to a warmer climate at an early age. Yea! OTTUMWA Mike S. @ SML VA. |
mike stoher sr.
wild blue
Coupler question
When I removed coupler from the 1 inch prop shaft it came off very easy. After reading about how tight they are, it seemed strange. I cleaned the flange by sand blasting (careful to stay clear of the bore) and found what looks like a tap broke off flush. I thought it should have a third set bolt. Right? The tap does not protrude into the bore and does not stick up enough to loosen by tapping with a punch. After closer look I found some mushrooming on the back of the flange the appears to have been caused by a hammer. Is it trashed or should I keep trying to save? Someone must have gotten there first. Please, what do ya think about that? Mike @ SML |
mike stoher sr.
Mike,
Time for a new coupling half! The coupling to shaft should be a interference fit (.0005 to .0015 under) and typically bored to fit the shaft due to variations of the shaft OD. If your's came off so easily, there is a good chance that the boat was run with the engine/shaft misaligned. This will cause the coupling to move slightly with each shaft rotation and fret. The fretting will wear the bore larger over time. Considering the hammer marks on the coupling, it sounds like a PO has a hacker!! He probably didn't even know what shaft/engine alignment is!! Since you have the shaft out, check it for straightness. It shouldn't run out in the middle more than .002 or .003 at the most. Don't forget to check the prop taper aft of the strut/cutlass. A bend there is common if the prop took at hit. If you find any bends, you may want to consider getting a ARE shaft/coupling set up. The same price but whats nice is the coupling end is a taper fit. No worries about getting it on and off plus they run very true. |
wild blue
Thanks Pete
I'll have the runout checked first of the week. Where is a good source for driveline parts? Skidim? Thanks again, Mike @ SML |
mike stoher sr.
Mike,
I just saw in another thread where Eric referenced a source/manufacturer for the ARE double taper shaft/coupling. It's got to be in one of the "shaft" or "strut" threads. I'll see if I can find it. Skidim is certainly a source for many parts but may not be the best buy. They also are no longer a supporter of this site so I suggest avoiding them. Correct Parts is so give Karen or Billy a call. They would be a good choice if your shaft is good and want to go back to the single taper too. You would need the coupling half. Then, the new coupling is bored to match the OD of your old shaft. After the coupling is fit/pressed on the shaft, it's always a good practice to chuck up the shaft in the lathe and do a light cut on the coupling face so it runs true to the shaft. BTW, the easy way to install a shaft with the pressed on coupling is with the engine out. |
Elbert's, he is the manufaturer..his name is Cecil. its in Oregon....Google
wild blue
Thanks Pete and Eric,
Got a starter problem, please advise. I bench tested the starter--nothing but a spark. I then tried turning the drive (looks good, no rust, no wear and moves forward freely)but could not pry the armature to move. took the plate off the back end an found a rusted water mark 1 inch high on inside of plate. The brush holders were rusty but freed up with PB Blaster. Slight oxidation on copper brush brush contact on arm. but no wear. The problem seems that the arm. is stuck to the field. Question: OK to spray PB or WD-40 into starter without harm wiring? Don't want to force. Feedback please, Mike S. @ SML |
mike stoher sr.
Mike,
With one of the ends removed, the armature may be stuck to the field magnetically. Take it apart and clean everthing up. Check the end bushings for wear. If worn, they too will cause the armature to drag on the field. Consider taking it to a shop for a rebuild but if you want to do it yourself it's not that hard. Considering the armature and field ohm's out indicating it's good electrically, a shop will only do a couple things: New amature bushings, Turn the commutator, Undercut the insulation between the commutator segments, Install new brushes and check the Bendix. |
wild blue
Pete,
Sprayed the unside of the starter with WD-40. Let it sit and lightly tapped the armature out using a block of lead as a buffer. Only rusted on the lower side. Could not believe still has paint on the magnets. Found no sign of wear, not even brushes worn. Cleaned some rust off armatur, greased bushing and made sure brushes were making contact. Put it together to bench test Seems perfect!! I love it when things go well. Hope it will do as well under load. I think I'll have a beer and see if my luck holds out with the altanater. Thanks again, Mike S. @ SML |
mike stoher sr.
wild blue
Anyone know of a Wildcat or a similar boat that I can get measurements and pics of rear seat. Mine had nothing left to use as pattern. Wildcats in diaries are old and inactive. Mostly need to see how the lower portion is constructed.
Thanks and have a great Thanksgiving, Mike S @ SML |
mike stoher sr.
p/allen
Gold Member Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
Check with 62wood. I think he still has a 1970 wildcat for parts.
wild blue
Do you think this might be the original color vinyl for a 68 Wildcat? Another pic try Mike S @ SML Damn I think it might have worked. or not? |
mike stoher sr.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21183 |
Mike, you cant link to pictures on your hard drive. You either need to upload them to this site (use the image icon, which looks like a tree with an arrow), or upload them to an image site and link to them here when you post (using the image icon- tree with no arrow). The advantage to using an external image site (like photobucket) is there is less of a size restriction. Check the common questions forum for detailed instructions on how to post pictures.
wild blue
TRBenj,
I set up my PBucket account last night, after printing off the directions . I moved an image to PB but could not move it to CCF. The image address showed up on the preview but not the image. Maybe the web address I'm using is wrong ????? I'll have my wife help me when she has time. I WON'T GIVE UP--I WON'T GIVE UP- I WON'T GIVE UP----But thanks! Mike S. @ SML |
mike stoher sr.
BuffaloBFN
Mike, when you use photobucket put your pointer on the image and 3 links should drop. Use the 3rd(img) and copy and paste to the forum. You can also 'quote' someone else's picture to see the code and format.
Gonna be a neat boat! |
