Boat Cleaning |
ski4069
Newbie Joined: September-02-2007 Location: United States Status: Offline Points: 12 |
Posted: December-02-2009 at 12:04pm |
What is the best method to clean the outside of the boat to get the yellowish stain off from the water in our lake? Is there something homemade that works out great?
Thanks Jared |
Go to heaven ski like hell
Some people are happy with a homemade concoction of 50/50 Lysol toilet bowl cleaner and hydrogen peroxide. Personally, I havent found anything (home made or not) that can touch Marykate On/Off hull cleaner. Its super strong and acidic, but works like magic with no scrubbing, even when diluted. You can find it at West Marine or online. Just be sure to wear junk clothes and eye protection... and dont let it sit very long on painted surfaces (like the trailer).
ski4069
Thanks, I'll try it
Bigcity
Newbie Joined: November-29-2007 Location: Canada Status: Offline Points: 28 |
Our boat spends the summer May - October in the river near the ocean in brackish water. After a few weeks the hull gets real green.I try to pull it once through the summer to cleanand wax the hull and change oil etc and have found that FSR ( any marine store) works great. She cleans up like new. Good Luck.
BIGCITY
My Baby !! |
behindpropeller
Find a janitorial supply house and buy toilet bowl cleaner. You will go broke buying it any other way!!
Tim |
harddock
There is a jel called FSR (fiberglas stain remover) You apply it on with a brush or rag, let it sit 5min and wash it off. The area will need to be waxed but it works well.
There is also a similar product called Y-10. There is a concentrated powder that you mix with water called Slimy Grimy. This is more for cleaning a dirty scummy hull than just the stain. Should be able to be purchase any of theseat marine stores, or boat dealers. |
Different cleaners (chemicals) work better on different build ups on your hull. What works good for tannins in Wisconsin might not be as successful removing algae in Florida.
Definitely rinse your trailer well. |
behindpropeller
I think if all of these chemicals were examined you would find that they are all acidic. I will grab the toilet bowl cleaner out of the closet and post later on what it is. +1 on the trailer. Wish I had pics of what mine looked like before I painted it. Tim |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5779 |
+1 on the toilet bowl cleaner but heed the warnings fully. This stuff is caustic and will ruin trailer paint but far more important is to wear rubber gloves and eye protection. Rinse your skin immediately if you get any on yourself, it burns, I know.
I just cleaned my 81 this fall before putting it away but I removed it from the trailer. My hull was filthy but the Toilet bowl cleaner (The Works) took all the staining off without any scrubbing. Give it a few minutes to work and rinse it off. DO NOT get it on any painted surfaces or your trailer bunk carpeting. |
WhiteLakeSkier
Senior Member Joined: July-03-2009 Location: White Lake, NY Status: Offline Points: 197 |
on/off. Not the gel stuff. Put the liquid in a pump up pesticide sprayer and spray on. Stay clear of the mist though, you might melt!
I use the 'Works' TB cleaner. A good time to do this is when the boat is off the trailer.
I use a brush mounted on a 3 ft long broomstick. Not much leverage, but at least you can keep that acid off your arms! |
