  New Posts New Posts RSS Feed - Another BFN Rebuild
Another BFN Rebuild
 Post Reply Post Reply Page   123 31>
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Topic: Another BFN Rebuild
    Posted: December-09-2009 at 3:08pm
Things are starting to slow down a bit here with winter having set in and the holidays upon us... so hopefully this will spark a bit of interest. There have been several worthy BFN rebuild threads (Buffalo, Hasbeen, Grinch), but ours will have a few unique elements- so while I was initially hesitant to start a thread of our own, I guess theres no harm in doing so. So here goes- you might want to put on your reading glasses though.
A bit of background: This past summer I was able to convince my dad that a BFN would be a nice addition to our fleet. We found this '79 in New Hampshire, and while it was a little rough around the edges, it was largely complete. While I wouldnt call its performance during the test drive overly impressive (it was taking on water at a pretty good clip, it wouldnt come out of the hole to save its life, and one of the speedos leaked all over me the whole time), it did turn in an honest 52mph on the GPS- so we were sold. Over the last remaining months of summer, we tinkered with it a bit- tried a few props, added a DUI distributor and a 750cfm Holley, did a bit of rewiring and gauge replacement, put on a new starter, re-sealed the rudder port (and got a new rudder when we didnt safety wire the original back on), etc. We footed with it some and hot lapped the lake a bunch. It was reliable, the holeshot was much improved, and it turned in a best of 58.5mph in Lake George to win the 2009 "Adirondack Dash"... so not bad first summer.
What we knew going in was that any boat this age was going to need structural work at some point... and while all the motor mount lags were tight, the boat did come without a cover so it had been exposed to its fair share of weather. The only soft spots in the floor were in the rear removable panel and a little bit around the pylon- but we figured it was due sooner rather than later. The glass over the stringers in back had plenty of cracks as well. When we pulled the pylon out of its cup in the hull when using the boom (the floor flexed enough to allow this), that confirmed it... this winter it would get re-strung.
So this is where the fun part begins. Dad has done most (all) of the hard work up to this point- having the boat in his garage makes it a bit easier, I suppose. He pulled the floor to find most of the wood to be rotten, no doubt helped along by a lot of waterlogged foam. The front section between the engine and bow were particularly soaked- the 3 vent hoses which had disintigrated and the faulty battery box drain were surely contributors. Dad said he easily removed 400 or so lbs of foam. These are the only decent pictures I have up to this point, along with the ones I shared in the "redneck engine hoist" thread:
With the weight of the 454 and soaked foam gone, the trailer springs have breathed a sigh of relief!
As it sits now, all of the stucture has been removed, save for one main stringer. Ive got a bit of grinding to do this weekend, and then it gets tucked into the back of the garage where we will start to put it back together.
We've assembled a list of modifications and changes we want to make. These include:
-replace all wood in floor and stringers with composite
-install engine cradle
-replace all flimsy vent tubes and hoses with PVC pipe
-move pylon 2" forward to allow access to bilge in front of engine
-install kick plate that spans half the width (like on newer boats) for more under bow storage
-replace drivers seat frame with 80-84 (non-delux) version to allow easier adjustment
We've also got some engine work planned and some cosmetic work to do, but Ill save those for another thread.
Right now, the plan is to not refoam, at least not entirely. We may do a bit of the bow section to give the boat some floatation and hold all of our tubes/vents in place. Thanks to JoeinNY for that idea. Im also stealing a page from Joe's book with the stringer and floor material selection- Coosa. He's been a great help so far by cluing me in on some of the finer points of his construction.
Before we start ordering materials, we're going to mock up all the pieces we'll need out of wood. That should give us an accurate idea of how much we'll need to buy. Probably a good idea since coosa isnt cheap. Right now I am planning the stringer layout in CAD- its probably the most fun Ive had with the tool yet. The biggest obstacle, if you want to call it that, is the addition of the engine cradle. The early BFN stringer shape doesnt lend itself very well to installing one- there is a ~1" jog in the stringer between the front and rear mounts. The rear OMC mount installs directly on the main stringer, while the front mounts sit on 2” tall blocks and shims. Even with secure lags, these blocks flexed a bit with the torque of the BBC, so they have to go.
Since the stringer shape will need to be different (flat) regardless, Ive decided that the best option is to install a newer style engine cradle. Starting in 1990 with the Ski Nautique, newer CC cradles require wider primary stringers, by about 6” (inside to inside of 26” vs. 20”). Instead of the mounts sitting directly on the cradle and having the stringer notched below it to give space for the nuts to attach, the mounts sit inward on angle aluminum tabs that are welded to the cradle. Heres a visual from my ’90 SN:
Since installing a newer cradle will require cutting off and rewelding the tabs to accommodate the 454 anyways, this gives us a lot of flexibility on final stringer height. No need to be super precise with our layup since we control exactly where the mounts will be (both height and distance from transom) by where we locate our tabs on the cradle.
Anyways, here is a quick look at the proposed vs. old structure:
Its not finalized by any means, but its getting close. Here is what the structure will look like with the vents/tubes (teal), cradle/battery box (blue) and the floor (pink):
The plan right now is to foam in the front 3 cavities (up to the 3rd bulkhead).
This is a (very) rough picture of what the cross section will look like (at the rearmost bulkhead). Old structure is in green, new in red.
Like I said, nothing is set in stone yet- still plenty of time to make changes or incorporate new ideas. Comments/questions/concerns are welcome! Ill get some updated pictures this weekend.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 3:52pm
Wow. That is all. Wow.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
502Python View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 502Python Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 5:09pm
I'll be watching this thread. Looks like there is a lot for me to learn from you.
1999 Sport Nautique-Python Powered
1999 Ski Nautique-Python Powered
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 5:36pm
I think you should re-title the thread to "Not Just Another BFN Rebuild"
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 5:50pm
Ha, I dont know Alan- have you seen Gregs, BJ's and Kirk's work? Those are tough acts to follow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 6:07pm
Well put.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 6:08pm
The bar is set pretty high indeed but that's whats so great about this site. You can see the quality of the rebuilds from year to year keep improving. We're turning out some very well done projects these days, not to put too much pressure on you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 6:26pm
The other amazing part is that it will be completed by April.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 6:49pm
Very true Alan, lots of quality work going on around here these days. Hope we can keep that trend going!
Just for fun, heres the what the overhead view looks like with the top deck and accessories installed. I wasnt going to go this far, but knowing where the scoops, seats, dash and everything else are really helps lay out the structural pieces underneath. Of course, I probably got a little carried away with some of the details. Oh well.
Bruce, I dont know about April, though that would be nice. May-June would be acceptable.
Wacko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wacko Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 7:21pm
Looking forward to the updates. This looks very interesting and well thought out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 7:54pm
Now that the ball is rolling, does anyone have any ideas on how to improve storage in the boat? While its a full 19', it really has no more storage than my 16' Skiers or Tique did- which is to say, next to none.
Right now Im thinking of adding another pod on the passenger side like Kirk (the Grinch) did.
Probably incorporate cupholders like he did, too. I have a black glove box out of a '68 Freeport- what did the 70's glove boxes look like, and where were they installed? Up under the dash? I dont plan on cutting any holes. What about the forward-folding observers seats in the 80-84 Ski Nautiques with non-delux interiors... does that make access under the bow that much easier, or are they useless? Under floor storage somewhere?
BJ mentioned that he'll be moving his battery to the rear of his BFN. I considered that, but I think Ill need as much weight forward as I can get- with the extra 400 lbs of waterlogged foam in the bow, the boat still ran plenty bow high. It would really rise up when coming out of the hole with a few people in the back seat too- I dont want to make that worse with a rearward weight bias. For whatever reason, this BFN doesnt seem to run faster with extra weight in back like the smaller, flatter boats- so no worries there.
What about future growth- anything I should consider adding now with the floor out? I have no plans for a heater, stereo, shower, etc- but who knows what the future holds. Again, I will not be cutting any holes in the dash or gunnels- in case that wasnt clear.
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 8:01pm
Tim
Quit being so vague.
Have you gotten your cradle situation figured out?
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 8:14pm
Originally posted by tullfooter tullfooter wrote:
Tim
Ha, sorry Steve... too much detail?
I think maybe its figured out- I havent spoken with him yet, but Eric is supposedly bringing them back to OH. Once I can confirm that, Ill let you know. Thanks again for your offer!
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 8:49pm
Tim I think the engine cradle would be a must with that much torque. The stringers on your BFN are very different to Greg's latter model BFN. In his the engine was mounted on a cradle lower in the hull and the primary stringers were much lower than the secondary stringers that supported the floor.
It appears they put that dip in the stringer so the block under the front mount could be smaller. That is a bit "agricultural" (rough in Oz slang). When Correct Craft started using the cradle it was a huge improvement for engine to drive line stability and the pylon mount was much more substantial.
By going to the wider spacing on the primary stringers. Would it be possible to do away with the secondary stringers assuming they are there only to support the foam filled floor.
Then just use the full bulkheads before the engine and the half bulkheads down the sides and after the engine to support the Coosa floor. The beam on your BFN is a bit narrower than the latter BFN's that would lend it self to this style construction.
This was how I have planned my stringer replacement in my 89 if I ever get the courage or inclination to pull the floor up. The 89 2001 also used the wider spaced stringers like your 90 as it had the PCM reduction tranny.
Looking forward to following this thread as the bar is raised again.
89 Ski
hasbeenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 9:11pm
I have two things to say
1) Atta baby!
2) Wooo hoo !
bj
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 9:34pm
Haha, thanks BJ.
Lewy, I like your idea about nixing the secondary stringers- I think Sebastian did the same thing. Unfortunately, it would be quite a stretch if its possible at all. Id have to see what the width of the BBC is at floor height- I think it might be too wide to fit in a 26" wide space. In other words, the stepped stringers open up enough to give it room and I dont think I could bring the main stringers full floor height. Even if the engine would fit, it would make it pretty hard to get a hand down into the bilge. Also, even with my taller mains (approx 3-1/8" taller than original), theyre still 3-3/8" below floor height. The new style cradle is 6-1/8" tall, which is driving the new height of my mains to avoid trimming it down. If I were to bring it up to the floor, the rear mounts would sit below the rails of the cradle- not ideal. Moreover, while the design would be simpler, Im not sure it would save any material... in fact it would probably cost more to make the 1.5" wide mains taller than it would be to just have the 1/2" wide secondaries in there (which are also shorter at less than 8'). Oh- and last but not least, the exhaust sits on top of the primaries so they couldnt be full floor height all the way to the back regardless (they'd block the thru-hulls). I guess that is a dealbreaker... but thanks for thinking outside the box!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 9:34pm
Projects like this clearly mark this forum as the premier website for ski boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 10:04pm
Ha, we havent even started rebuilding the boat yet... but thanks Chris. No argument on the quality of this website though- Im glad to be a part of it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2009 at 10:30pm
Tim - Your upfront planning will make a big difference in the end result, keep it up!
Keuka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keuka Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2009 at 1:11am
Tim
With the attention to detail and preplanning you are doing before you even start, I can't imagine the finished project will be anything less than outstanding. I would just be tearing into it, taking lots of pictures and measurements along the way.
I am a fairly new to this sight and have only been a boat owner since August. I am traveling a lot for work this winter been reading through these rebuild threads. It's great hotel reading and a little inspiration for the project I will someday face on my Martinique.
Keep it coming
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2009 at 1:14am
When I looked at the picture at the start of this thread I thought the main stringer was at floor height. But now after looking more carefully I can visualise the step down. That is the same as in Greg's later model BFN. Just the angle that the picture was taken from made it look like floor height.
Yes no secondaries just like the guy who did Kapla's stringer job and that is a much beamer boat than the early BFN. I feel if you are not going to re foam there would be no need for the secondaries. I don't think they add much to the hull strength but would like to hear what the engineers think of that.
89 Ski
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2009 at 2:02am
I gotta agree with Joel...wow...
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2009 at 10:42am
Thats correct- the structure isnt exactly the same as the later BFN's, but its close. The addition of the cradle drove a few changes at the factory, as did moving the cockpit forward in '87. I agree that the secondaries dont add a lot of strength- ours were no more than 3/8" from the factory, maybe 1/4" (tough to tell since they were so rotten). They will essentially be framing the bilge in our construction. The engine just sits too low in the V-hull to bring the primaries full floor height, unfortunately.
John, have you seen the '82 BFN project on ebay? Youve been playing that "not handy" card too long- I say you grab it and dig right in. You could borrow most of the ideas from my build for yours!
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2009 at 7:42pm
Looking good so far. This is one I like to watch. I love the pre-planning and CAD work...very nice. The ideas you have seem really solid and well thought out too.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2009 at 1:38pm
Glad you started this Tim; and looking good!
1988 BFN-sold
skfitz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2009 at 2:40pm
Very impressive. What material do you intend to use for the stringers? Coosa sheet cut and laminated to proper dimension?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2009 at 3:19pm
Correct- the entire build will consist of coosa. The primaries will be 3 laminated layers of 1/2" bluewater 26. The rest of the ribs and bulkheads will primarily be 1/2", doubled at the floor joints as applicable. The front section of the floor where the front seats mount will be 3/4" with glass on both sides. The rest will likely be 1/2". The front sections that are being foamed will be simply glassed over, save for the raised kickpanel portion, which will be framed with 1/2" coosa to allow for the mounting of panels and accessories.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2009 at 6:16pm
. . . doubled at the floor joints as applicable . . .
Could you 'splain for the noob? And by noob, I mean me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2009 at 11:16pm
I will be doubling up the ribs/bulkheads (so they are 1" thick instead of 1/2") at all the joints in the floor. Clearer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2009 at 12:23am
Got it. I'm looking forward to following your build.
