  New Posts New Posts RSS Feed - 1990 PCM ENGINE PAINT
SASHAY1939 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SASHAY1939 Quote  Post ReplyReply Direct Link To This Post Topic: 1990 PCM ENGINE PAINT
    Posted: February-10-2010 at 6:29pm
I looking for a source or paint code for the silver engine paint used by PCM in the late 80's -early 90's.
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 6:40pm
Rustoleum!
82 Nautique 1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 82 Nautique 1 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 8:20pm
High temp ? Part # Color #
Original Owner " Dennis"
1982 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 9:09pm
Last I checked, SkiDIM sells it.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 9:36pm
no need for high heat..regular paint will do just fine...just make sure all surfaces are clean and degreased..if not paint will not hold and will peel off when dry....
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-11-2010 at 9:49am
take a painted piece to your local auto body supply store, they may be able to use a color eye and get you close, fwiw, i use bc/cc to paint engines good up to 350 degrees and to date...well its durable
