96SNOB Steering |
Author | ||||
storm34
Posted: March-16-2010 at 3:42pm |
Anyone know the correct length for a 96 SNOB?
WakeSlayer
Chris I bet Bruce Foutz does.
Mike N
1968 Mustang |
storm34
Thanks Mike, do you have any contact info?
Just got an email from Karen. She said we'd need a special cable for the SNOB. I'm guessing due to the windshield and dash being moved back. Makes for a pretty pricy cable, but I guess thats the luxury of having an open bow! |
WakeSlayer
Mike N
1968 Mustang |
According to White Lake Marine's online store, all boats from 93-97 used the same 19.5' steering cable. Its special in that its a special Teleflex part (not a universal cable), but theres nothing special about the SNOB.
WakeSlayer
My understanding is that most later model CC's have an XX.5 cable, and a proprietary throw to them.
Mike N
1968 Mustang |
storm34
Thanks for the info guys...I'll do some more checking and see if Karen can get me one in the next few weeks.
Tim,thanks for clearing this up. Looks like the one in their shop is around the same price as what Karen expected. The weird thing is the dealer thought it'd only be 150? You guys think the difference would be in quality of the cable? |
boat dr
There is a throw differece between a CC cable and bass boat.I think it is 10" vs 7" all else being the same.
You can use a "standard cable" and it will fit, and it will turn the rudder BUT........It will not turn as sharp to port.........Just did one in the shop, Buy the stuff that came on the boat, from someone that knows CC,quality aint cheap. |
I agree with Billy. Buy the right cable for the boat. The earlier boats (pre-2001) used the standard cable with the shorter throw. I notice a huge difference in low speed maneuverability. I can get by with the smaller boats, but we're buying a high dollar cable and converting the BFN over this spring.
storm34
Don't worry Billy, waiting for Karen to get me hooked up! |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
Sorry I have to jump in here. When we went over to Teleflex rack and pinion there really was not any thing special or propriatary about it until we utilized the idea of incorperating the old larger rotory cable in the rack format. Then in either late 90's or early 2000s teleflex went to a larger rack mount and pinion assembly. Since Teleflex and Morse combined company's the larger heavier rotory/rack cables became more troublesome and early failure became a problem and Nautiques have now gone over to the standard Teleflex Extreem cable.
A suggestion for all that are considering a new cable in a early Teleflex rack and pinion application is to go ahead and up grade the pinion assembly to the newer unit and utilize the newer Teleflex Extreem cable. you will be happier for it. Also if you are paying more than $145.00 for the cable you are being robbed! This application does apply to the pre Teleflex Rack and pinion era nautiques as the old rotory systems do have a the extra throw incorperated in them. Cheers! Jody |
Fl Inboards
Sorry my disclaimer at the end should read: This application does NOT apply to the pre Teleflex Rack and pinion era nautiques as the old rotory systems do have a the extra throw incorperated in them.
kapla
Thread Jack
Hey Jody good to have you back!! how was your trip to the aussie land? Pics? kapla |
DrCC
I was wondering the same? Moomba pics?
AT |
storm34
Thanks for the info Jody, looks like I have some research to do on cables!
storm34
Update on the SNOB Cable. New one is sitting in the office and I'm planning on instillation in the next few days.
I've been researching rudder removal. We had a vibration last year when turning, the best description I could come up with is it felt like the rudder was rattling around. I went to see the boat last night and the rudder seems to bounce when you turn the wheel. It would only do this in one direction, the other way was fine, smooth and easy. Does this sound like grounds for rudder removal? Just to be sure, I pulled these steps from another thread and a pic of Tim's 90 Rudder.
I'll probably pull the rudder first and check everything out before I pull out the old cable. I'm worried about messing up the throw when I tear everything apart. Any thoughts? Suggestions? |
Edit: Just ignore my advice- I havent had to do a rack cable (yet). Jody has it covered.
Fl Inboards
Fl Inboards
Wrong procdure for centering a rack and pinion cable clamp block assembly and centering the steering wheel. Centering the rudder is done with a tape measure via measuring tip of trailing edge of rudder to the corner of the chine cut out/bottom of boat with the rudder at full travel one way then measure full travel the other way. Move the cable support tube so as the measurements are equal from full travel both directions then tighten down the clamp block assembly. To center the steering wheel the boat needs to be run on the water. Keep in mind that the hub assembly is splined with the sterring post. First remove center cap then loosen the nut holding down the steering wheel to the hub with a 3/4" socket Note: do not completly remove nut but get it finger loose. Next run the boat up to 34 mph holding the steering wheel firm and driving in a straight line(this next part is kind tricky)notice where the steering wheel is oreinted and where you would like it oreinted at this point holding firmly to the steering wheel and driving in a straight line, slowly pull the throtle handle back down to idle/out of gear then unscrew the nut as it should be on finger tight pull off steering wheel re-orient it where it needs to go install the nut again finger tight then go check. If all checks out OK then retighten the nut with 3/4" socket and put center cap back on. I do this part of the procedure in less than 3 min so it is not complicated. With Tims method you may wind up with more rudder travel going one way then the other. Keep in mind I have already replaced three rack systems this month. Also on your 96 you would do your self a favor and buy a new teleflex Extreeme cable and the newer pinion assembly as it is superrior to what came orginal on the boat. It's hard to find good help these day's |
Fl Inboards
Tim did mention about the cable length and throw also needing a "special" cable.
here is a measure ment that can be performed to make sure you either use the "special" cable or can use standard length cable If your tiller arm is 8-1/16" bolt center to bolt center you will need to utilize the "special" extra throw cable. If the tiller arm measures 6.5" bolt center to bolt center you can utilize a standard throw cable. |
storm34
I may do this, just because we were having some water on the carpet in the back of the boat. I think I've tracked it down to the rubrail. Just want to make sure, thats a different topic tho.
I'll snap some pics at lunch, I'm pretty sure I'll be reusing the clamp box. This is the white deal coming out of the starboard stringer? Correct?
Here's a picture of the assembly at the helm. Hard to tell, but thats the end of the teeth and you can see the cable on the right side of the opening. It looks like it's set up to one end (either right or left). I talked with Woody this morning, he said if the wheel's not right side up I can pop the center cap and flip the wheel accordingly.
This sounds like it should be pretty simple. I feel that I'm thinking about it too much, I need to get in front of it and just get it done. |
storm34
Thanks for all the help on this! I thought I would try my best to document everything for others.
storm34
Jody, thanks for all the info...Sounds like you and Woody are on the same page with centering the wheel. I got the cable from him, he knew exactly what I needed once I said 96 SNOB.
Great description on finding correct throw aswell! He thought I would be alright as long as I don't mess with the settings once I get everything apart. I'll see if I can get it installed tonight, make some measurements and report back! |
Fl Inboards
Chris here is another one you might want to know when you re-assemble the steering cable. Their are or were four small ss flat washers for the rack and pinion assembley. They do not go under the fastner heads but they get sandwiched in between the pinion and rack for correct gear mesh tolerance. |
storm34
Thanks Jody, Woody did mention this briefly but I wsn't 100% sure if I heard him right.
storm34
A huge thanks goes out to steve workman and pete brainard for taking my phone calls tonight! That's what makes this site so dang cool!
I got the old cable out and am having trouble getting the new one started. The first 2 feet seem the hardest. I think I just need another set of hands to pull while I feed the cable through. Not near as easy as a throttle cable! The bumping I was talking about turned out to be the rudder. The packing nut was completly loose and was turning with the tiller arm. After talking with Pete a second time I went ahead and dropped the rudder..just my luck, not enough clearance to pull it. I'll get some new packing rope since I've already got it opened up. I'll be back tomorrow night more prepared and see if I can't finnish it up. Kind of frustrating night but I'm so lucky I've got everyone here on my side to teach and help me through this! |
62 wood
Chris
So, the rudder definetely had a little more play than it should have?! Glad you ended up checking the packing and found the reason why. Thats the great thing with this site...lots of people with lots of different experiences...and always willing to help! |
Steve,
The jam nut wasn't locked down on the packing nut so it would turn with the rudder. Since the rudder shaft to port was always a pretty sloppy fit, I highly suspect that's where the vibration was coming from. No warranty on the boat? Chris should get some of his money back! |
storm34
Pete/Steve, thanks again guys. You ROCK!!
Anyone have any tips on getting the new cable started? This one is giving me hell trying to get through the first 2 feet. I'm a little worried I'll damage the other controls/wires going through if I try and force it too much. ps- I now know why Pete always wears long sleeves, I got into some glass last night on our muffler and am itching like a homeless bum!! |
62 wood
Actually ...most the time our heads are full of rocks.. |
