  New Posts New Posts RSS Feed - Another BFN Rebuild
Another BFN Rebuild
 Post Reply Post Reply Page    <1 678910 31>
The Godfather View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Godfather Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2010 at 11:02pm
The blue oil pan is covering the supercharger....
Tim, looking good as always.
I bet the coosa cost you per sheet.
Dave
wakeboardin2k4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2010 at 11:05pm
Raindog, what heads does the 8.1 have. I would think the exhaust ports would be the same on tims 454 as the 496 since hes got rectangular port openings.
Just curious. I dont know much about the pythons but the entice me
RainDog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RainDog Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2010 at 11:49pm
Don't really know. I've only read that the 454/502 are interchangeable but the 8.1/496 is not.
PCM made Pythons out of the 502 block until 2002 when they switched to the 496, a 6 cu in difference WakeSlayer will never let me live down.
The only other thing I know is that the 502 is a big bore, stock stroke 454 but the 496 is standard bore, lengthened stroke.
Maybe some harecore bow tie folks know more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2010 at 11:55pm
That's very interesting. I did not know that about the big blocks.
Tim-where did you guys find those EMI's? I saw a pair on an offshore boat racing site a few months ago. Curious if that was the same pair
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2010 at 10:19am
I have the Python head info somewhere. I just went through a complete computer conversion, when I can get my sh!t together I will post it.
That is a big 6 cubes, Steve.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2010 at 11:18am
Tim, thats the old style, if it works it will be just fine...i was critiquing...thats a tough one to spell, you know what i mean
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2010 at 1:03pm
The 496 is the Gen 6 GM big block (8.1L). I dont believe any parts carried over from the earlier versions. The 502 (gen 5) is a slightly taller block than the 454 (mark iv), but many parts interchange- heads, exhaust, etc.
There are a ton of parts for the 496 out there- you just have to know where to look. Not quite as many as the 502/454, but theyre out there. Nothing is cheap on these things!
I found the EMI's on Craigslist in Nevada. We were torn on whether to go old school (aluminum logs) or new school (new header/manifolds) but the price on these was good enough to jump on. While theyre billed as a stock Mercruiser replacement (dimensions-wise), they are several inches taller than the old manifolds we had on there, and a bit wider as well. We may have clearance issues when we drop the box over them. The intake and new valve covers are on their way and the roller rockers showed up last week. Just have to place a misc gasket/bolts/pushrods order and it should be ready to bolt together.
Didnt get as much done on the hull as I was hoping this weekend- too many projects going on at once. The fillets on the mains should be done now, and dad has a bunch of templates in process for the front bulkheads... hopefully we'll get some of this stuff glassed in soon. We did a fit check on the cradle and it set in nicely... so far so good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2010 at 4:03pm
Quick update... Ive been delinquent with pictures.
Last weekend we got the mains taped down and the keel bedded.
This week Dad filleted and taped down the keel. His first solo glass work... came out sweet.
Today we prepped everything for the top wrap, then got that down.
Prepped:
Wrapped:
The secondaries are cut top and bottom- just need the transom angle put on them. Tomorrow we'll get them bedded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2010 at 5:01pm
Nice clean work guys!!
Mike N
1968 Mustang
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2010 at 5:27pm
Slick job there Tim, shall be interesting how the toothing you have done under the bow is used.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2010 at 4:07pm
Roger, we're using the lip of the old floor as our guide to rebuilding the structure level. The toothing youre seeing in front are where we cut some pieces out to facilitate making templates for the bulkheads.
Secondaries are now bedded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2010 at 9:07pm
Those look like brand new weights!
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2010 at 10:05pm
they should be on ice, not wood
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2010 at 2:35pm
Weights are the same as last time... we've been gravitating towards the Sam Summers in dad's fridge!
Dad is hoping to get the secondaries taped in this week. Since theyre so close to the mains, we've decided to lighten the schedule up a little- only going 2/4/8/Biax.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2010 at 9:48am
gotta 40 wellcraft coming, not winterized, 2 bbc's, open checkbook and wants more power....if you could only see the smile, once in a while you get the peanuts instead of the shells.
i gotta figure these out, flats with rectangles, 370 stock, i want to get him to the 400 mark...what do ya think Tim, both lefties, maybe I'll go after the pistons...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2010 at 11:04am
Eric, from what Ive read, you need a bit of compression on the BBC's to make good power. Im not sure what the Mercs came with for a stock CR... so find out what pistons are in it now. The rectangles should have ~118cc chambers, Im guessing it has either 990 or 088 castings. If you have at least 9:1, then just an intake and a cam swap will have you close to 450hp.
Of course, this is all theory until we get ours wet!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2010 at 9:17am
im battling 1990 technology, and feel by camming and intake i will get to that 400 mark, I got both engines yesterday, slight dome in the pistons, merc aluminum intake, 2.300 with the 118's. all the right stuff...i could fit a fist in the runners....once in a while i get excited about running a boat, I have 2 on the list, the Zodiac diesel with foot bolsters, and this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2010 at 10:27pm
Dad finished glassing the secondaries this week. Its surprising how solid the hull feels now with just the stringers in... still missing all the bulkheads and ribs.
Today we spent perfecting the bulkhead templates and getting them cut out and shaped. Hopefully they'll get pre-glassed this week. Next step after that will be to do the same on the rear ribs, then start cutting holes in all the pieces for the battery box and vent and blower hoses.
Secondaries glassed:
Bulkheads shaped and resting in place:
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 2:03pm
Benj,
Looking really good. I agree those weights should be in the fridge, not on the stringers...LOL!
It is pretty surprising how stiff things get huh? I noticed that too. Since my top cap was off, mine was really flimsy as I took things out, until things were back in. The most noticeable for me was when the deck got attached to the outer hull sides.
You are coming along nicely. I like how you're doing the ribs all the way across as one piece. Is that typical for this type of Nautique or are you altering that from original?
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 2:15pm
Oh wow... Hollywood...it's on the tee
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 2:31pm
Thats how the BFN's (and presumably the other v-hulls) were built. We're deviating from original in a few ways- since we're not foaming, we're adding a bunch of ribs (in the rear, to the sides of the secondaries) and bulkheads(in front of the stringers, which go full width). This should provide more support for the hull and floor. Our spacing is ~10-12".
Here is a picture of Buffalo's '88 BFN. He kept his closer to the stock configuration.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 2:47pm
Tim, this may have been mentioned but that steering wheel has got to GO, like, NOW. Worst. Steering wheel. Ever.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 2:55pm
Joel, Im surprised no one has mentioned that- youre correct, its fugly. Thanks to Chris (Storm34) we've got an original one going back on once the rebuild is done. For now, that cheesy one does a good job holding the shop light in place.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 3:07pm
Hey Tim,
Tried to call you this weekend, but from the looks of things you were pretty busy. You think maybe you can give me a call when you get off work tonight? You have the number.
BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 3:15pm
Brian- you bet, Ill give you a buzz tonight. I remember seeing your missed call now that you mention it... this weekend was a blur!
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 3:30pm
Don't drink too many weights Tim! Progress looks great!
lfskizzer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lfskizzer Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 3:56pm
So Tim you foaming any of the front area? I just finished up the stereo re-install on the 85 now its got some good tunes. and alittle bit of bass. Thanks to Morfoot's speaker boxes they worked out great. I built a customer 8" sub box and mounted it in front of the vent lines. and put my amp rack hanging from the deck under the bow. I will post some pics later after I clean out the boat of the mess i made lol. I am off this weekend the 24th if i have time would love to stop by to see the progress myself lol.
-Phil
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 4:03pm
So you'll have 7 bulkheads including the front of the bilge? You know if it can't bend, it'll break.
How far forward did you run the keel?
I like the floor tabs you left for reference, sweet. Yall are doing some super nice work; clean and clearly well planned out.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 4:41pm
Greg, good point- I do expect the boat to be solid! Ive had a few conversations with Joe regarding glass schedules... we're bedding and filleting 2 of the bulkheads shown, plus the narrower one that we've yet to build that will form the front of the bilge. Everything else will just be taped with 2/4/8.
Our keel board only runs as far forward as the original one did. We did bring it further back (and the mains further forward) though. Thanks for the comments- thats high praise coming from you!
Phil, yes the front 2 and a half cavities are getting foamed. Basically the front 3, minus the area under the battery box in that 3rd cavity. That will be the forward most drain point. The foam will hold all of the pipes in place, give a little bit of sound deadending in chop, and hopefully keep the boat off the bottom of the lake... or at least slow the rate of sinking. The foamed cavities will be glassed on top. Not sure what our schedule is this weekend- probably still splitting time between the boat and the cottage, so give me a call.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2010 at 5:19pm
Chris,
You forgot that he's getting the good weights out of his dads frig!! The good SA summer stuff! His dad has better tastes!!
