  New Posts New Posts RSS Feed - rusted block drains ?
brittcrowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittcrowell Quote  Post ReplyReply Direct Link To This Post Topic: rusted block drains ?
    Posted: April-21-2010 at 3:13pm
So with the trailer fixed, on to giving the boat some TLC.
Went to put back in my block drain plugs and man are they rusted up.
Going to my grand paps shop, I know he has a lot of taps. Is that a good/bad idea? what size are those threads?
One side is really bad, the other is so so.
I know that I should replace them with quick drains. Can you replace the one under the water pump with a quick drain too?
'93 Ski Nautique (needs new interior)
east tx skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote east tx skier Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2010 at 3:31pm
The block drains are 1/4" npt as is the drain on the j-tube. The manifold drains are 3/4" npt.
1998 Ski Nautique (Red & Silver Cloud); GT-40; Perfect Pass Stargazer; Acme 422.
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2010 at 3:59pm
Is that a crack next to the hole on the bottom pic? I've used alot of PB Blaster and a soft cylinder shaped brass brush (like a gun brush) on a cordless drill to clean the threads up before, but that one may be too far gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittcrowell Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2010 at 4:10pm
Gun brushes! Duh! Thanks man, I went to HF and Lowes looking for something yesterday when all I had to do was stop by WallyWorld and head for the sporting goods dept. Heck I even might have one or two laying around in the gun cleaning kit for my 16ga.
Britt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2010 at 4:26pm
Britt,
It wouldn't hurt to run a tap in to chase the threads beside the wire brushing. Since a pipe thread is tapered, you don't want to go to deep otherwise the plug will be too deep and loose. When you feel the tap tighten up, just go one more turn.
BTW, I believe the plug on the J tube is 1/8". Check it.
Yes, brass quick drains are a good idea. Won't rust but use the ones with the removable stems so you can still probe the hole for sediment when draining. I'll see if I can get you a picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittcrowell Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2010 at 4:37pm
The J tube uses the same brass plug as the engine block.
SkiDim has these. $81
http://www.skidim.com/prodinfo.asp?number=MCM001
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2010 at 4:59pm
Granger has them as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2010 at 5:34pm
DO NOT use that kit from Skidim. To this day I can't understand how they can sell a means of draining that can't be probed for sediment. Here's the removable stem stock cocks I as well as others have found to be the best. The center valve stem unscrews completely.
You'll note the are available in 1/8, 1/4 and 3/8" pipe size. If your manifolds ar 1/2 or 3/4" you'll need a bushing. I suggest brass. Here's a link: stop cock
EDIT: The link isn't working for me. Go to www.mcmaster.com and enter # 4921K2 for the 1/4" size
