Another BFN Rebuild |
Page <1 7891011 31> |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21143 |
OK a few questions.
I am trying to figure out how to support the rear removable panel, and how to mount the gas tank. I could use some input. Right now I am planning to support the rear panel with angle alumium, which will attach to the secondary stringers. This is how CC supports the panel in all of the 89+ boats. The only thing I dont like about that is how they attach- CC lagged them into the stringers. I would rather not lag into the coosa. I cant through bolt from the inside, as the floor will be installed and glassed down to the stringer, so no access to get a nut on. I could potentially install the bolt (somehow secured from spinning) before dropping the floor on. My only fears in this scenario is 1)keeping the bolt's threads clean while glassing the floor down, 2)if I ever cross thread a nut and bugger up the bolt, Im screwed because it cant be replaced, and 3)if it ever breaks free and spins, I cant remove the angle. In regards to the gas tank, I plan on attaching some 2"x2" angle aluminum to each of side of both secondary stringers- so it will essentially sit on two T's. Probably put some rubber between the angle and tank. Im not sure how Im going to secure it down though... the original configuration had the tank sitting on some 1x's that spanned the whole length of the tank, and the tabs at each end screwed down to those. Some sort of straps? Any thoughts? ![]() |
do you have acess to a lathe? I have an idea that will work if you do, but you'll have to lay it all out to locate the insert before you permanatelly mount the pannel. I don't see a problem thru bolting the angle for the center removable pannel should be easy, but if your wanting a mostly continuous stop for the bottom of the pannel the two outter sections will be the tough ones to get layed out but I would think glassing in a post/stud wouldn't be an issue, it's not like you going to be removing it anyway once it's down its down and there shouldn't be a reason to have to removed it, you really only need about 1/2" lip maybe 3/4" to keep it in place at the floor.
another option is using studs that have a hex on the end or square that is smaller than the minor diameter of the thread, then all you have to do is double nut it on the underside using an oversized flat washer too and stick it through the pannel glass it in on the bottom, tape the threads off on the exposed side, glass that side and call it a day if it breaks free you have the hex feature to hold the stud while you turn the nut with and open end wrench. Instead of double nutting the underside weld the nut to the stud will work better it's just a stop anyway. This might be a little easier though why do you have to use angle? Why not just create a channel in the floor for the lower section of the pannel to rest in say 1/2"-1" deep for the entire width of the boat, you could even stop the removable pannel flush with the vertical pannel and then just use a small strip of corsa to support it from sliding backwards. |
another thought is building up on top of the floor's level behind the vertical pannel with a block/strip of corsa say 1" high or so you could use wood if you wanted to use screws but you really don't need to screw the bottom it can only go back if someone is leaning against it so you don't really need them, the top is going to be secure to start with, I'm assuming your tucking the top portion behind the cap and not in front like the late 70's boat's where done.
sorry just realized it's a 79 makes it even easier since it is in front of the cap if it is like the SN's |
M3Fan ![]() Grand Poobah ![]() ![]() Joined: October-22-2005 Location: United States Status: Offline Points: 3185 |
Could you double up the 2ndary stringers on the inboard sides, and cut the floor to lap over that doubled up piece, falling short of the 2ndary stringer and essentially exposing your 2ndary stringers as the "shelf" on each side for the floor piece to rest on? The doubled up pieces are in red below.
Thanks for the input guys- now we're cooking!
Chris, Im having a hard time visualizing what youre saying. To make sure we're talking about the same thing, here's a quick sketch of my original plan. Hopefully you can check it out later tonight at home. ![]() This is the cross section of the rear part of the boat. The stringers and floor pieces (coosa) are in gray. The red line shows how I plan to glass everything together once its installed. The question is how to fasten the angle (purple) that will hold up the removable panel (green). In reading Chris's last comment, I had an idea that very closely mirrored Joel's. Instead of cutting the secondaries shorter and adding nailors to the outsides to support the permanant floor, Im thinking it would be better to add nailors (blue) for support on the inside to support the removable floor. I checked and I should have almost 1.5" to spare between the inside of the secondary and the exhaust hose, so even a doubled up piece of coosa (1-1.25") could be snuck in here. ![]() The question is, will a 3/4"-1-1/4" lip on either side be strong enough to support the panel? The panel is 34" wide. It will be built out of 1/2" coosa, with a few additional 1/2" strips on the underside running width-wise for support. |
Well I went real low rent on this fix, I ran 1x3/4 strips of untreated coose along the side of my secondaries held in by some stainless screws. My floor also sits directly on the primarys though, so it was just to keep the floor from popping up when one steps near the seam. Could you get more elaborate with the floor piece, with relatively deep legs on the bottom that drops down to the main stringers?
If you do the angle iron bit you would be a lot better off with 24 stainless screws and some 5200 than with a few lags. It is coosa after all you dont need to treat it like wood. I am heading down south for the weekend but when I get back I will take pictures of the tank strapping system in the 95 I believe it will be similar to what you are proposing. |
hasbeenskier ![]() Platinum Member ![]() ![]() Joined: May-23-2005 Location: United States Status: Offline Points: 1116 |
My two cents worth is Joe's idea with the added concept of glassing the coosa strips to the secondaries taking into account the thickness of the glass layup. There will not be enough weight on the deck to shear off the strips.
bj |
hasbeenskier
Good stuff Joe.
I cant run supports down to the mains because the exhaust hoses will be sitting directly over them- mainly towards the inside edge. The only place I can grab some room is all the way out towards the secondaries. My concern with the lags was the screw retention- obviously not rot. The thought of using a bunch of smaller screws had crossed my mind... maybe Ill add a 3/4" strip of coosa along the inside of the secondary for the panel to sit on, and add a 2" angle to that, held on by a bunch of 1-1/4" screws. That would give me 2-3/4" of surface for the panel to sit on. The shorter, smaller screws wouldnt extend all the way into the sealed cavities either. Is that what youre saying BJ? ![]() Regarding the gas tank, my '90 has a strap system with threaded rods that fasten down to some angles attached to the stringers... Im just not sure how I would go about building these. |
FWIW what I like about my idea is that with the section removed you get a really clean looking rear-bilge-area because there is nothing visibly sistered onto the secondaries.
My vote is to go with glassing on strips of Coosa. Tim, in that last sketch you did, it looks like you have plenty of room next to the exhaust. Is it out of scale?
Joel, I see where youre coming from... but Ill tell you why I like sistering to the inside better.
1)Cutting the secondaries down 1/2" in a section would be a PITA since theyre already in place and glassed down. 2)The secondaries are already covered in 4 layers of glass. They have this much glass to make them strong in order to support the (permanant) floor. The sistered piece that would be supporting the floor in your set up would not have this same strength. 3)Glass does not like to make 90 degree corners, and your approach would add a doozy when taping the floor down. See below (red). ![]() While I appreciate clean lines, strength and functionality come first... besides- its just the bilge! Not to worry though, if I add it to the inside it wont look "scabbed"... it will be filleted, glassed, smoothed and painted and will blend in nicely. |
Youre killing me Pete- yes the scale is a *little* off... but its close. Here it is in Autocad.
![]() Lots of room on the outside of the hose... in fact, the hose will barely catch the mains at all. I would add coosa exclusively, but it gets expensive! Im also not sure how much I will have left, and these 6" tall x 46" long support pieces arent small. Do you think a 3/4" lip at either side is enough? Or should I go with some 2" aluminum angle in addition to it? |
Tim,
I like the idea of the extra support area the angle would provide. Yes, 3/4" isn't very much! Instead of the angle, how about Coosa and glass? |
lfskizzer ![]() Senior Member ![]() ![]() Joined: July-26-2007 Location: Wilton, CT Status: Offline Points: 290 |
Tim
what about putting t-nuts in on the outside that the aluminum angle bolt into? ![]() T-Nut in Stainless Steel Would that work? |
whats wrong with some brunstucky rachet straps?, thats how you hold in a cars gas tank up here....works just fine lol...believe me, Ive seen it more than once
Ok I was thinking you where talking about the vertical pannel that covers the tank and the backrest that the rear seat covers. Your talking about the horz pannel that is removable. In that case I like the angle plate idea better. For fastneing it, I would get a 1" strip of flat stock, drill some holes in it, if you have access to a arbor press, punch square holes into it use carrage bolts welded in place or just plain old bolts welded to it would work too, then I would drill holes through the secondary stringer and then use lock washers and nuts to attach the angle to the inside. I would drill the strip and angle at the same time just clamp the two piece together and drill away they'll be lined up and go together pretty easily.
basicly the stringer would be between the stud strip and the angle stock with the threads being horz. maybe 6-8 1/4" diameter studs per strip should be enough. |
Chris, that thought had occured to me, but I wouldnt be able to make one big backer for the angle. There are ribs spaced at every foot between the secondary and the outside of the hull.
Phil, where would I put that insert? On the back side of the secondary stringer (outside) or the front (inside)? Do you think the barbs would hold it in the coosa? Im not so sure. Pete, you mean 2 layers of coosa (1.5" lip) instead of one (3/4")? I wouldnt extend the second piece all the way, as it would make it pretty tight with the exhaust hose. Thats also quite a bit more material ($$$)... do you not like the idea of screwing the angle in with a series of smaller screws? Eric, good looking out on the ratchet straps for the gas tank- why didnt I think of that? |
Keeganino ![]() Grand Poobah ![]() ![]() Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
Interesting stuff going on over here! Looks great.
1973 Skier |
Tim, you do any research on a good intake? im almost ready to assemble these 370's, the currents are factory Merc aluminums, but 1990 technology, I may opt to put these edel 750's on them since i have them in the box...not a big fan though, good baseline engines but i have to vee block the cams and see what i have and where i can go..im leaning towards hydromotive props, 4 blades,
I really think with whats there getting to the 425 mark wont be so hard...it has the guts, and i just need to be careful with the cams. |
if the ribs are in then you have to break it up but if not notch the ribs and glass over every thing. Also you could just embead a piece of strip stock in between the corsa and then just drill and tap after it's cured. |
Eric, the Edelbrock Performer RPM has a good reputation, as does the Weiand Stealth. We're going with the RPM on ours.
Chris, the ribs arent in yet, but Im not crazy about embedding aluminum into them. Will glass even stick to aluminum? Remember that the secondaries are only 1/2" thick. |
is there an issue with screws biting into the corsa material? worried about striping out later? That is what I'm thinking your worried about if not then maybe your over engineering too much into this and making it more complicated than it needs to be.
Chris,
The screws stripping out of the Coosa I believe is Tim's concern. I had never seen the material before Joe brought some drop offs to GL. Interesting stuff but not much to screw into. The center core is a higher density polyurethane foam and the skin is glass reinforced. Tim, The old West system method of creating threaded holes is to drill 3 to 4 times the diameter needed, fill the hole with filled epoxy, then drill and tap. Not a bad method but I wouldn't do it on only 1 layer of Coosa. At least 2 to get the needed bearing surface on the fastener. |
Chris, Pete is correct- the coosa will not hold a screw like wood does. The stringers are laminated with glass on both sides, which helps- but it still makes me nervous.
Pete, what do you think about securing the angle with a bunch of 1-1/4" #10 screws? They would extend all the way through the 3/4" support, but not through the 1/2" thick stringer. Or should I go with something larger, and possibly drill/tap the epoxy as you mention? |
doesn't the corsa soak up the resin and that is where is gets it's strength from, surely it doesn't remain in the foam state, not much structal strength in that. What the big deal notching the cross supports it only has to be the thickness of the strip stock and also who cares if it is several pieces you have angle to use as a guide before the floor is down. Get a scarp piece if aluminun and see if the epoxy resin sticks to it I bet it does.
FrankT ![]() Senior Member ![]() ![]() Joined: September-07-2006 Status: Offline Points: 245 |
Tim,
I have had good success with white oak. Epoxy and screw it to your glassed stringers. If you don't think 3/4" is wide enough cut two strips and epoxy them together first. I don't think you need many screw to hold the access panels down if that is your concern. On the Malibu this panel is hinged just behind the engine cover and you can open it up by simply lifting out the rear seat. FrankT |
Chris, the coosa isnt just foam- its a mix of foam and glass. Its quite strong and doesnt rely on the resin for strength- but the cloth on both sides makes it stronger and will allow for better screw retention. I could potentially notch the ribs for that aluminum backer, but ideally everything would be accessible and serviceable once the floor is in and sealed. That notch would also make for a lot more cuts and trickier glassing. I will keep it in mind though- thanks! Luckily we're not to the point of having to make a decision just yet.
Frank, we're going to a lot of effort and expense to eliminate the wood and foam in this boat... Im hesitant to put wood back in for any purpose whatsoever! Im thinking of doing something similar to your suggestion, only with coosa and/or angle aluminum. I wont be fastening the removable floor at all- all of the newer CC's just have them resting in place, which is fine by me. The screws would be to hold the angle aluminum to the stringers. |
If the floor is just going to sit there then there isn't a need for the aluminum angle just double up the corsa to create a shoulder, triple it up and add a radius to it and call it a day.
Chris, I cant double up the 3/4, as I dont have that much room between the secondary and the exhaust hose. Doing 1/2" and 3/4 is a possibility though. Definitely cant triple it up. I wanted a bit more bite than the 3/4" coosa could give me, hence the angle aluminum. The other consideration is cost and availability of the coosa... I dont know how much extra I will end up with, and at $250/sheet, its not cheap.
Tim,
I'd go the larger hole filled drilled and tapped for threaded bolts. I just don't like the idea of putting sheet metal screws into the Coosa. |
