  New Posts New Posts RSS Feed - S.O.S
S.O.S
 Post Reply Post Reply Page    <1 34567 16>
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2010 at 11:02am
Originally posted by Luchog Luchog wrote:
Originally posted by vondy vondy wrote:
We have a mechanic friend here who says water will get right passed the rings and it only takes a bit to milkshake. Thats what he says at least.
are you trying to convince us or yourself?
Oh, just bringing it up, I keep hearing different things from different people.
Guess I'll get it fixed and see what happens. If there is still water in the oil then I'll dig deeper. Sound like a plan?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2010 at 11:56am
if water leaks into a cylinder the exhaust valve has to be open, and last time it happened to me the enging hydrolocked, with a tablespoon of water
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 3:50pm
Well........
Talked to Ryan's buddy over at Buxton Marine here in town. His first suggestion is to fix or replace the manifold and see if that fixes the problem. If not, he basically suggest a rebuild. Not knowing the hours on the engine, he would be hesitant to put new heads or head gasket on without everything else being solid.
Actually he recommends getting a Jasper engine rather than a rebuild. That would be around $3,000. And have a waranty. Plus installation, etc. I'm sure I would be looking at $4,000 - $4,500.
He gave me the name of a local company that does engine rebuilds so I have contacted them. He seems to think it would be around $3,000 for the rebuild but I'll wait and here from them.
So, if I'm looking at $3,000 minimum to get back on the water, I will have a nice red lawn ornament sitting around for the season.
Also got a name to a company that might be able to fix the manifold, have yet to call them.
Anyway, I'll try that first then hope for the best.
Comments?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 4:09pm
David,
Before you go sending the manifold off for a expensive repair, find out where the problem is. If it is by the two plug holes I mentioned, it does not need a "specialist". Anyone who can handle a TIG can do it. Also, he may be able to handle more extensive repairs. If the problem turns out to be a burnt through section inside the manifold itself, then the outside jacket is cut open, the repair made to the inside and then the jacket is welded back together.
If you must send it out to someone, these guys are the experts: Crow Custom Cast
I know several of my antique/classic restorer friends have used them with fantastic results. I almost called them myself when I busted the hub end out of the planitary gear housing on the Flexifour.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 4:13pm
does anyone have an extra exhaust manifold to send to Vondy so he can atleast narrow down this issue a little more? Allen maybe? at this stage any type/style for a 351W would work to verify the rest of the engine is fine.
I feel the manifold has a 90% chance of being the issue, the intake gasket, next, I don't feel you sealed the water jacket correctly a thin strip of RTV on one side isn't going to cut it, also letting the RTV set up is not what you want to do in this type of install, valve covers, oil pans yes, intake no.
I suggest you borrow or buy a new exhaust manifold, recruit a professional to install the intake correctly with new Fel-Pro gaskets using a nice bead of RTV on both ends of the block and on all four water ports and both sides of the gasket before installing the intake and not letting the RTV set up any more than the time it takes to lay it down everywhere it needs to be, let it sit over night and then drain the oil and add fresh oil if there is still water in the oil that is currently in the crank case and replacing the oil filter as well, then firing it up and see what happens, if the water returns then it needs torn down to find the problem, might be the head gasket might be the block, if it's the block then there is only one route if there are signs of a head gasket failure then replace it and forget about the rebuild, you didn't have water in the oil before you over heated it so I question the block being the issue and a low percentage that it is. just my .02
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 5:38pm
Thanks for the advice guys.
Pete, I still have not been able to get the manifold apart from the riser. Soaked it every night with PB Blaster and still no luck. I ordered some of your Kroil but have no idea when it will arrive. Thanks for the link on the Crow guys. If it comes down to it I will keep them in mind.
79, I like your plan. It would be ideal if I could find someone with an extra manifold. Of course I don't know of anyone. Hopefully I can get this one of mine apart and if I'm lucky, it's easily accessible and weldable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 5:51pm
Ask the guys at Buxom marine if you can borrow one or maybe a CCF member can help you out, that will at least let you know how bad the heat got to it and in the short term if you have to get new exhaust mainfolds off e-bay then so be it better than having a yard noam for the summer.
also to clarify letting it set over night that is after the intake is installed and before you start the motor to let the RTV cure, Some like over night I say the heat will cure it quicker and have the same results but to be on the safe side over night it before you start it.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 6:20pm
My money says the manifolds although they may be leaking a little aren't the real culprit here. If they were leaking that bad the water would be in the cylinder and the motor wouldn't turn over. His water is in the oil pan and I would have to go with 79's thinking that the intake is leaking.
For a set of gaskets that would have been the first thing I pulled .
I also warned you about screwing with those manifolds. They are a butt joint by the way, if you've messed with them enough you should be able to insert a hack saw blade by now and just cut the studs off. THEN go to the machine shop to get the studs out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 6:36pm
I'm leaning that way as well Allen it's just that if he checked it right then he's seeing a leak.
here's a thought, drain the block and all of the hoses that have water in then so that no water is in the crank case or hoses, add fresh oil to the motor and new filter, after drining the old oil out. Pull the coil wire crank it over for a minute to circulate the oil, check the oil make sure that there isn't any signs of water in it, now pull the hose from the output side of the RWP, pour water into the hose and fill the block with water, check oil for signs of water, if now signs crank to motor again for a minute with out adding anymore water and the coil wire still removed, check oil again if there is water in it now then it's not the manifold causing the problem. But a small amount of water can turn into a milkshake quickly, I would agree tyically your going to see motor in the cylinder if it is the manifold and most likely hydrolock the motor too, but if the leak is slight then it could just be sepping past the rings.
just a thought, I too feel it's the intake but the mainfold is much easier to tackle for beginner so I suggested that route first, but there could be problems with the test of the manifold as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 7:05pm
I can get a hacksaw and cut the bolts but there is no way mine are a simple but joint. There is a piece of metal of some sort between the two halves. If you stick a feeler gauge in there and tap on it, it sounds exactly like tapping on the outside of the manifold.
Makes me wonder if there was not a problem in the past and someone stuck a tube between the pieces. If only I had a fiber optic scope.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 11:05pm
Here's what I got with this manifold...
There's definitely some form of metal in between the two halves.
This gap is pretty much where the gasket was.
Here's a closeup best I could get it. That dirty looking stuff between the joints is the metal.
This is the depth. Seem like it's right inside the water jacket. I can stick a then piece of plastic in the water drain hole and see it bridge the gap.
Should I get out the hack saw and start cutting? I can cut the bolts and see if that get's it apart. If not, I would assume this mystery lip would need to be cut. If it's deep in there, I can't imagine it coming apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 11:35pm
That's 50 year old gasket material that's been compressed and subject to hundreds of degrees of exhaust gasses. I had the same problem and I can all but guarantee it's not metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 11:43pm
So at this point should I cut away?
81, did you have a post once on this subject? I remember someone a year or so ago posting multiple pics with these apart. At least I think I do.
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 11:56pm
broken bolt?
PAPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PAPA Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 12:08am
David, I do have a good PCM exhaust manifold assembly if you would just like to try it. I can't sell it, I would need it back. It would probably take three days for you to get it. If this would be of any help and you decide you would like to try it call me 219-558-8127. John.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 12:08am
broken bolt?
What the so called metal inside? Definitely not a bolt. It's all the way around. It could be a gasket but sure sounds like metal when I tap on it.
Did they use metal gasket's by chance?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 12:29am
I'd wait until you could soak it with the kroil,remember measure twice cut once. Then get a dead blow hammer and tap on the riser to get it loose. I got mine apart and all I had to replace was the gasket. I think Chris is right,just think about it- it was fine when you used it last,the only thing that changed was the new manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 3:16am
You called it. I finally dug deep enough to break through and stuck a hack saw in there to dig the rest of the gasket out. It was hard as a rock.
I'll continue to soak the studs and see if I can't separate this beast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 9:09am
Gary,
I feel there's a problem with the manifold but I'm still not ruling out the intake issue ether.
With the overheat/no cooling water on aluminum exhaust manifolds, they burn through real quick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 10:38am
whats baffling me, unless you drained the block, your picture with the intake off there is no water in those passages, at that point its a closed system and if you fill those passages with water to the top they shouldn't or wont leak down unless you have an issue (crack), i still back up the clock and wonder why someone put an expansion plug in the side of the block and my theory is when you overheated the engine you pulled the short "straw"
water going into the cylinder will "steam clean" the cylinder and wash it down and i think i suggested a plug chop....pull all 8 plugs and look for a clean plug,
plain and simple, do a leak down test on each cylinder, air them up,
it takes a tablespoon of water to hydro lock a cylinder if the engine sits and leaks in from the manifolds...that *************** your pulling from the crankcase is coming from a large source of water, I really think you have a crack somewhere via, head, block or intake and i really think your chasing your tail
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 11:19am
Thanks for the offer! I'll keep it in mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 11:25am
Eric that pic of the intake off was taken before all this when I was installing the new intake. There was no water in the system from winterizing.
I still have not pulled the intake, I know the exhaust is leaking so I figured I could save myself the trouble of pulling and reinstalling the intake if, by chance, the exhaust was the only problem.
Now I just got to get the damn thing apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 12:33pm
Eric, in case you dont want to go through the whole thread, I will give you the "short" version:
Vondy if you can add something please do it, it would be nice to have eric on this train.
Vondy had a hot start issue, he attributed this to a flooding 2bbl carb, so after 5 pages of discussion he was convinced that his best option was a 4bbl carb and intake upgrade.
He installed the intake himself, he seems to have left the sealer cure a few hours before placing the intake on the cut-bolt guides. When he had his intake apart, there were some little water residues on the block but they could have been from moisture and condensation.
He tested the boat on dry and all checked fine, so he went for the lake test, he blew the expansive plug, found the messed up oil.
After he tested the boat back on dry, he noticed a hard starting noise and so I suggested him taking the plugs out and water fired out the cylinder. He also got milkshake oil again.
My personal opinion is he has a crack on the exhaust, that's been there for some time now, maybe from before he switched intakes.
but then there's another issue letting water into the crankcase, might start by the intake gasket, a head, a sleeve, or block.
He also did a compression test at some point at it all checked out good.
What we suggested at this point is that he first solves the exhaust problem, test again and then keep digging on the rest of the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 12:52pm
Good review Luchog. I would note that when installing the intake I let the RTV sit for 1 hour before completely snugging the bolts. Per the instructions on the tube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 2:28am
Here you go Dave. I wonder what the reserve is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 11:01am
Well would you look at that. Wonder how much she's worth? Looks like someone took a can of spray paint to her at one point. You can see it on the oil filter.
Can't see the rear engine mounts...
GottaSki View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 11:58am
So, replacing intake = water in oil....
Water from jug #4 who's intake runner is also adjacent to the water passage.
I'm betting its just the intake's gaskets as well.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 1:04pm
Kroil get's in Monday. Say this stuff works and I get the manifolds fixed. What kind of gasket material to I need to use to put the pieces back together?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 1:20pm
David,
Look for a compressed Aramid fiber/Buna-N gasket material. McMaster has it in small pieces. It's good for 400 degress which will be fine for that area since it's water cooled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 5:44pm
Thanks Pete, what thickness do you recommend?
Wonder if any of the round ones would fit. Guess I can measure once I get her apart.
gasket
