  New Posts New Posts RSS Feed - Separating a Stuck Coupler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 5:14pm
Originally posted by behindpropeller behindpropeller wrote:
Originally posted by sjpitts sjpitts wrote:
So is there anything special about these bolts? I want to replace them when I am done. They look like ordinary stainless to me. But I am not really sure if they are stainless.
Jared
WHy do you want to replace them?
to play it safe and They also need to be grade 5 or better
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 5:20pm
???? A 3/8 stainless bolt has a shear strength of around 10,000 lbs x 4 is 40,000!!! Even Billy's or Joe's engines would shear them!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 5:27pm
so your trying to say regular china junk is good enough?
sjpitts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjpitts Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 6:52pm
I just wanted to replace them because they were a bit rusty. Not too bad, but a bit.
Because they are rusty, maybe they are not stainless.
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjpitts Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 6:53pm
Ok, what does this mean? Are trying to say don't use stainless? I am sorry, I don't get the joke.
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 7:00pm
Stainless is fine....
Unless you plan on putting a carbide prop on your machine.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 7:13pm
I may see '79's point on this one..
Stainless tends to gall up and sieze a bit easier than grade 5 likes to rust.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjpitts Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 7:14pm
Thanks man for the answer on the stainless.
Next question. I think I have the side to side aligned well enough. But now it is pretty clear that the top has a larger gap than the bottom. May .006.
So I am thinking I need to raise the front of the engine. So my best guess is that I need to loosen the lock nuts, and then turn the big silver bolts clockwise just a bit. See the pictures below, I think I need to turn that bolt clockwise to raise the front. And then retighten the lock bolt.
Sound like the right plan?
Thanks again guys
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 7:28pm
Jared,
You got it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 8:10pm
Some brass nuts on your stainless bolts work good :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 10:10pm
Jared
No joke. I'd go stainless. I did with my 64.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 10:11pm
Never-seize on SS threads.
I remember when I first saw the stuff. A saleman came into the shop with a piece of SS threaded rod, smashed the threads with a hammer, put the never seize on and then ran the nut off over the damaged threads. The nut was smoking but it came off! It actually re rolled the threads!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 10:14pm
Chris,
I don't recall saying and even re read that I ever mentioned "China junk"! I hate to tell you but grade 5's and 8's are coming in from them too. I agree it is a shame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjpitts Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2010 at 10:19pm
I got it done. And I just reused the old bolts. Thanks for all the help.
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 10:39am
i would be dropping the rear mounts to close the top gap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjpitts Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 4:15pm
Why is that?   Why would you chose one or the other? I thought about lowering the back, but the front seemed a little easier to do. I guess you would have to move it less using the back. Is that it?
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 4:30pm
I'll let him answer but I'm going to venture a guess. Lowering the back lets the engine sit down farther in the bilge and closer to the stringers. Raising the front does the opposite, which could put some stress on the mounts.
I tried to lower more than raise when I did mine with that thought in mind. Not sure if I'm right but it seems to make some sense to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 4:38pm
Both are correct. Front or rear mount adjustment may be needed to keep the shaft centered in the shaft log and maintain alignment to the strut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjpitts Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 5:14pm
That makes a lot of sense. I didn't think about that.
But in that case, maybe raising the front was right for me. If you scroll up the thread and see the picture of the shaft from under the boat it looks like the shaft is "lower" rather than "higher" in the log.
But that picture is a couple of years old.
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 5:27pm
Jared,
A true drive train alignment starts at the strut and then goes forward because the strut is the fixed position. Now's the time for you to check to be sure the strut is ok and not bent. What I do and suggest, is with the coupling halves disconnected, make a wood V block to rest the forward end of the prop shaft on. Make it so you can move it around in different positions. When turning the prop shaft you should find the "sweet" spot where the shaft turns the easiest. Hopefully this is when the shaft is roughly centered in the shaft log. If it turns freely, then you know the strut position is good. Clamp off the V block to maintain the position and align the engine to it.
marcus12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcus12 Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 8:22pm
hi guys i'm in the process of trying to do an alignment myself and it looks like from the back of the engine it needs to go to the right to close the gap. I've loosened the pinch bolts on the front and back, and I can't get thr engine to budge a bit even with a hammer and crow bar. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 8:30pm
Make sure the pinch bolts are completely loose so you can move them with your hand. Put some PB Blaster on the shanks from the trunions and let it soak in real good. Then try moving it again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcus12 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 1:19am
When you say pinch bolts are completely loose, do you mean the nut on the threaded bolt? I have the nut completely off both front and rear threaded bolts "pinch bolts" like shown in eric's threadand it still won't budge. I really don't know where to get to put pressure on it either, i'm kind of scared of breaking something. Any help will be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 9:19am
Marcus,
The pinch bolts are the small fasteners that clamp (squeeze) the mount down onto the horizontal shank (round rod - not threaded). These can be stubborn as they do rust up inside. Sometimes the mount needs to be removed and loosened up on the bench or in the vise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcus12 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 12:12pm
But the pinch bolts are the threaded rods right? How do I remove then without messing up the threads?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 12:16pm
the "pinch bolts"
what i do is take the nut all the way to the end of the threads and tap it thru with my brass hammer...i think this is being overlooked. if the mount does not have a split, it is the tapered type mount, so the more you tighten the nut the tighter the trunion. you will notice on the opposite end that there are no means to hold the other end of the bolt.....this is the tapered type. if the mount is split and you see a bolt head at both ends this is the clamp type.
simply by loosening the tapered type will not move the trunion, you have to tap it out and release the taper
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcus12 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 12:52pm
Eric, the engine mount on my 85 SN has a split, so are you saying I need to tap the pinch bolt through the hole toward the bottom, or have I missed something. Sorry for the confusion I've just never done an alignment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcus12 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 1:37pm
                                                           This is a picture of what i'm looking at. What do I need to tap through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 2:07pm
Tap that threaded piece you have the nut off of. If it is the split style it sounds like it will come out all the way. Otherwise it will kind of tap toward center until it gets to the other side of the interference fit. If it doesn't move easily, do like Eric said and put a nut back on it to keep from messing up the threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2010 at 2:08pm
Please read again - slowly.
Marcus,
From your picture, it looks like you have moved the engine sideways. See the shiny spot on the round (NOT THREADED, HORIZONTAL) rod.
