  New Posts New Posts RSS Feed - Steering cable adjustment
srbranum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Topic: Steering cable adjustment
    Posted: May-22-2010 at 4:45pm
Man do I need some help(because mine is out of town this weekend)
I can't seem to figure out how to calibrate of set the steering cable in my boat(1975 Skiier). Here is a picture of underneath the dash and the rudder area. I really need some help in order to make it to Georgia next weekend. Can anybody throw me a bone.
Thanks.
Scott
I have to keep her running 'cause I can't afford a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 5:51pm
Scott,
Attach the cable to the helm but leave it off the tiller arm. Set the wheel to the neutral position by counting turns lock to lock and divide it in 2. Set the rudder in the neutral position. Attach the cable to the tiller. Tighten the cable tube block on the stringer in that position. Now, the rudder will be centered along with the wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 5:54pm
Dr. Pete,
Again, you are the man.
I am going outside and work on yours and eric's replies and let you know what happens. If I can get past these issues, I think I have her wipped.
scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 6:08pm
Scott,
Pete,
What are you calling the tiller are? Can you describe it? Sorry
scott
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 6:17pm
The arm is the bar that comes off the rudder that the cable attaches to. You need a new tube on the helm.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 6:36pm
Is there supposed to be a tube coming off that plastic nut shown in the picture? Where to I get one if that's the case?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 6:43pm
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 7:02pm
I wonder what happened to the old one? Never saw it in the boat.
Thanks,
scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 7:33pm
Scott,
It will work without the new tube on the helm. The cover keeps the dirt out/off the free end of the cable. Get the new cover on there pretty soon. You may also want to do some cleaning/greasing up there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 7:45pm
I think I got it.
Re: The missing tube. That would explain why the cable curls up in to the wiring and getting grease all over it.
Also, Does 3 3/4 turns divided by 2 sound about right? The back of the cable is almost if not touching the rear of the boat. Can I adjust it out any away from the stern?
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 7:49pm
Scott,
This is what I did btw, correct or not:
I disconnected the cable from that white, ceramic looking bracket running off the primary stringer in the back.
Turned the steering wheel lock to lock and divided it by two.
Reattached the cable to the ceramic bracket.
Tightened the cable nut underneath the dash.
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2010 at 10:14pm
Sounds good Scott! Georgia next weekend just ahead!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 12:48am
Pete,
I hope I get to go. The last few things I have to do are:
Put carpet in
Install the seats
Install the engine cover.
Install the battery box and cover
Tighten every nut and bolt
Epoxy the depth sounder transducer
Hook up the hoses and fuel line
Install the rear floor and access plate
Try and clear off old wood flour/resin stuff I was stupid
However,
I am still stumped on this bilge pump deal. I have attempted everything ya'll said and was resolved to just bypass the float switch until I could figure it out. Now, I can't even get the bilge switch to come on.
There are three wires that come off the bilge switch behind the dash:
1. One on the positive side leading to the bilge pump area
2. One on the negitive side also leading to the bilge pump area and
3. One on the positive side leading to the fuse link directly above 1 and 2 above.
The question I have about the above information is...where does the bilgepump switch get its power?
Further, before I started the rebuild project, I cut four wires that had to do with the float switch and bilge pump and wrote down where they went. Two from the float switch and two from the bilge pump. BUT......those four wires lead to only three from the dash area and they were connected to:
a. One side of the bilge pump switch
b. The other side of the bilge pump switch and
c. The middle lower post of the AMP meter.
This is kind of wordy but I thought you could use your infinite knowledge and figure me out a battle plan, I hope. I can't put it in the water here or anywhere without this matter resolved.
Scott
