  New Posts New Posts RSS Feed - 79 Nautique rebuild?
 Post Reply Post Reply Page    <1 3456>
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2010 at 3:39pm
It's coming along nicely. I did the same thing with the foam I was doing, using the measuring cups and having them marked.
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 1:36am
I got some time in on the boat yesterday. While watching the bilge paint dry I thought I would clean up the rudder port and get it ready for reassembly after scraping and wire brushing the sealant off of the parts.
I saw a washer sitting in the driveway. It is the one in the last picture in the center. My guess is it would go on the rudder shaft between the packing nut and the steering arm. It may have been stuck to the packing nut and came off when I was cleaning it. If anybody knows please help.
Thanks, Monty
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 1:43am
check on top of packing nut between nut and tiller arm I believe
Brian
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 8:37am
Not much left to do now Monty,looking great, that washer may fit inside the packing nut ontop of the packing.
Roger.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 8:28pm
it goes between port assy and tiller arm..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 8:43pm
Thanks Everyone. Now if this paint will ever dry. Fas drying my ass its been two days and still tacky.
I may be in contention for the longest ever stringer job!!!
           Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 9:28pm
           Monty
I'm way ahead on that
Roger.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2010 at 2:05am
Well after the trip to Green Lake and Pete's Excellent Alignment 101 class. I decided to tackle the strut alignment. The first picture shows where the shaft was in the bottom corner of the log to turn freely. I dropped the strut and shimmed with stainless steel washers. After dry fitting it the shaft was centered in the log so it got 5200 and tightened.
Here is my old log hose next to the new one.
Cleaned up the Rudder
And got it mounted with new gortex also ran new speedo tubing
Now I am getting ready to start on the carpet. I was thinking of doing the sides first then the floor. Any Suggestions? Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2010 at 8:58am
Monty,
Look'n good
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2010 at 9:54am
Monty,your on the last leg of the rebuild,time to look out for another CC, I'm sure the the other half won't mind.
It was great to meet you both at GL
Roger.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2010 at 2:15pm
Looks Good I know you are excited.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2010 at 4:57pm
I need some help.
I am trying to hook up my new steering cable at the helm and can't remember if the cable attaches to the top connection and the plastic tube to the bottom or vice versa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2010 at 6:21pm
I need some help.
Put your "thinking cap" on!! Do you what it to pull or push on the rudder tiller arm when turning???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2010 at 6:53pm
Thanks
Thats what I did after asking the question.
Should the steering cable be secured to the stringer or lay in the bilge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2010 at 7:33pm
Monty,
They just lay in the bilge.
Bigdaddyriverrat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigdaddyriverrat Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 7:05pm
Man you guys amaze me, I hope I can do one tenth of the job some of ya'll do.
Earl M
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2010 at 2:30am
Thanks, I wouldn't have known where to even start without this website and the fantastic people on it.
I just about have the boat ready for the engine. Still have to pack and place the shaft. I was cleaning up engine and ran across this on inlet hose. My plan is to wrap 1 1/4" hose around the bell housing (for future strainer) to the transmission cooler. From the transmission cooler 1 1/4" to raw water pump 1" lies my problem. Picture shows what P. O. did. What would be the right way for this?   Thanks, Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2010 at 11:41am
You should be able to find a better looking 1-1/4" to 1" adapter at home depot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2010 at 11:13pm
Thank Tim Lowe's .91 with my sons discount. Waiting on hoses.
I checked the impeller and its a good thing.
Luckily there was a new one in the box of parts that came with the boat.
I put some paint on the engine and set her back in.
It was a giant relief when I got it in and the couplers were lined nice and close.
I am currently injecting cpes in lag holes then 5200.
Then I will dial in the alignment.
My question of the day is.
Is there supposed to be a gasket for the thermostat housing?
It has three bolts holding it on and looked like it had rtv sealant on it before.
But it was loose when I got it. T-sat goes in spring side down is that right?
connorssons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 12:04pm
Yes on both questions! boat looks great,you have an eye for detail. nice job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 6:49pm
Great work Monty, your almost ready now
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 9:02pm
Thanks Guys!
Roger sure enjoyed the beers in the evenings at Green Lake.
Glad to hear your engine parts made it back in your luggage.
That might have been hard to claim if they lost your suitcase.
Does anybody have any ideas where I can get a gasket for this thermostat housing????     1979 commander 351
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 9:15pm
Monty,
It's probably easier to just go and buy some sheet gasket and cut it yourself. I had LOTS of experience with doing that on my Flexifour rebuild!! Keep it on the thin side - 1/64".
BTW, I'm impressed with your rebuild/stinger job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 9:32pm
Thanks, Pete
I'll go to Autozone and try and get some gasket material and silicone it down. HA HA HA
I thought thats what I may have to do when I couldn't find a match on any of the popular sites. Glad you told what thickness to look for. Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2010 at 12:44am
Still waiting on my new water hose from g2marine. So I put the old ones back on,put some gas in and hooked the garden hose up. The only way it would run was a little gas straight down her throat. Had gas to and in the carburetor but wouldn't run. Never been inside a Holley before but found a parts diagram and how to so I went for it. Inside was a lot cleaner than the outside and looked like new parts were inside. However the Metering body vent baffle was laying at the bottom of the bowl. I also noticed that the pump discharge nozzle was plugged when running a stripped bread tie wire through it. Put it back together and she fired up! Yeah!!!
Now I am trying to track down a dwell meter and timing light (never used one but seems easy enough) and set timing.
Does anybody know off the top of their head what dwell setting and timing setting for my 351?   Thanks, Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2011 at 12:02am
After a long cold winter I got the boat registered and headed for the lake. After purchasing a new set of trailer tires finally made it to the ramp. Was pleased with the way it ran but needed work at idling in gear.My plan was to get a idea of how she ran before I messed with trying to change the distributor. I had bought a new distributor on eBay but it had the wrong gear on it. Pulled old and took them to a machine shop to have my gear pressed on new dist. When he was tapping the roll pin back in the top of my gear cracked off.So I Bought the electronic one Jody had for sale.
Question 1. Will I need to change coil going to electronic ignition?
          2. I don't have a ballast resistor now. Will I need one?
Been working on putting a stereo in the boat Since the previous owner cut a hole in the dash. The old stereo that was in the boat was ruined by water. I don't want that to happen to the new one. I bought a splash proof cover for radio but the hole was cut so high in the dash it wont fit because of the q in the ski nautique emblem and also the dash has a angle right there. Any ideas????
I am making a bulkhead to fit on top of the airbox for front speaker and to help keep boating gear up front. I made a cardboard template and cut out of plywood. cpes and some epoxy and tape.I Will carpet it next.
Once again I want to thank everyone for all help and great ideas that come from this site. Monty
WOFTAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WOFTAM Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2011 at 10:44pm
Hi Monty-
I am deep into the re-stringing. All of the stringers are bedded and tabbed. I originally planned on a glass over foam floor but see that you went with wood. Was glass ever an option for your floor? Were there any gaps between the stringer tops and the bottom of the floor? If so, how large were they?
Man, I hope I can use this boat this summer!
Just because you can does not mean you should.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2011 at 11:07pm
Mike I had never planned on going back with foam so glass over foam was never really in the picture for me. Well I did use foam for the air box and actually reglassed some of the original back down. I also foamed around the battery box but it has plywood floor. While replacing the stringers I had planned fol a plywood floor and tried to make it level across. What gaps I ended up having I used Biax cut to strips and epoxied to the tops of the stringer. Then used thickened epoxy along the stringers to bed the floor down. One thing I think Roger UK79 suggested was attach scraps to the bottom of the floor where the seat bases screw down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WOFTAM Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2011 at 1:06am
Hey Monty-
Thanks for the reply. Do you have any pics of the layout of the plywood in the boat. I am really leaning to the plywood instead of the glass, but do plan on re-foaming. I am specifically interested to see how you tabbed the ply in and how you did the port and starboard aft sides .
Thanks again. I started laying biax last night over the primaries and around the secondaries tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2011 at 6:14pm
Great work Monty, good here your back on the water, post a picture of her on the water for us to enjoy
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
