1978 351 w rr |
rstuart
Groupie Joined: May-18-2010 Location: Tenn Status: Offline Points: 42 |
Posted: May-21-2010 at 1:41am |
could anyone tell me or post a pic. of the proper engine and manifolds color.
horkn
Well, my 78 PCM 351w motor was dark ford blue, everything but the exhaust manifolds were this color. The manifolds are a nasty green color.
I painted my manifolds black because they were hideous in the stock color, and my performer intake is now Silver, with black GT40P heads. Here is the motor before , basically as it came from the factory. |
rstuart
thank you tom i've been wondering about that green but i guess i'll try to match it as best i can in a high heat i'm shooting to get my boat as close as i can 78 cc southwind20
draire
Newbie Joined: June-07-2010 Location: ann arbor, Mich Status: Offline Points: 4 |
Off topic
I am a new owner of a 1978 Ski Tique. Am in need of a wiring schematic for the ignition switch. Also, am not getting any electrical to the Plugs. Have had the Coil tested and it meets specs. Definitely have battery voltage. Any suggestions what my problem might be? |
Drairedavid
David,
Are you getting power to the coil with the ignition switch in the crank and run position? If you have a point set (no conversion), pull a file through the contacts to clean them up. A finger nail file will work great. Here's the wiring diagram out of the CCfan reference section. Do some browsing - it's got lots of info in it. Tell us more about the boat and welcome to CCfan. Any pictures? |
draire
Thanks a million for the Schematic. Took only a couple of minutes to get everything wired up properly once I had that.
One thing I note is that it takes a few minutes to warm up the engine; otherwise, when I apply full throttle it wants to die. So, I must pump the throttle a few times to keep from stalling. Once warmed up I have no more problems. I will post pictures soon. Have a great 4th! David |
Drairedavid
