  New Posts New Posts RSS Feed - antisiphon valve
antisiphon valve
malibud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Topic: antisiphon valve
    Posted: July-02-2010 at 12:32pm
I thought that my lack of rpms (4000@wot) might be a fuel problem and I am trying to get the antiphon valve off . Do I have to take the tanks out ? is in the elbow? where exactly is it ? I took the elbow off and it is connected to a pick up stick.
thanks for the help I am kinda stuck right now and don't want to go too far since i wannna hit the lake today
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2010 at 12:51pm
Dan,
Unless someone has removed the anti, it's the fitting between the 90 on the tank and the fuel supply hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2010 at 1:07pm
Big thanks again .. glad i did not take the tank out. now that it is out does the valve come apart ? My plan was to soak it it in some carb cleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2010 at 1:13pm
It looks like a ball valve how do you clean it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2010 at 1:19pm
That depends on how old it is and who's manufacture it is. Most will have the ball check pressed into the fitting especially the ones with the integrated hose barb. Take it off the hose, soak it and blow some compressed air through it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2010 at 1:39pm
thanks figured it out it has check valve w/ a spring
