  New Posts New Posts RSS Feed - Help with tune up !
Help with tune up !
dans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dans Quote  Post ReplyReply Direct Link To This Post Topic: Help with tune up !
    Posted: March-23-2006 at 6:36am
Just got a 1982 sn 2001 w/ ford 351 and velvet drive tranny. My manual is newer (1989) - What kind of autolite plugs go in a 1982(14 or 18mm ?) Do I have a water stainer sceen & a tranny screen to clean ? Can't find it.( maybe not on the 1982). If someone knows exact part # or name for autolite or motocraft plugs that would be great , then I can go to autostore here . Thank You !! P.s I think I have the 240 hp 351. Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-23-2006 at 8:06am
autolite 24 for the plugs, you may or maynot have a strainer, if not then get one and install it yourself. If you do it will be inline with the pickup hose and before the tranny cooler.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: March-23-2006 at 8:31am
The tranny screen is just inside the inlet of the transmission cooler.
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: March-23-2006 at 7:40pm
    When I change the trans oil, I take 5 minutes and seperate the shaft from the trans (4 bolts) which allows me to run the boat "in gear" to help mix things up before I dump the oil. I cant say how much actual benefit there is to this, but it seems to get the gray clutch material out better.
                                    Jeff...
tcarden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tcarden Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2006 at 10:02am
Congratulations Dan! I just bought an 82 Sn also. Go online to www.skidim.com. They have everything you'll need and great advice and service too. I ordered a new strainer for mine, It didn't have one either, for $39 bucks. Good insurance I think.
