  New Posts New Posts RSS Feed - Difference in Auto and Man Bilge
Floatmyboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Floatmyboat Quote  Post ReplyReply Direct Link To This Post Topic: Difference in Auto and Man Bilge
    Posted: March-24-2006 at 8:15pm
I have a 89 2001 and on the Dash there are two buttons for a bilge one says Auto and the other one says Manual Just Curious on the difference
75% of the earth is water
Spend 3/4 of your time on the Water
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2006 at 8:27pm
Your bilge pump should have a float switch next to it.. In the manual mode it is simple pump on or off, used for emptying water while the boat is occupied. The auto mode is for pumping out the boat when it is not being attended to, like an overnite tie up or folks that leave their boat in the water all the time. In auto mode the pump will kick on when the water level inthe bilge raises the float switch high enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Floatmyboat Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2006 at 8:29pm
Thanks Does the ignition button need to be on for the auto bilge to work
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2006 at 8:44pm
It does not, at least on my boat.
Bob Ed
83 2001
tonydjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonydjd Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2006 at 5:38am
Usaually the ignition does not need to be on if the switch was wired correctly easiest way to find out use a test light or better yet open dog gog house lift float switch by hand you should hear the bilge kick in if the switch is on auto and wired correctly
