  New Posts New Posts RSS Feed - Skegs a little bent
Skegs a little bent
marmon77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marmon77 Quote  Post ReplyReply Direct Link To This Post Topic: Skegs a little bent
    Posted: October-08-2010 at 11:45am
I was looking under my boat yesterday (87 SN 2001) and noticed that the first skeg (fin) in the front was a little off center. Can i just apply a little pressure to it to put it back in line?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 12:28pm
I probably wouldnt.. it is just screwed in and even if you didnt crack the gelcoat or glass in that area you would probably work the screws loose and open yourself up for some water intrusion or worse. Take it off take it to guy with a press (local machine shop or prop shop) have him straighten it out then reinstall...
michiel200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michiel200 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 5:17pm
I understood the fins are glued as well.
Tried to take one off, but didn't came loose after removing the screws.
'92 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 5:40pm
How bad? Post a pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 5:45pm
Not glued but a pretty good bond if a decent sealer was used. If you do remove them, I suggest putting them back on wth 3M 5200 or at least 4200.
From another thread on a strut but the same senerio:
Originally posted by AZ64-X55 AZ64-X55 wrote:
A freind of mine has been having trouble removing the strut, being set up in the hull, as the picture shows!
any suggestions on removal?
Hot air gun on the strut and dead blow hammer. If that doesn't work, it can be hot wired off. It's just a PITA getting the wire started between the strut and the hull when they are set in the recess.
