1969 Mustang Stringer Rebuild |
Post Reply | Page <1 1112131415> |
vondy
vondy
Hoping to get US Composites and my CPES ordered today. Not sure about several things. Looking for some advice.
1. How much Cabosil? Seems like those who have ordered the 10lb bags don’t use very much of it. Should I go for less? http://www.uscomposites.com/fillers.html 2. Do I need any other filler/thickener besides the Cabosil? I see others use milled fiber. 3. Here’s what I am understanding as far as the layup goes. a. CPES the stringers/wood. b. ???Do I wrap with fiberglass before embedding or embed straight CPES coated stringers to hull??? c. Bed stringers down in thickened epoxy. d. Filet with thickened epoxy. e. Down the length of the stringers from the stringer to the hull, glass 2 inch tape followed by 4 inch then 8 inch. Then 12 inch biax followed by capping with 12 inch biax. ???One layer each??? f. Same with ribs. Maybe no biax? g. CPES floor. Do I glass as well? h. Bed floor to stringers with thickened epoxy. i. Glass floor to sides of hull. In layers? j. Glue down vinyl floor. 4. On the plywood floor, if I am to glass it, do I use cloth and how much and what thickness? 5. Are most people getting their CPES from Jamestown? Smiths Warm CPES Epoxy 2 gal kit enough? Sorry for the bombardment of questions. This whole thing is mind boggling the first time around. I know I’ll also need brushes, etc. If you see anything I need to add, change, remove, please let me know. As always, many thanks! |
Keeganino
Sorry to misquote you there Tim. I did most of my glassing in the middle of the summer so I was using less hardener than called for and ended up with about a pint left over.
1973 Skier |
No, I would do it again- we did a good amount of glassing in cooler temperatures (winter/spring in New England) so the Fast Cure sped up the process somewhat. If youre going to be working in more moderate temps, the Medium cure (3:1) works great. |
Keeganino
Edit on my post above I used 10 gallons of medium cure epoxy, and I used every last bit. Sorry about that and good eye Mike. You will be fine pulling both secondaries as Critter mentioned. I think I read Tim saying that he would probably not get the fast cure epoxy again. Cheaper to get the 10 gallons all at once.
1973 Skier |
critter
IMO, you can remove both Secondarys with no issues as long as you have
the boat supported well at the front chine area and stern. I think that I remember removing both secondarys at the same time. |
1980 Ski Nautique
1966 Barracuda |
vondy
Thanks guys! I'm going to be on a question role here for the next two days so please bear with me.
Back to the US Composites order later. As for stringer removal. It's in the 50's today and I would like to take advantage of the cooler weather to do some more grinding. Should I remove the port secondary. This way I'll have both secondaries removed and then bedded in before the primaries are removed. Then I'll do the primaries one at a time. This makes sense to me but being that I have not done this before I may be missing something that could mess me up down the line. |
WakeSlayer
Keegan, you mean a 5 gallon kit, I assume. Even so, I have a good dent in my second 5 gallon kit on the 18ft SN, and still have the floor and little stuff to do.
Mike N
1968 Mustang |
Keeganino
Your grinding looks good. I would not go any further. I did one side at a time so I could make sure everything was level and lined up. Makes it a lot easier to mark your engine mount locations. Nice stringer out in one piece! Wish I had had one like that for a template.
Seems like the only receipt I dont have is from USC!? But here is what I found in my notes: Mains take 16 linear yards per layer for both stringers Secondaries take 14.3 linear yards per layer for both stringers FLoor to hull and bilge is 21 Linear yards per layer I used a gallon medium cure time epoxy kit and cabosil as a filler. Probably only need like 2 lbs of that. I got 10 lbs and barely made a dent in it. I got the 95 yard roll of biax and used a little more than half. Here is Tim's order for the BFN which was about the same as I ordered except for all the 50" cloth. Only got a fraction of that. |
1973 Skier |
vondy
The grinding has begun. Wow, let me tell you how much fun that is... living the dream
The starboard secondary is out. I actually feel bad taking it out because it was in there so good. No rot either, other than where the screw holes were for the cross bracing. It wasn't bonded to the hull quite as well at the stern but the rest was stuck like new. Now that I have the feel for grinding I want to make sure I'm going deep enough, and not too deep. I've been stopping when I get down to the cloth area, removing the thickened mat. I'm assuming the thick gray area should go as well. I thought about bedding the stringers one at a time, using the adjoining one as a guide and clamping block. It will prolong my grinding time but make the installation easier I guess. Thoughts? No more grinding for the day, off to a wedding. |
Thanks, Pete. That would be my dream job, as long as I didn't have to make money at it as that takes the fun out of it. That boat is almost done. I got to get that steering wheel off and paint it and the helm.
The white dot flooring cost around $90 and they sent me enough to do 2 or 3 boats. |
Bruce,
That boat is nothing but I think you should get out of the appraiser business and let your sons (and yourself) do boats!!! |
We used white dot flooring from Gary's which has a similar look as a floor plan. I like the looks of it, but it is hard to keep clean. I'd go with the sharkskin Nautolex next time.
David,
I, like Tim am sorry to hear about the glass floor pan. They were very unique to the stangs. How much of it is actually left? Restoring it takes lots of work but it can be done by someone that is advanced in glass repair. DO NOT throw it out!!! Yes, I feel your choice of doing the Nautilux floor is a good choice - still original!! Go for it! |
vondy
Keeganino, do you have a shopping list from your US Composites order? Working on mine and would like to compare. Your boat is about the same as mine, although you have much more going on with your secondarys.
vondy
It's beyond rough, two sections are already gone. Now that I am thinking about it, I'll still need to do some notching around the pylon area. |
I think even a rough looking floorpan is better than ditching it altogether.
I think we bought some extra 2x doug fir for the ribs. |
vondy
Yes I do have the floor pan. It's in pretty bad shape though. Cracks everywhere, the pylon area was separated and glued to the floor when I got it and the removable section behind the engine was very flimsy. I put some ply in that area, painted white, to get me through the last two years. The ribs sound good. I would love to skip the notching. What species would you use for them? |
WakeSlayer
I wish I would have done ribs on the SN, but I already cut the notches. And, yes, what a pain in the ass to work around them....
Mike N
1968 Mustang |
On my Skier, we're not refoaming. Instead of those "straps" that sit in notches cut in the main and secondary stringers, we're going to put in a few ribs running between the secondary and side of the hull- at least at the seems of the plywood floor pieces. Cutting and cutting around those notches in the stringers is a pain. Those ribs, plus glassing the floor to the walls should provide plenty of support. I think we're going to use 5/8" ply.
WakeSlayer
I think you still want the longitudinal stringers. You need some support outward on the floor.
Mike N
1968 Mustang |
Keegan, how hard did you look? Lots of places sell the Nautolex.
You can find a piece big enough to do the floor and panels on ebay for ~$200. Vondy, refresh my memory- do you not have the fiberglass floor pan? |
Keeganino
The samples I got were real nice. I was running out of money at that point in the game and the carpet was a lot cheaper.
1973 Skier |
vondy
Thinking about it. |
Keeganino
It looks like a lot of space till you start putting it back together. I think I asked the same question, but at putback time there is not really a big enough space to make a nice chest or locker once the battery box and conduit are in. Are you ordering the nautolex vinyl from Garys for the floor? I might spring for it after the carpet is worn out.
1973 Skier |
vondy
Thanks for all the advice on the engine paint. I'm actually looking forward to messing with that. The stringers are scaring me
Talked to Eric about the trans today and hopefully will be mailing off tomorrow. What do you guys think about the structure? My plan is to go with 3/4 ply for the floor and vinyl on top of that, no carpet for me. Should I keep the structure just like it is? As small as the boat is I would imagine 3/4 ply would not need any extra bracing. I don't even think you would need the cross bracing that is in there now since the floor would tie the stringers together. Except maybe under the removable panel. I'm also thinking of relocating the battery to the center as far forward as I can like others have done. Curious if anyone has attempted to put a built in ice chest in this area. There's a lot of open space under there. |
David,
The self etch is fine for all metals so you can use it for the cast iron too. I do recommend priming the whole engine. On my last project (1927 universal) priming made a big difference. I first prepainted some items that would be hard to paint completely after assembly. These I did not prime and it took several coats (3 to 4) of the Duplicolor engine paint to cover the high spots in the rough castings. Then, I went and got a can of Duplicolor engine primer and used it on the complete engine. I found the finish with the engine paint with primer to be lots better plus it covered with one coat. |
Keeganino
They consistently take a week to deliver. I also used the duplicolor primer. Not sure about using it on the non aluminum parts. I think anything that is bare metal should get primed. Pete will know better.
1973 Skier |
vondy
Thanks Pete. Since I'm applying primer to the aluminum, should I go ahead and apply to the rest of the engine as well?
Picking up the Fir today. Hopefully this weekend I can get some cutting and grinding done. Need to finalize my US Composites list as well so I can get that ordered. How long has it been taking you guys to get your orders in from them? |
David, I use the Duplicolor self etch and found it to be a good product. I also wipe down aluminum with a weak acid. In my case, I use liquid soldering flux just because I always have a pint on hand. Some will use vinegar but I do not feel it's strong enough. |
