1969 Mustang Stringer Rebuild |
Post Reply | Page <1 56789 15> |
TX Wind
Senior Member Joined: March-29-2011 Location: near Dallas Status: Offline Points: 333 |
Excellent point on the kinking Tim. The silicone kinks very easily by the way. If he uses copper, he could braze a 45 in there easy enough or even a 22 1/2 or 30 if necessary. Shhhhh....I thought there was a rule on here against advocating for mufflers....especially on a boat that didn't come with them. |
The manifolds exit slightly less than vertically (towards the front due to the engine angle) so he's need a 90 in there if he were to use soft walled hose. We got the corrugated over the copper on my sister's Stang though- just takes a little muscle. |
vondy
Looks like another project to add to the list.
Thanks for the recommendations, Jeff thanks for your references. I'll have more questions once I actually dig into this part. |
"No worries on the muffler comments... my track record speaks for itself". Big talk from you guys who have never spent some time in a HM powered boat When your sittin on the doc with blood dripping out your ears,then I'll listen to you. Won't hear you but I'll pretend I do. Ask John or Eddie how mine sounds with mufflers |
vondy
I have to second Gary, this thing is pretty loud with what its got. I assume they are glasspacks.
TX Wind
Well...If you really wanted to keep the mufflers, you could put a slight angle to the floor under the seat and then pull it out with the seat base. Getting some glass over the stringers should move you a bit closer to the edge of the seat before it hits the mufflers. It might not be that bad in the end.
TX Wind
I have tremendous respect for what you do and what you know Tim. That BFN is the bomb. Didn't this boat come with corrugated anyway? |
Vondy's? Very possibly. My '71 Skier still has the original corrugated hose on it. I would have expected a '69 H-M to have some copper in the exhaust as well. Gary, I havent spent a *ton* of time in H-M boats, but Ive spent some. A lot of time spent listening from shore, too- there was a '70 H-M on our lake that had to have 10,000 hrs on it. It was *almost* the loudest ski boat Ive experienced... Id say Reid's '73 takes the cake, but my sister's Stang with the aluminum Interceptor logs exiting to 3" out the back with a healthy stretch of copper is pretty close too. My '90 isnt exactly quiet either: ^^This one will get mufflers before long though^^. Im curious to hear how loud the BFN will be with aluminum manifolds and 4" all the way back- Im hoping its bearable. |
WakeSlayer
Reid's Skier is freaking awesome.
Mike N
1968 Mustang |
81nautique
I bought some used mufflers for my 81, currently aluminum edelbrocks to stainless out the back. When I fired it up in the driveway this weekend I put the mufflers back in the garage...I just can't put them on yet!!
[QUOTE=TRBenj] I would have expected a '69 H-M to have some copper in the exhaust as well.
QUOTE] Mine just had molded 90's at the manifolds and straight hose out the rest of the way |
Good info, Gary. Im curious what years CC was putting copper in the exhausts- my sister's boat didnt have any copper either, just 2-1/4" hose. With all the volume the H-M's put out, I would have thought there was some metal in the exhaust... I guess the 3" and aluminum manifolds are enough! That also explains why it seems like her '69 is so loud now. |
If they were using copper, I would guess it was early 60's and earlier. Has anyone ever seen copper piping that was original?
CC used it in the 70's from what I understand. Tom Lawton had copper pipes in his '76 Ski Tique. |
Bruce, Yes, I have and feel it was the mid 60's when they were switching over to all rubber. |
MAN - GA
Senior Member Joined: July-09-2009 Location: Cumming, GA Status: Offline Points: 298 |
For what its worth my 75 Mustang has 3" copper tubes and it sounds great - just curious if log or riser style is louder?
I dont believe the manifold style (log vs. pyramid) makes much difference in volume- but the manifold material does seem to have an effect. Aluminum or SS manifolds tend to be louder than cast iron. |
I wonder why they would have used copper pipe in the later years as the rubber hose was better quality than in the earlier years? Maybe the gear head factor at the factory at the time? I think the next engine I put in a boat is going to have copper tubes rather than straight rubber, just for the extra noise.
Bruce, maybe it was a cost saving measure? Obviously not the case now, but at one point, was copper pipe cheaper than hose?
Brady
Senior Member Joined: June-28-2008 Location: Lake Elmo, Mn. Status: Offline Points: 226 |
Copper is a commodity and the price varies widely, altho rite now it is as high as I have ever seen it.
Charlie
Three Lakes, Wisconsin 69 Barracuda |
Rubber's way up there now too due to the oil in it. I just had to buy a new set of E tires for the truck since the fronts looked more like "slicks"!! |
Keeganino
My 73 Skier has copper pipes and I love the sound tone.
1973 Skier |
vondy
Update. Have one last stringer ready to bed this week. Taking an extra day off this weekend so I'll have 4 straight days of working on this crazy project. My goal is to have the entire floor down. Minus the vinyl, still have to order that.
2 questions... Is the goal to get all the glass on the stringers in one sitting? While it's green? Biax wrap and all? And where are you guys getting your bilge paint? Thanks! I'll post some pics soon. |
WakeSlayer
I guess that is a goal, but it is pretty tough to do in practice, in my opinion. Perhaps if you just do one stringer at a time, but if you are trying to do both at once, or all four, you are going to have a really tough time. Take your time and do it right. You will have bubbles to roll out, epoxy to mix, glass to cut, and patience to run out of. I think I was able to get all the thin stuff in one shot, and then did the biax the next night.
BilgeKote is available from Jamestown, USC, and West. I think I only bought a quart, did two coats, and have some left still. Nasty crap, do it outside or with the door open at least. I used white. Looks great til you get a motor running in there and bilge water, etc. I would use gray next time. |
Mike N
1968 Mustang |
2 stringers at a time (primaries/secondaries) is much more doable than 4. Even if all your glass is precut, it will still wear you out. Build yourself a platform to hold everything (glass/resin) so youre not constantly in and out of the boat, and you wont wear out as quickly.
Id pass on the bilgekote. Several of us have had problems getting it to stick to the directly to the epoxy. When I called their tech service they told me that it needed a primer when used over it... I guess they dont consider epoxy to be a type of fiberglass, wtf. Stripping all the uncured paint out of our bilge was a nightmare. If youve got all of the gel ground out of the bilge, either tinted epoxy or gelcoat would be my recommendation- thats all Ill use from here on out. |
Keeganino
I was one of those who had problems with the bilgekote. It never set properly even after 2 full days in the direct sun in the middle of July. I second Mike's advice- don't use white! I like the tinted epoxy idea and will be inclined to go that route on my next one if Tim is still happy with it after the boat is on the water.
1973 Skier |
vondy
Yeah I guess that was my plan, two stringers at a time.
So what's the process on using tinted epoxy for the bilge? What do you tint it with? Do you just brush it on like paint? Thicken it at all? Wonder if I'll have enough left over.... Thanks! |
David,
The tints are available from US Composites (didn't you get your supplies from them? or where ever you got the resin. It brushes or rolls on just like regular epoxy. |
vondy
Thanks Pete. That seams easy enough.
I would really love white but I know I would regret it as soon as the first drop of oil hit. Will probably go with gray, although blue might be an option. On a side note, is this a voltage regulator? Apparently I had part of a zip tie fall behind it and melt to the exposed coils. When I pulled it off it took the coil with it. So I guess I need a new one. |
David,
Yes, that's the voltage regulator. Go to a decent auto supply (not Autozone! ) and se what luck you have with them having/finding one. Unfortunately with the advent of internally regulated alternators, these old ones can be hard to find. Some of the real old ones are going for their weight close to gold!!! |
