Mounting Radio Under Dash |
Keith
Admin Group Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
Posted: June-07-2006 at 12:55pm |
My '86 Silver Nautique came with a AM/FM CD radio mounted on top of the dash in a waterproof radio box. It's really an eye sore for me. I'll pull it out but the speakers are installed in the gunnel and it would be strange to have speakers with no radio.
Anyway, I want to mount the radio under the dash. I'm looking for a bracket that would allow me to mount it to the back side of dash but hang down below the dash for diver access. Any ideas? Thanks, Keith |
Tim D
I built a box and put one of those plastic covers on the front to protect the cd player. I put a toggle kill switch on the side to cut it off instead of having to open the plastic door. It's held up with two L shaped brackets on the front and the rear is held up with pipe strapping, that long flexible metal with a bunch of holes in it.
Tim D
77stang
Senior Member Joined: May-19-2004 Location: United States Status: Offline Points: 342 |
are you intending to keep the water proof box? it looks like the brackets currently on the box would certainly make the application easier in that you might be able to produce a bracket under the dash which would mount right up with the bracket on the box.
Keith
Yes, I figured I would use the box which is very similar to what 79nautique referenced.
Nautique2001
Keith,
I surfed over to the2001.com. Look where this guy mounted his stereo. |
Tim D
The enclosure 79 is talking about is nice, I looked at those but it would hang too low for me when mounted upside down under the dash. I need to keep the skin on my shins.
Tim D
77stang
Skinning myself is why i choose not to go under the dash.
man, with that raised instrument panel it sure lends difficulty of what it was thinking, which was basically to grab some 1/4" by 4" aluminum and come down with it behind the dash to meet up with the bracket on the box. i like the mount in the pick above, just dont know if iut fits your instrument panel. by the way, if i didnt have so much tied up in my old boat i'd be headed your way in a instant. i really like you silver nautique |
Keith
I just spoke with Bruce at MWCC. They do sell the lockable glove box that came in the 87 Ski Nautique (replaces the 'tray' on the 82-86). It has a slot for a radio. The problem is it wouldn't be orginial to the '86 and I would need to cut away more of the dash. It would look clean though.
I've also seen some mount them on the underside of the observers seat facing the driver, or on the side under the seat.
wesman
Groupie Joined: April-14-2005 Location: United States Status: Offline Points: 42 |
Keith, I have a 1984 SN and was wondering what "tray" you were referring to. I don't recall anything on the dash panel that resembles a tray, or something that can be modified into the locking glove box. I too am struggling with the thought of installing a stereo, but the "where?" question has kept me from moving forward with it.
Wesman
Keith
wesman,
The 'tray' is to the left (observer's side) of the mirror in the top of the dash. You can see it in this photo of my boat The 1987 - 199X version of the lockable glove box can be seen in this brochure page for the 1989 Barefoot Nautique and also in this photo of an 1987 Barefoot Nautique -Keith |
NAUTI84
Senior Member Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
Keith / Wesman
My 84 didn't have the tray either. (I had thought about adding a glovebox there though.) I bought an enclosure that has a clear curved splash cover on the face. It slides open when you push a button. I mounted this in the center of the dash, right below the emblem that's behind the corner of the observers seat. There's still enough room to reach behind the seat to work stereo or flip seat forward for better access. Not original but looks decent. |
dans
Senior Member Joined: March-23-2006 Location: United States Status: Offline Points: 187 |
I used the metal thing from my car stereo that the cd player slides into. I screwed that with two screws to the wood up under the dash were the horn is but close to drivers side (looks like a 2x4) . Then slid stereo into it . Works great & you can slide it out if you need to. After a few trips out you can control it without looking while driving. 82 2001
wesman
Keith/NAUTI84,
I don't think the 84 models came with the tray on the dash, so I was wondering, could we buy the lockable glove box and cut out a hole on the top of the dash where the tray is on the later models? It might be a kindof sortof stock way to install the radio even though it wasn't available for my year model. It gives me the heebie jeebies to think about cutting a large hole in my dash! |
Wesman
Keith
MWCC has the 1987 lockable glove box for $96. It is bigger than the 'tray' so even for those of us with the tray, we'd have to cut the dash a little (no turning back).
I guess it is about as stock as you can get for installing a radio. I'm still thinking it over. I might just do it. After all, my pylon is already from a 1987. -Keith |
Make it look like it was installed by the factory and no one is going to know the difference, well most, and you can always say It's a special trim piece only available on the Silver Nautique speciel edition model
Furno
Groupie Joined: June-13-2005 Location: Clarkston, Mi Status: Offline Points: 49 |
My 83 2001 does not have a tray or glove box. For those that have one, it looks like a good place to put a radio. I've been wondering where to put one also. If I wanted to install one, does it require additional bracing or reinforcement?
Andy
'83 2001 |
Keith
All,
After visiting the Green Lake Reunion and seeing how the newer boats have their radios mounted I got an idea. Up under the dash on the my '86 Nautique, close to where the steering cable tube extends, the gunnel continues for about 8". Careful to not obstruct the steering cable tube extension, I mounted a piece of 3/4" x 4" x 10" piece of PT vertically so that the opposite end just rests against the carpet on the inside of the hull. I then drilled new holes in my radio case mounting bracket so that the mounting bracket would attach flush to the case. Mounting the bracket to the vertical piece of wood I now have a radio that is vertically mounted, flush with the dash. It's easily accessible by the driver but also out of the way. Now I just need to add some gray carpet to the piece of PT and I'm ready to go. -Keith View from under the dash |
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13520 |
Thinking about painting the case gray too? Install looks great, gray might make it blend even better though.
Tim D
Just like the old Corvettes.
Tim D
