  New Posts New Posts RSS Feed - fuel gauge
fuel gauge
Burtman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burtman Quote  Post ReplyReply Direct Link To This Post Topic: fuel gauge
    Posted: June-09-2011 at 7:05pm
86 ski that the fuel gauge will only show empty.
What is the best route to take to get fixed beside just keeping the tank full? New sending unit?
Burtman
"I'll help where I can but don't make your problems my problems"
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2011 at 7:43pm
There are ways to test to see which side had failed. This just came up. I did a quick search and couldn't find the other thread. I'll look later and see what I can come up with.
Something about grounding he sender wire and if the gauge moves, then it's the sender. Not totally sure though. Worth trying to clean up the sender wire connection as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burtman Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2011 at 7:54pm
Thanks Bri
I will try cleaning all of the conection points this weekend and post any results.
Burtman
dochockey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2011 at 12:16am
Do you have a ski course where your at?
Kirk
1989 Teal Ski Nautique
1967 Mustang
Harris Float
Sunfish
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2011 at 9:02am
Fuel tank sending unit The search feature is fantastic but using the correct key word can be the problem at times!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2011 at 11:20am
Cool Pete. That's what I was looking for
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2011 at 12:11pm
Do exactly what Pete said in the other thread. But also check the condition of the cork float.
I had the same problem with my "85. After doing all the tests Pete said it tested fine including the ohm test. Put it all back together still didn't work
It ended up that the cork had built up a bunch of varnish and was gas soaked and would not float correctly. Replaced the cork with a new foam float and wallah worked like a champ.
Still have the $50.00 sending unit sitting in the garage that I bought to replace it with.
Moral of this story, don't rush out to buy replacement parts till you know you'll need them!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burtman Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2011 at 3:52pm
No ski course on my lake Kirk. I'm in southwest lower Michigan. Where are you located at?
Also, thanks for all of the usefull info.
I will be working on this tomorrow morning to see what i can come up with. I will deffinetly check the cork before dropping the loot on an entire new unit.
Burtman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2011 at 10:37pm
[QUOTE=gun-driver] Replaced the cork with a new foam float and wallah worked like a champ.QUOTE]
I think I have the same problem Paul.Where did you get a float?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2011 at 10:17am
Gary,
I got it from a ATV/snowmobile shop in my area. They usually have some lying around.
You can also check Lowes hardware drawers in the area of the furniture fastners they carry corks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burtman Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2011 at 1:20pm
I took the back seat and rear panel out and noticed that one wire at the unit itself was broken off at the conection point. Cut about 4" off of the wire and reattached. Works great.
Thanks everyone.
Burtman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2011 at 1:33pm
Gotta love the simple and free fixes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burtman Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2011 at 1:43pm
yes it was nice to not have to open the wallet
Burtman
