  New Posts New Posts RSS Feed - Another Neutral Safty Question
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Topic: Another Neutral Safty Question
    Posted: June-08-2006 at 9:45am
My neutral safty switch has always worked but at times it works sporadically. There have been instances where it will start in gear and there are times (more frequent) where it prevents me from starting even though i'm out of gear and ready to start.
In the latter situation i can put it in gear through the trottle down, pull it back to neutral and it seems to retrigger the switch and get it acting properly again.
Linkage to transmision gear indicator appear good and wires all appear good. Has anyone else experienced this. I was wondering if its a sign of the switch going bad. All comments appreciated
Jerry
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2006 at 11:05am
It sure does sound like it is time for a new switch. There are two types, so make sure you know which one you need before ordering...but it is probably just old vs. new style.
Very easy to change....takes minutes.
