Hull Hugger |
Page <12 |
Scrawford ![]() Groupie ![]() Joined: June-03-2010 Location: Boise, ID Status: Offline Points: 53 |
I would also check your exhaust manifold to riser gaskets. I noticed my port side was running a little warm, pulled the riser off and noticed that I had not trimmed the gasket enough around one of the water ports.
Eric
97 196 Closed Bow |
Phil, All you need to do is click on the down arrow next to the members screen name. Click on his profile and it will bring up all the data. One of the items is the last time he logged into the site. Also, you can not just copy and past a link on CCfan like you can do on other sites. First, you must go to the "post reply" and not the "quick reply". You will find the "world" icon. Clicking on it will bring up a window where you what to type in the description of your link. Click ok and the next window is where you what to paste the copied link. |
Jones ![]() Senior Member ![]() ![]() Joined: September-07-2010 Location: Boise Status: Offline Points: 249 |
Howdy. All I had to do was take it out and it rattled so I knew something had broken loose. With so few hours on yours I doubt it but might be worth a look. Due to the design, it was hard to tell by reaching up inside.
1979 Ski Nautique (sold)
1997 Ski Nautique 1998 Super Sport Nautique |
PhiloM5 ![]() Newbie ![]() Joined: August-09-2011 Location: Los Angeles Status: Offline Points: 26 |
Hi.., wondering if Jones is still on this board... I have the same issue with a hot port downpipe and would like to ask him some questions. I've already fried the port downpipe and have replaced it with a new one. But when I run the engine the port side get really hot. I checked the risers and everything looks really good so I'm leaning towards the hull hugger thingy. I'm wondering if I can simply take the rubber hoses off and check for blockage.
Does anyone have an email address for him ? Here's the link to my thread. http://www.correctcraftfan.com/forum/forum_posts.asp?TID=23036&PID=289015#289015 |
97 Ski
5.0 97.3 hrs |
Sephmu ![]() Senior Member ![]() Joined: September-11-2009 Location: Jax Beach, Fl Status: Offline Points: 169 |
Hey Jones glad you got your problem solved without spending a ton of $$!
I finally wrapped up my install Sunday and I'll have to say, there is no doubt you came out way ahead of me in the money spent category!! I forgot how much that stinking exhaust hose is! Regardless, I'm excited to have that bulky hull hugger out of there, and surprisingly I couldn't tell much of a difference in noise while on the hose in the driveway, granted it wasn't under a load but I was expecting it to be much louder regardless. Maybe the old hull hugger had already given up the ghost before I got it, not to mention it had split like an egg! But the only discernible difference was maybe just a bit more "sharpness" in the exhaust note. We'll see how she barks in the water, but man my bilge is much cleaner without that thing! Hopefully I can get some pics soon for those interested, as I'm looking at the camera on my desk while I type this, which I'll surely forget at the end of the day! Thanks again everyone. |
The debris in the picture is after I had to reach in and break it apart to remove the tube. If I would have known what was in there, I would have cut a larger access hole (and wore some gloves)
I took it to the lake yesterday and problem(s) solved!! The exhaust hose is now warm, not hot and I had no problem getting to 4500 RPM. In fact, it seemed to run better the longer I was out on the water. There is no doubt quite a bit of crap on the valves that was blown off. Another surprising part is that it had little if any noticeable effect on the noise. Although it may be louder than a properly functioning Hull Hugger, it is still A LOT quieter than my old '79. |
I've been having a couple issues I have been unable to completely solve and which I thought were unrelated until I finally solved both over the weekend. As mentioned here Hot Exhaust HoseI've been having intermittent issues with hot exhaust hose to the point of blistering the inside. I thought the risers were the issue but they weren't. Manifolds are in great shape, the engine runs at perfect operating temperature and water flow appeared to be good. I was beating my head against the wall trying to figure out the problem. Another issue was a rattle in the muffler that prompted me to plan on replacing with a Y-pipe. The comments here from Mr Muskewitz and watrski caused me to change my mind. The rattle was not very noticeable when the boat was in the water so I thought I would just leave it alone. And finally, I've recently been having some hesitation at WOT I thought were the vacuum secondaries.
Then, Friday night it came to me that blockage in the Hull-Hugger could be creating excessive back pressure resulting in the hot exhaust and was probably also causing my high RPM issues. The first thing Saturday I dug into it figuring I had nothing to lose. Thanks to Eric Crawford for his recommendations regarding the 45 degree cut with the Dremel. |
Yeehaw, y-pipe and various other goodies on my doorstep this morning thanks to Bonnie at Race-City Marine! Pics as soon as this wonderful "sunny" Florida weather clears up. Thanks again everyone!
I see. That would be a problem. I just didn't think the Y pipe made that much of a difference in the noise. I sure would like to hear the difference before I make the switch.
watrski ![]() Senior Member ![]() Joined: December-01-2010 Location: Chippewa Lake Status: Offline Points: 393 |
Its all in your taste. Sounds good from far away. We actually use our boat 4-5 hours a week so the constant rumble gets annoying. I also ski 2-3 days a week at 6AM, don't like to wake up people so they can complain. |
Some people say too loud, others love it and say it's not obtrusive at all. It seems some of the early morning skiers around here have "un-Y-piped" more out of courtesy to the sleeping residents on shore rather than not liking the sound.
All depends on your use and preferences I guess |
Just took a Y pipe and crap out of mine.
Got tired of having a headache after driving the boat for a couple hours. |
Gotcha. Good luck. I would be very interested in how it turns out and what affect it has on the boat.
Yeah, they have all the sizes on that sight which is nice, I just linked one at random. but I believe mine is 3.5 inch in as well, I'll double check when I get home.
Like I said, at that price I'll have my ducks in a row before I order! Hopefully I'll get some pics up when I'm done next week |
Yes, be carefull. That shows 3" exhaust x2. Mine was 3.5"
$145!
Found this bad boy, and at that price I can assure you that I will be measuring twice ![]() Thanks again everyone! -Sean |
I think the freight cost was more than the purchase price. I'm very interested to see how it works out.
I haven't replaced it yet but I'm planning on it. Being the cheapskate I am, I decided to buy one of these and modify it rather than fork over the $100 plus:Centek Surge Chamber This is how it turned out. ![]() |
Thanks but keep in mind that was the first thing that popped up with my search. Many different inlet/outlet diameters are available. Keep going - I want to see the results (and hear) of getting rid of that "septic tank" hull hugger!!!! |
I spent two hours searching before I posted that question!
![]() Thanks as always Pete. You da man! |
Come on Sean, you haven't figured out how to do a on line search yet???
![]() ![]() I just did a on line and with the first hit came up with this:Marine fiberglass Y pipe Go for it!! ![]() |
Hey Jones,
Where did you find your y-pipe? Looking to find one asap, adios hull-hugger....man I hated that thing! Thanks |
Thanks Eric. The baffles actually do very little to "muffle" the noise and probably have more of a negative impact by restricting exhaust flow than it does by reducing noise. I was looking at the most cost effective method of eliminating the rattle and figured if I had to cut into it I might as well remove the baffles completely. It turns out I decided to replace the hull hugger with the "Y" pipe mentioned previously in a few threads.
It's nice to see another Boisean on this site and I hope to see you around. I was at Black Canyon yesterday for a test run and it was flowing like a river. |
Removing the baffles kind of defeats the purpose of the muffler. So yeah, you could remove them but then the muffler won't 'muffle' as well.
Here's a post of mine on how to rebuild your muffler for about $20. Did mine last summer and still going strong. http://www.correctcraftfan.com/forum/forum_posts.asp?TID=17967&KW=&title=blown-muffler-rebuild--easy |
Eric
97 196 Closed Bow |
You can replace the Hull Hugger but it will hurt the piggy
![]() Sorry about that, just wanted to use the pig emoticon. I was going to say that the Y pipe came up in another thread as a way to replace the invera-flow, but looks like you were on that thread. |
This topic may have been covered before but has anyone ever cut open and removed the Hull Hugger baffles? I really don't see much of a use for them other than noise and mine have developed an annoying rattle. It seems one or more have broken lose inside.
Page <12 |
