  New Posts New Posts RSS Feed - 82 nautique oil pan gasket
zeclops View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zeclops Quote  Post ReplyReply Direct Link To This Post Topic: 82 nautique oil pan gasket
    Posted: July-25-2011 at 1:10pm
Getting closer to finishing up the rear main seal on a 82 351 And yes thanks for all the response on the rear main seal. I am wondering if I can use a automotive 4 piece oil pan gasket or is something unique about the original marine one.
Thanks,
Stan
stan082
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2011 at 2:36pm
get the fel-pro marine 1 pc with steel spacers
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2011 at 2:37pm
hanging upside down is a beeoch, 4 pc means 4 places it can leak....trust me on this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2011 at 2:39pm
put a damper in there too
Post Options Post Options   Thanks (0) Thanks(0)   Quote zeclops Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2011 at 3:06pm
Thanks for the response. Yea I get dizzy hanging upside down. I've completly removed motor and put on stand so that I can clean and rotate. Saves my back as well. I just saw they had a 1 piece of 4 piece at autozone and was checking if they would work on the marine application. I will track down the felpro you mentioned and use that. Thanks for the damper tip.
Stan
stan082
