SS Mini Update |
Post Reply | Page <1 2345> |
dchris17
Gold Member Joined: May-28-2005 Location: Weatherford, TX Status: Offline Points: 573 |
I'm using an ammeter. I just figured out that everything seems to work if the ammeter is not connected. If I'm using an ammeter, do I connect all the "I" posts on my gauges to its "I" post?
Should I just switch to a voltmeter? This is really pissing me off. |
JEFF KOSTIS
Gold Member Joined: April-19-2005 Location: United States Status: Offline Points: 817 |
Dave, make sure the wires to the ammeter come from the alternator output stud(this line feeds the ammeter), then the output of the ammeter returns to the battery +(or the hot side of the starter solenoid). You should then have a wire going from the BATT terminal on the ign switch to the ammeter(the side connected to the alternator output). All the +12v to feed the gauges hook to the ign terminal on the ign switch. Also, on the ammeter, if the gauge reads backwards, flip the wires on the posts. It will still work and not hurt anything if hooked up backwards. See how this compares to your connections. I also messed up in my previous post as I meant to say that no wires from the ammeter should be connected to the ign terminal on the ign switch, as your battery will go flat in no time, and your engine wont shut off.
I was looking at the PCM schematic in the reference section and they have a error in the way they show to wire the ammeter in place of a voltmeter. They have it wired to show the actual output of the alternator feeding everything instead of just showing battery charging current. I have never seen that. Best of luck!!! Jeff... |
JEFF KOSTIS
Dave, I wont be around till tomorrow night. Will see you ya made out then so you can can the "iron pipe pylon" out to get a ski in.
Jeff... |
JEFF KOSTIS
I had to get a quick post in this morning, as when I woke up, I realized I forgot to mention that the line going from the ammeter to the batt terminal on the ign switch should go thorugh the ign dash fuseholder to protect the line. Also, the wire going from the ammeter to the batt + point on the engine should be hooked inline through the 60 amp breaker to the battery, instead of the hot battery side of the starter solenoid(if it is).
Jeff... |
dchris17
Big sigh. We got in one wakeboard run in this morning. The water was beautiful and the wake that my little boat puts out is freakin' awesome. On run #2 though, there was a pop from the motor and the valves started clicking. Fortunately, someone towed us in. I haven't pulled it apart yet so I don't know what is wrong yet.
Bummer. I'm feeling a little depressed. At least the wake was beautiful. Gosh. |
dchris17
Turns out it was nothing - just a spark plug that had wiggled loose. What a relief. Too bad I wasted my morning not skiing!
scott8370
Gold Member Joined: November-30-2005 Location: United States Status: Offline Points: 872 |
good news. That was a easy fix. As for skiing..theres always tomorrow.
Scott
dchris17
Yes there is. And the iron pylon worked out okay. It had a little play side to side, but otherwise it was fine. I need to put some kind of spacer around the old ring pylon I put in it off of eBay. It's too short to ski from, but it is good enough for sliding the pipe onto.
I also had my very first "Man, what do you have in that little boat?" experience. That was pretty gratifying. My M17 really looks good in the water. I still don't have the ammeter setup right. I'm going to keep working on it this week and go skiing again on Friday. |
jbear
Dave: That is one of the best things about these boats, what happens on the ramp. I never take the '80 to the water without getting some kind of comments. Feels pretty cool huh, knowing where your boat came from?!
john |
dchris17
Finally! I was able to get a solid set of wakeboard runs on the SS Mini. Man, it has a nice wake compared to my previous boat. It was nice. And there was no paddling it back into shore for a change!
JBear is right - these are the coolest boats around. I did have one mishap. Forgot the bilge plug - there was five inches of water in the boat when I realized what I'd done. Thank goodness for bilge pumps! A couple of things I've noticed: - The ammeter is wired backwards. It goes negative when the RPMs increase. - The speedo doesn't kick in at lower speeds and bounces a lot once it does kick in. - The control requires a soft touch. It takes really small adjustments to get it to the right spot for boarding. Will that improve when I replace the control with something newer? - The boat takes off like a rocket when it gets on plane. Holy crap! It's fun when you're just messing around, but when you're towing somebody you have to watch it. - I love this boat, but it turns like crap. It needs a fin or two. Anyway, had a good time. We didn't tow it to Texas after all - it would have been awesome to ski the cliffs at Possum Kingdom, but maybe next year. |
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3362 |
Yes, a new Morse control, cable, ends, and the right throttle return spring and you'll be able to control the speed by shifting your butt cheek.
However, if you hold the throttle like a gearshifter all bets are off. Its neccessary to rest your wrist on the console or gunnel and hold the knob between the pads of the thumb, index and middle finger and adjust speed by flexing those three fingers. You boat likely doesn't have a speedo balance tube, hence the bouncing. Without wrecking the dash for dual airguides a cheap GPS is better. |
dchris17
Any recommendations for a GPS? It would make a good "featured product" for Keith...
JEFF KOSTIS
Where we have so many weeds plugging up the speedo, its better to train yourself to listen to the engine, as well as look at the wake. Getting familiar with a particular boat is better to set and maintain speed.
Jeff.. |
dchris17
Hopefully I'll start getting to know this boat better soon. There have been so many kinks getting to the point where we can take it out for a day and not worry about paddling it in that I don't really know the boat yet. And we're still not through all the kinks, but I think we're getting close.
I don't, but I borrowed one last year and It had .1 mph resolution and updated very fast. It was sure handy when my daughter was on the boom and I'm trying to hold a 'hot eleven'...
dchris17
I wish they made one that fit in a standard 2.5" opening. That would be pretty cool.
dchris17
It's been a long time since I posted, but since bkhallpa$$ put this post in the list for best of 2006, I guess it's time for an update.
The boat runs great. It's awesome to ride behind, although I have a hard time finding buddies who can get out regularly and who can drive worth a darn. It's very fast - even outran a brand new malibu and is noticed every time I tie it to a dock. It still needs new upholstery, a new floor, new metal (horn, cleats, etc), and would definitely benefit from a new control. It also needs some gelcoat repair as well. That's the good news. The bad news is I'm quitting my job and going back to school full time to get a PhD in 2008. I'm afraid 2007 is going to be the last summer I own this boat, and then it's going to find a new home. I just can't store it for 4 years, unless someone wants to volunteer some free barn space until 2012. Needless to say, I'm a little depressed about letting the SS Mini go, but it will be worth it when I get out of school and start my new career. |
Nautique2001
David,
I wish you the best of luck in school. Sounds like you've got lots to look forward to with your career. The good news is that CCF.com will always be here. Whether you own a boat or not, keep your posts coming. We'll help you pick out another great Correct Craft boat in 2012. Plus, look at the reunions you can attend if you're available! Ken |
You're going to sell it after it's been in the family since new?
Still need a pylon? |
dchris17
It hasn't been in my family since new. I got it from the son of the original owner. I've only had it for two years. Still, that's exactly how I feel.
No, I don't need a pylon anymore. Thanks though. |
Nautique2001
Hollywood,
You have money burning holes in your pocket, you should buy it! Ken |
dchris, I definitely misread your diary, woops.
Anywho, I definitely don't have the extra cash for another boat. If I could store it I would but I just checked and don't have any of that either! |
dchris17
I'm going to give first shot to my four brothers. They are all boat enthusiasts, and one of them is likely to pick it up. If that fails, I'll post it here. At least that way it will stay in the extended family. I would cry if I had to sell it on eBay.
copcraft
Senior Member Joined: October-07-2006 Location: United States Status: Offline Points: 165 |
Dchris17
That was a good post! I'm glad I went back and read it all the way through. Since BKH said it was good I knew it would be. I have a vision of what you did with your SS mini for the '74 Mustang I'm working on. Your posts, and Jeff Kostis' input, helped me tons. Thanks and Good luck! |
jbear
David: Lots of luck. Please keep your C/CFAN friends up to date on how it all goes. I sure have enjoyed sharing your story. Can still remember when you first found this boat at the yard and what you went through to get it home. Still remember the excitment in you post when you got it in the water for the first time. That is the gret thing about this site; the story behind some of these old boats and the guys who care for them. Thanks!
john |
JEFF KOSTIS
WOW!!!! I havent posted in a while due to work taking over my life, but I have to on this one.
Dave, I am happy for your going to school, but are you sure you have exhausted all possibilities?? I felt like a fool to ask, but this kills me!! Its hard looking back in the beginning at your first post and seeing your excitement. Im sure it isnt easy, but Im convinced that the SS MINI was your first real "family" boat after the pics of the kids in it. Im sorry if I just made things more difficult for you. GOOD LUCK ALWAYS!!! Jeff... |
dchris17
Actually, Jeff, I think you and my brother James are helping me think this one through a little better. My first reaction to quitting my job and going back to school full time was that we would be so poor I would have to sell it for the cash. Now that I'm going through the detailed planning, I don't think that's the case. I probably won't be able to afford to run it much, but if I can find a place to store there may be no reason not to keep it.
So... I'm going to cross my fingers. I've been thinking about this a lot this weekend and I've come to the conclusion that I will hold on to the SS Mini for at least one year, and will only sell it if I don't have a plan for storing it after the summer of 2008. Thanks to everyone who has pitched in over the last two years and encouraged me on this project. Hopefully I'll find a way to get a PhD and keep the SS Mini! |
JEFF KOSTIS
Does this mean "Pile Higher and Deeper" and keep the SS Mini???? Jeff... |
dchris17
That's funny. Yes, I believe it does.
69 Mustang
Senior Member Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
David,
I'll be building a 4 bay addition to the soon-to-be "Garage Mahal" this summer. It will be 2 bays too many on purpose...I know it is a little out of your neighborhood (Southern MD), but if it is the difference between holding on to her or not, you can lay her up here when I am done. Mike |
For every complex problem, there is a solution that is simple, neat, and wrong.
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
