Electronic Ignition Change |
firefighterwes ![]() Newbie ![]() Joined: April-21-2006 Location: United States Status: Offline Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: June-22-2006 at 8:20pm |
Hey guys,
Im gonna be purchasing a pertronics ignition system for my nautique and I need to know what all parts need to be purchased. Do I need to replace the coil, plug wires and distributor, or just the distributor. Appreciate the help. Thanks All, Wes Everyone be safe this season. |
77stang ![]() Senior Member ![]() Joined: May-19-2004 Location: United States Status: Offline Points: 342 |
i have a pertronix 1581. On the 1581 there is no additional parts and you DONT bypass the resistor. The instructions are pretty easy to comprehend.
and, atleast on mine, you dont replace the distributor its a simple slip in module |
Your boat is cherry man. She is beautiful. Will that 1581 work on a Ford 351? Ive got an 81 nautique. Appreciate the help.
i honestly don't know but i think it does. check their website or maybe google
"pertronix 1581" - if that doesnt help check their support phone number |
joed ![]() Senior Member ![]() Joined: May-04-2006 Location: United States Status: Offline Points: 144 |
If you go to www.vintageperformance.com you can find the right one based on your distributor type. From what I've read the 1581 is for 8 cyls. with prestolite distributors that have the "clip-down" cap.
You don't have to replace the wires, but not sure on the coil. I'm planning on buying the "flame thrower" coil when I do my upgrade. Hope that helps. Joe |
joed is correct. and even if you buy a new coil it has to be a points compatible. ie. your existing coil is fine
