  New Posts New Posts RSS Feed - Changing tranny fluid
marmon77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marmon77 Quote  Post ReplyReply Direct Link To This Post Topic: Changing tranny fluid
    Posted: September-09-2011 at 11:37am
Would like to know the best or easiest way to drain tranny fluid, any tips tricks so as not to be too messy. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 11:44am
Mark, some guy's have used a turkey baseter(sp?)to remove Tranny fluid, some have used a small pump to remove it. I use a huge syringe with a rubber tube on the end to draw out the fluid. It takes awhile but no mess and I get most of it out.
LaurelLakeSkier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaurelLakeSkier Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 2:12pm
A vacuum pump similar to this works well for the removing trans fluid and comes in handy for a variety of fluid removal operations.
The world is full of youth—what we need is a fountain of smart!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 2:17pm
We use the suck up and it works great... a mitivac is supposed to be a quality unit as well.
Mark, whats up with the red rev-gel BFN? You thinking of upgrading?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 3:02pm
Tom351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom351 Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 3:17pm
I use one of these:
http://www.walmart.com/ip/Attwood-Gear-Lube-Pump/16351021
Just add a hose on the end made for the bottle and you can drop the hose into the trans filler hole
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 4:06pm
I used one like this. If the collection tank is not connected to the pump, it's helpful to have someone holding the output side as well as the collection container. Or else yes, you will make a mess.
I found I had to poke around a little bit with my suction tube to find the bottom of the trans. Also, I used two identical, empty, windshield washer containers. When I was done sucking out the old fluid, I lined up the container with the old next to the empty container. Then, I filled the empty with the new, until it was at the same level. Then put the stuff in. (This helped insure I was putting back exactly what I took out).
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 4:11pm
That's a good idea takes the guess work out of the equation.
Liledgy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liledgy Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 4:25pm
. I have used the little pumps that you can put on a cordless drill. Worked very well and quick to. It's pretty cheap too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaurelLakeSkier Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2011 at 8:20pm
Tim
The red/white is the right color combo for me and if it was a bit closer (and maybe a little lower price) would be worth a look for a nice retirement project. In terms of the upgrade, if you're asking if it would replace my BFW (Barefoot Whaler),I don't ever see getting rid of that boat although adding a few more HP is always a possibility.
The avatar addition came as a tip from Dr. Hollywood
Post Options Post Options   Thanks (0) Thanks(0)   Quote marmon77 Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2011 at 1:16pm
Thanks for the info. guys Il';ll get to!
