USCG approved or not? |
Post Reply | Page <123> |
Tom351
Groupie Joined: August-23-2010 Location: Chapel Hill, NC Status: Offline Points: 98 |
kinda joking- was more poking fun at the "Jet Pilot" name- In my head it is "Jet Ski Pilot"...but I realize that it really means more than just that. |
Jllogan
Well, its not so much looking cool as it is comfort. I mean, usually the smaller vests are easier to move in etc. I still want to float or I would just wear a rash guard. Also there is becoming a vast selection of non uscg approved vests. In fact it seems anymore is almost 50/50 depending on where you shop. So I was more curious if there really was a big difference. Thought maybe it was like getting a food to be kosher, just need their blessing.
mdvalant
Whew...thought you were kidding but just had to be sure ;)
I recommend the A-10 to all of the guys in show skiing. Almost all of us use them in practices and shows. Barefoot suits used to be the norm but for a 4 hr practice they get annoying. The pilot isn't bulky and allows the climbers to fit in front of us/on our shoulders with ease. Keynote: we always have pickup boats and very competent observers keeping an eye on our skiers. |
The first pull-over type vests I noticed were nylon Slippery When Wet and made for the jet ski racing crowd.
You must wear it properly! I just love it when a girl takes off her vest and a nip is out. |
mdvalant
Those vests are unsafe, they should not be wearing them.
mdvalant
Some in our boat choose to wear the non traditional front bobber vest. I tend to prefer these over the other.
IMAGE deleted so this thread is SFW. |
calendar ^^
Jllogan
Tom351
+1 on the calendar
After seeing this: It would be interesting to get out some weights and compare my Oneill Assault (CGA) to Outlaw (Non-CGA) in floatation- My guess is that the CGA vest is around 20lbs and the Non-CGA is around 8-10lbs. And MD- I think you make a good case for using the A10 in your situation- there is a big difference between tournaments or show skiing (or people with that much experience going wakeboarding/skiing together) compared to the average person wakeboarding in an A10 with an inexperienced friend driving the boat. |
MattB
Senior Member Joined: September-30-2011 Location: Nottingham UK Status: Offline Points: 376 |
This site is not the normal internet forum for boat owners as most of you guys are older and more experienced than a lot of the people posting on forums out there. We will all have (should have) enough experience to know what can happen and how to mitigate risks. If you feel comfortable in a non approved vest and KNOW it will float you in an emergency then go with it, if it wont float you then you are putting your life in the hands and hopefully quick thinking of the guys/girls you are riding with.
Oh and don't forget the difference a wetsuit can make to buoyancy, last time I was diving I had to carry an extra 14kg of weights to get the correct buoyancy due to the 12mm of wetsuits. If a comp vest floats you whilst wearing a 3mm will it do the save if you are just trunking it? That image isn't very `office` friendly I will need to have a second look at this thread later. |
Jllogan
Yes, I think the problem is that the information that is readily available on vests while buying them is that it is either cga or non cga. There really is no buoyancy ratings or at least its harder to find. So you dont really know what you are getting until you get it. I have seen some vests like the A-10 which look like they provide little flotation while other non CGA vests definitely look bulkier, I am sure there are many differences. Problem is you dont know until you are in the water.
Tom351
Exactly- this is the only comparison test that I have been able to find: http://www.boatus.com/foundation/findings/50/page6.asp |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6121 |
something that I have found that works, is that if your vest is a little loose, cumbersome and bulky, if you gain 15-20 pounds, it fits real snug.
DieselCash
Groupie Joined: October-30-2011 Location: Killeen, TX Status: Offline Points: 53 |
It may just be me and my bad luck but, I prefer a USCG vest. Because if something bad is ever going to happen, it will be me. Being alive is 100% better than ever being dead.
1992 Sport Nautique
Bri892001
I have a Hyperlite Indy.
The year I have is a little less bulky/cleaner looking than this one, but close to the same look. It's USCGA and not very bulky. I know from lifeguard classes that I sink like a rock with lungs empty and not paddling... to the point where people never wanted to pair up with me for rescue drills. So I probably wouldn't mess with non USCGA. |
Jllogan
M3Fan
I just switched from the "most comfortable", slimmest, most flexible USCG vest I've ever found to an Eagle Comp Vest.
It floats me but definitely not to the same height/degree as the USCG equivalent. It's not one of those super-thin ones- it has some meat to it. To me it seems like a good compromise. However, the performance difference, weight difference, comfort level, etc. is NIGHT AND DAY. It's running the slalom course with at least 10 less pounds of wet foam on my upper body. So, everything is a risk. Getting on the ski is a risk. Boating is a risk. Will I make every set of this sport less pleasant, to a considerable degree in comparison, for the difference in buoyancy in the off chance that I fall in a certain exact way where the delta from one vest to another might be the ultimate reason I die (out of the 5000 other factors contributing to the death)? Right now probably not. If the comp vest wasn't such a big difference then it would be an easier decision to make. Next year I'll try to do some tests out of curiosity. |
05 210
Platinum Member Joined: February-17-2006 Location: Southern Maine Status: Offline Points: 1481 |
I dont ski so I have no experience with those types of crashes. I had a bad day two years ago on a wakeboard though. It was late in the day and I was kind of beat from riding and being out in the sun all day. We were riding in a nice flat cove on my lake and when the driver turned at the end I decided it would be a good time to cut out hard for a nice powerslide.....done it hundreds of times. Got going about mach 2 and got into the slide, got lazy and stood up. Caught a back edge and hit the water so hard backwards that the lens on my watch broke. I had a USCG approved vest on and did not get knocked out. However, I was under water completely inverted with the board still on my feet. Body tingling, staring up at the sunlight hitting the surface of the water, unable to move any part of my body. As I slowly passed the folcrum and started to float up my buds were out of the boat and swimming towards me. As I reached the surface they were surpised that i was still concious. They had to take my board off and physically put me in the boat. It took me almost two weeks to recover from that crash. Last year I was reading an article Wakeboarding Magazine and Chad Sharpe was writing about the importance of proper floatation. He is a world class rider and experienced the exact same crash that I did and said he has never been that scared in his life. Until you have been stuck underwater, helpless, and concious enough to understand whats happening, but not be able to help yourself will you understand the importance of proper floatation. And I actually had it on. Imagine that same scenario while wearing a comp vest and being spotted by some dudes with a few beers in them that didnt realize you fell till they got 1/2 way across the lake. I'm all set with that. All it takes is a few seconds and it's over. Comp vests are for competitions.
Mike |
Bri892001
There's a guy on my lake who's a pretty serious wakeboarder, who wear's a helmet as well as a life jacket. He was doing some sort of trick one time, and somehow managed to catch himself in the back of the head with his own wakeboard. I'm actually not sure if the board was still attached to his feet or what, but it resulted in a bunch of stitches. He started wearing the helmet after that.
75 Tique
Maybe I should think about that. I drew blood from a minor head wound from contact with my slalom ski after a pretty good tumble last summer. You just never know. |
Bri892001
I used to worry about that with the kneeboard too. You can face plant and the board will come right off and still have quite a bit of momentum behind it. I'd usually keep my head down for a second or two after a hard fall.
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2099 |
I utilize either a Straight Line or Eagle Non CG approved vest, However in my world very few serious skiers utilize CG approved vest as they ski on private lakes.
Having read many regulations, State and Municipal laws concerning the use of approved flotation it would be in every ones best interest to know what the law's and regs are in their area. Having been beat up pretty good from time to time taking digger's at 34 and 36 mph I have only had to be plucked out of the water seeing tweety's and Stars once. but when I do fall hard and Float up from it I all way's put my hand up in front of my face. I came up about 15 years ago and as I turned around to look for the boat the ski that had blown off my feet hit me right on the bridge of my nose! ouch! Blood and more tweety's and stars! |
MattB
Even if you do bash your head at least an approved vest (or vest with sufficient buoyancy for you) will keep you afloat so that you can get rescued. The helmet or no helmet argument is very very subjective and down to personal preference. I wore a helmet for a couple of years due to a ear problems but don't wear one anymore unless I am doing obstacles. But its personal preference, I don't think the two issues can or should be put together in the same way.
One of the devices will save your life and there is an enormous amount of evidence to support this, the other safety device will at best stop you from needing stitches, all the other evidence about helmets is very subjective. Try and prove me wrong about a helmet but I still won't go back to wearing one unless I am riding over obstacles, there is no way you will get me into the water without a good impact vest with good buoyancy though. |
IAughtNaut
I must be falling wrong...
Jody, you've only seen those cool little flashy stars once? It seems like that happens about every other time out for me. Somebody told me once that was an indicator of a concussion, anybody know if that's true? And Mike, I probably had a half-dozen times this summer where I ended up with my board on top of the water and my body straight down underneath with no idea which way was up. I actually kindof enjoy those, because I can hang there weightless for a few seconds (which feels like an hour), let my body go limp, and know my vest will eventually pull me back up. Ya'll can do whatever you want, you're grown adults, but with the beating I take, I'll never not have a CG approved vest. |
Morfoot
+2 on that. Same thing but with a kneeboard in my experience. |
81nautique
conscious or unconscious both scary as hell. My wife took a backwards headslam on a powerslide this past August. That was one nasty fall and her bell rung the rest of the day not to mention twisting a knee. Major mental set back as well. |
watrski
Senior Member Joined: December-01-2010 Location: Chippewa Lake Status: Offline Points: 393 |
I always wear my USGC approved vest when skiing.
The problem with USCG vests is the $$ it takes to get them certified. Just because they don't have the certification doesn't mean they will not work. |
05 210
75Tique and Quinner both rock those when they're on the water. I think that there are inherent risks involved in everything nowadays so I do what I can to be safe that's all. I will never be good enough at watersports at this point in my life to justify the necessary gains from a comp vest. If others can honestly say that the next advancement in their skills would come from a smaller less restrictive vest than so be it. I think the thing that alot of people realize when they start to get older is that it is no longer just about you, its about the wife, the kids, the mortgage, the business, etc. FWIW I dont feel like a person skiing in a comp vest on a private controlled lake is the same comparison as someone out on a larger body of public water, but thats just me. Mike |
81nautique
Sad but so True, especially the way things have been the last couple of years. I've had to get back into the manufacturing side of my business, if I got hurt to where I couldn't do physical labor I would be in a world of hurt. Even a hard weekend skiing with no injuries slows me down at work for a couple of days and the whole business suffers from it. Responsibility and reality can really suck. |
9 out of 10 Veteran skiers prefer the older vests lol,
