Need Airguide Replacement Glass |
lakemurraybass
Newbie Joined: February-07-2011 Location: Lexington SC Status: Offline Points: 27 |
Posted: January-19-2012 at 11:41am |
Does anyone know of where to get replacement glass for Airguide Speedos Circa 1987-1989
Can anyone help? rbass@uh.org |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2077 |
I have a box of speedo's and other misc gauges and what not's give me over the weekend I will see if I have anything.
Cuda Chris
Senior Member Joined: December-22-2011 Location: Tampa, FL Status: Offline Points: 401 |
Lakemurrayboss,
Check classicboatwork.com, Dean is the guy you will need to get in contact with. A few are advertised on that site. |
Donald80SN
There was a post on this site that spoke about using Clock / Watch Crystals ( Glass). Apparently, they are common and you can drill a small hole or two in them very easly with the proper bit.
Do a search on Airguide restoration and it should appear. I hope this helps, Donald |
politicallycorrect
ClassicBoatwork
Senior Member Joined: July-19-2008 Location: United States Status: Offline Points: 119 |
Regarding new lenses. Clock glass is not the same as original Airguide lenses. It will fit but is shaped differently than original lenses. I have quite a few that I bought as NOS but are not correct Airguide lenses.
I am waiting for an estimate to have new reproduction lenses made. I will post on the forum when I have them available. I currently have only enough for my restoration work. Thank you, Dean Classic Boatworks coolboats@classicboatwork.com |
Yellowbird
Groupie Joined: November-04-2011 Status: Offline Points: 64 |
I am looking for gauges for a 1967 Wildcat. Tach, oil, water, etc.???
ClassicBoatwork
Most of the gauges I have are on my website. I don't know what each year and model of boat needs what gauge. If you do not see what you need send me an email with a photo of the type of gauge you are looking for. Sometimes I can find them through one of my sources.
Dean www.classicboatwork.com |
