  New Posts New Posts RSS Feed - Replacing cutless bearing
crobi2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Topic: Replacing cutless bearing
    Posted: February-07-2012 at 8:26pm
Ok, finally getting around to it.
Leave the boat short on the trailer so you can drop the rudder (support the rudder so it doesn't hit the concrete when you unbolt it on top).
Remove the prop, and propshaft. Check your alignment when you disconnect the coupling. Mine was better than 0.0005 (yahoo!).
unscrew the lockscrews on the side of the strut
Sawing the old cutless shell. Be patient, take your time, take breaks (repack your log and rudder) don't use your sawsall!
fold the edges in with a screwdriver and light taps.
Pull out with pliers
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 8:35pm
The strut on this boat is almost 7" long. The factory put in two 3" cutless bearings one on each end with a gap in the middle of the strut. I have a 4 1/2" and two 2 1/4" bearings.
Now I know that I can just use the 4 1/2" bearing on the prop end of the strut, but since I have them, I think I want to use the 4 1/2" bearing on the prop end of the strut and a 2 1/4" bearing on the coupler end of the strut.
What do you think?
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 8:43pm
What do you think?
You don't need to go "overboard" with the cutlass length. In fact, too much will just add to prop shaft drag. I feel your plan on using the 4&1/2 on the prop end and the 2&1/4" forward is a good one.
Why no Sawsall?
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 8:43pm
Nice post. Looking forward to seeing how it turns out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 9:01pm
Thanks for the quick replies. I got the courage to do this job from reading all of the great "how to" posts on the site. I figured I would do my duty and post this to maybe help someone else do theirs.
So Pete, do you think it is ok to use both the 4 1/2" and 2 1/4" bearings together? The factory put in two 3" bearings. A 1 1/8" propshaft requires a 4 1/2" bearing. If I use both like I want to, that would be 6 3/4" of bearing, 3/4" more than the factory put in. Do you think that would still be OK?
Pete, I also took your advice and got an A.R.E. double taper shaft and I will post pics on the install. Do you know how much torque to put on the shaft retaining nut? And how much torque on the coupling retaining bolts?
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 9:14pm
Oh, and I was joking about the sawsall!
I have had one for many years and consider myself somewhat of an artiste with it. I, however would not allow myself around a strut with one. I am sure many other people could handle it safely but I was almost crying over the tiny cuts I made in the strut with the handsaw. (people have said that tiny cuts in the strut won't hurt it).
Here's a picture of our baby!
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2012 at 9:20pm
Rob,
You'll be fine with just an extra 3/4" of cutlass. I guess I just don't want for people to start filling the complete strut with a rubber bushing!
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2012 at 12:16am
I'm an artist with the Sawzall as well, but I did the first set of strut bearings by hand. Next time, Sawzall.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 1:14am
Strut bearing going in.
Back of the Walters.
Log in servicable shape.
New A.R.E. coupling (left) and old coupling (right)
Prop end of shafts.
double taper vs single taper.
Old shaft and new shaft (proof I didn't wrap it around a tree stump or something)
Alignment at 0.0005
Ready to test!
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 9:30am
Looking good!    If you can feeler gage to a half thou, you the man!     For me, it seems to change that much during the check, depending on how I hold them together.
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 9:49am
Looks like you've been on Texoma, by the looks of the hull.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 10:26am
If your old shaft is bent, I'd be happy to take the last foot or so (tapered end) off your hands! Shoot me an email: TRBenj@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 2:15pm
Thanks for all of the replies. Chris I hear you! I couldn't do it consistently either (.002 feeler gauge in, .0025 feeler gauge probing) until I had lightly coated all of the parts in grease for final assembly. I think the grease held the halves together so I didn't "pry them apart" trying to get the feeler gauge in. I agree it's tough to do and everyone should watch Pete's CorrectCraftFan alignment video (I have watched it many times).
http://www.youtube.com/watch?v=3_w0LvD6gEc
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 2:20pm
Ryan, the hull had that glaze on it when we bought it here in Texas. It could have spent some time on Texoma.
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 2:49pm
That glaze looks similar to what we battle up here in Iowa. Lots of silt in our lake so we keep a brush on the dock and scrub the entire hull now and then.
Again, great post!
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 2:52pm
Tim, the old shaft is showing .0025" of bend. I got the new shaft because I didn't want to try to maneuver a 500 degree F coupler under the V-drive. I think .0025 is still serviceable if I have a mishap and cannot afford a new shaft just then (strut, rudder, fiberglass, arrrgcetra). I have also considered seeing if A.R.E. could cut the second taper into the old shaft.
I'm curious - were you going to make a spare prop holder or something even more ingenious?
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 2:55pm
Another attempt at linking Pete's CCFan alignment video.
Someone please help me if this doesn't work!
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 2:57pm
Rob, that Air looks familiar. Did you get it at Buxtin's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 2:57pm
It's just going to be a spare prop rack. I forgot that you have a v-drive with a 1-1/8" shaft, so it wouldnt work for me anyways! Im not sure if being .00025 out is still serviceable or not, but it certainly might be. No worries either way!
FYI, CCF doesnt do "auto" linking. You need to use the globe button to create a hyperlink in your post. Make sure you delete all extra spaces before and after the URL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 3:19pm
Thanks Tim, I'll try that.
Ryan, I did get the boat at Buxton's but I bought her before she even got listed. The PO was going to sell her to a friend and sent the boat in to be inspected (compression etc.). The boat sat for a while and when I got there, Phil called the owner, who called his friend. The friend didn't pull the trigger and I immediately made an offer. So unfortunately (or fortunately) I had no nice dealer pics of the boat.
Do you think you know this boat?
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 4:17pm
It may be one a member here traded in for a 2010 and then it on a 2011(230)
Where are you in TX?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 5:20pm
Where's Brian with the macro mode suggestion? Look for the flower icon on your camera, it will focus on the upclose object and take much better pictures than the ones you posted above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-11-2012 at 12:42am
Ryan, I don't think the PO got a new boat. They had bought it in '05 and it kind of had the look of a family boat with few hours. Their last name started with P. First name I think was John. I think they just wanted out and were going to sell it to a friend but after Buxton's did the inspection, it sat on the lot until I got there. I was looking for a 1995 - 2006 210 hull and Phil had just sold a Super Sport that I was going there to look at. Anyway, Phil showed me this boat and then called the owner to see if he wanted an offer. We took her home in Dec '10.
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-11-2012 at 12:46am
Hollywood - Flower icon huh? I am such a newb.
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-11-2012 at 12:50am
By the way, water tested her today, she ran like a dream and with a little grease on the rudder shaft, turned like a dream. Packing was dripping about 1 drip every couple of seconds so I left it alone. I had the rudder packing very loose and it never dripped. Probably needs to wash out all of my grease first!
C-Rob
2000 SAN
