  New Posts New Posts RSS Feed - gulp....water in oil.
jackkloepfer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Topic: gulp....water in oil.
    Posted: February-18-2012 at 5:29pm
(I searched this, and didn't find anything)
when I went to change my oil for winterization this year...it looked like there might have been water mixed in with my oil as I was draining the old oil.
I probably ran the boat for a solid 50 hours with that same oil in it before draining it for winterization.
my main question is this; if there was a crack in the block that led the water to get in there, wouldn't I have noticed something horribly wrong during those 50 hours?
FYI: the boat sat motionless on dry land for about a month before I drained the oil.
thanks guys.
crobi2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2012 at 5:50pm
It could just be condensation from sitting, but they can go amazingly far with water in the oil before they blow up. I think you will have to investigate farther. Good luck.
C-Rob
2000 SAN
lakedog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2012 at 6:07pm
could be condensation, Run it and check oil. dont worry it is a boat
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2012 at 7:00pm
thank you guys. If I run it and check the oil, what would I look for?
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2012 at 7:49pm
Keep searching the old threads There is one that lists things to check in order before the block relating to water in oil. Head gaskets and manifolds two of many other possibilities.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2012 at 8:18pm
I would be looking for some nice gold colored oil. Not the kind that is milky white.
Actually I would probably be praying not to find the milky white stuff.
Mike
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2012 at 3:29pm
I'm guessing I should run it for a few minutes, then check for "milky white" oil, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2012 at 4:22pm
It would be nice to run it for a while and get it good and hot to steam out any condensation that is in there. I guess you changed the oil?
If you have fresh oil in there and run it a while till it's hot and it shows up like a milkshake on the stick, then you probably do have water intrusion from somewhere.
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2012 at 10:08pm
Which way did you hook water up to it so you could run it?
Lakedog55
