  New Posts New Posts RSS Feed - 331 stroker
331 stroker
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Topic: 331 stroker
    Posted: August-01-2006 at 8:57am
want to build a low end torque motor,anyone had any dealings with the 331 or 347 strokers being turned rev. rotation. have all the goodies on my pcm 302,carb.intake,dist, want to build a long block and swap out engines. any help guys????????????????????
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2006 at 9:35am
I wouldn't recommend the 347, the second oil ring is compromised for the piston pin, oil consumption and shorter longevity would result. The marginal rod/stroke ratio gives high side loading, that would be tough on a marine application.
River Rat to Mole
