  New Posts New Posts RSS Feed - Stuffing box gone amuck
Foot_Fungus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Topic: Stuffing box gone amuck
    Posted: April-05-2012 at 10:00pm
So today's task was to repack the prop stuffing box. However, what seemed to be a simple task was made infinitely more difficult by the lack of or improper maintenance. So I start off by loosening the hose clamp on the box side of the rubber hose so I wont accidentally torque it while tackling the 2 giant nuts. Silly me says gee lets take the other clamps off and spin it around just to check for condition. Well turns out on the under side there is a giant rip where someone had tried to remove the nuts without undoing the hose clamp, so when they twisted they twisted and ripped the hose at its midpoint. Someone got creative and "patched" it with rtv.
No problem I say I'll cut it off and put on a new one. So I cut it off and go to undo the 2 lock screws on the shaft key to slide the shaft off enough to put on the new hose. MFers are rusted in like no tomorrow. After an hour of soaking them with pb blaster, repeated hits with heat and ice water, and the biggest vice grips I own I can't even get them to budge. And of course the whole time I'm thinking well thank god the safety wire was on there they might of come loose on their own!!!
So I've admitted defeat and looks like I'm going to take it to the boat mechanic tomorrow and let them charge me a fortune to get them loose. Well unless anyone has any bright ideas.
lakedog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 12:39am
What year boat? And which shaft coupler do you have?
Mike
Lakedog55
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 1:11am
Yep, stuffing box can be a hassle...i've also got a 75 v-drive century, packing nuts directly underneath the transmission & completely invisible. Try it by feel only, with a mirror.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 8:34am
The coupling to the prop shaft is a heat shrink fit (.000" to -.001") Unless the coupling is fretted due to bad alignment, it will not "slide" off the shaft. The set screws are easy compaired to removing the coupling. However, "vise grips" would not be the tool of my choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 8:40am
I somehow got elected to pull 6 bearings on a 16 car ferry, 30ft shafts, they are not incased in bronze, I had the welders make me a puller with 1.125 all thread, they are 24 inches long, this is day three and i have the 2 worst ones two pull yet....I really thought i knew what a hard days work was, until now. my wife keeps asking why its so hard, you have always worked on boats, instead of using a 9/16ths wrench, im using 3" wrenches. and at times hooking a comealong to the wrench to break a bolt loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 8:42am
oh fck Pete, i had to bring in a 50 ton cylinder to pop these couplings, this place is kickin my ass, the props were stamped 486 lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 8:48am
what did i get myself into?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 8:53am
Does she expect you to start to show signs of your age?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 9:09am
i can still pound nails with it Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 11:33am
Eric - there was a reason they hired you, not everyone can do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 12:37pm
yea trust me vice grips are NOT my tool of choice and rarely leave my tool box. Unless I've done my research wrong won't I be able to use the socket/threaded rod trick to get the shaft out once I remove the set screws??? I let them sit in pb blaster over night so I'm going to give it a final shot later today and see what happens.
grim007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grim007 Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 12:54pm
question, would a pipe repair clamp(stainless steel wrapped around rubber ) fit in the box over the hose without the clamps on and if it did should i put one tool box for an emergency fix, grims
shaken not stirred
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 7:55pm
grimm i was just thinking about the same thing. Tackled the set bolts again today and snapped 1 clean off it was so rusted in there. So I'm left with either dropping $500-600 for a new prop or finding a way to repair the rubber hose without removing the shaft.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 8:30pm
Maybe drill out the broken set screw, then proceed with the PITA process of removing the coupler, then re-tap for bigger set screws? Other than that, sawzall and new double-taper prop shaft?
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 10:23pm
You could hoist up the engine & pull the shaft from the inside. would be extra work but cheaper than a new shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grim007 Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 10:42pm
at work we use the repair until we need to remove everything last resort kind of thing
shaken not stirred
bfedio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfedio Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 10:44pm
Damn I'm new to this forum, but joined because I need to tackle the packing in my 97 super sport. Just looking at where it is, thought it would be nice if it could slide out the bottom to access. guess i'm goin in. I'm the only owner and have never had an issue before. noticed the past few year it took on more water over night. Now the bilge cant keep up. figured I'd do the drive shaft and rudder. any tricks??????>
gtxragtop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gtxragtop Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 1:33am
You will need to drill out the set screw. If your lucky, it will then come out with an EZout. If not, then you will need to buy another coupler. I just when through this on my 96 ski nautique. I soaked the shaft/coupler with PB Blaster for 3 days. Added heat, tapped with a hammer with no luck. I then mounted an automotive harmonic balancer puller on the coupling and heated the coupling up with a blow torch. It moved very slowly and I needed to keep the coupling hot. It finally came of. Replaced the packing and took 220 sandpaper and cleaned out the bit of corrosion in the coupling. Was not much to remove. It then slipped right on/off again like butter. Amazing what 10'thousands of an
inch of corrosion will do. I though that I would put it together with
anti-seize but then thought... Bad idea, I don't want movement. Used one of these tightly mounted to the coupling.
http://www.google.com/products/catalog?hl=en&sugexp=frgbld&cp=18&gs_id=39&xhr=t&q=harmonic+balancer+puller&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1400&bih=858&um=1&ie=UTF-8&tbm=shop&cid=3562934389496767239&sa=X&ei=S6d_T_2ML4H30gHVi9zbBw&sqi=2&ved=0CG8Q8wIwBA
1996 Ski Nautique GT40
Worcester, MA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 12:18pm
The coupler needs to be a press fit. If it slipped back on to the shaft without heating, the shaft may come loose under load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 1:09pm
+1 on this one. Lot less work involved then pulling the motor out just to get the shaft out and a heck of a lot cheaper than buying a new shaft. I know there is a thread here somewhere where Fans used a ATF/Acetone mixture (?) with great results instead of PB blaster etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 1:47pm
Ok So after doing some research I'm down to 3 options. I ruled out the rubber hose patch idea bc its just not worth the risk, and I'd constantly worry about it.
1. Drill out the set screws and then tackle popping the shaft out of the coupler. ($5, but will probably take a weekend after all is said and done)
2. Slice the coupler long ways and just buy a new coupler($85 and about 2hrs to slice through it)
3. Cut the Shaft and buy an ARE double taper($450 and 2hrs to cut through SS)
SO now I just need to evaluate how much my time is worth and if Id rather waste money or waste my time. This also would drain my ACME 422 prop fund. Not even sure #2 is possible, just an idea I had that it had to be softer than SS. #1 may backfire as this boat was in salt water for about 2 years so I'm thinking the coupler may be a solid block of rust. I'd love to hear other people's thoughts on the matter.
On a side note after noticing brand new shiny engine mounting bolts where everything else is dirty/rusty it appears this sucker had a new engine put in or atleast, which would also explain why it says EFI on the side of the boat but has a newer carb on it.
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 2:58pm
Option 4....Call GZ and get him to take care of it. I think that'll be the most cost and time effective option and it'll be done right.
Steve
2011 Sport/Air 200
Excalibur 343
Former Malibu owner (07, 09)
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 3:24pm
if you opt to cut the shaft, use a cut off wheel, dont mess around with a swazall....5 minutes, really, what happens if you spend the weekend d*cking with the set screws only to find out the shaft is whooped? the ARE is the way to go
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 4:12pm
First we learn, then we learn to do it right.....
Any halve assed repairs below waterline are indeed STUPID...
Either remove the engine or cut the shaft...
This is not that hard a repair, why not do it correctly ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 5:06pm
NG,
Chris is correct. You have a problem just waiting to happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 10:35am
Pete, just to let you know, i was cutting out phenolic bearings, i brought my chain saw in, worked very well, its a whole new ballgame with these big bastards, looking from the back of the boat the port was worn down to the metalat the 5 o'clock positon and the starboard was worn at the 7 o'clock...alotta armchair qauterbacks....not one of them yet got up in the boat to ask about the alignments yet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 10:37am
personally i think it's the bearings causing the problem or they have welded the shafts in the past and they have the paperclip effect
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 11:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 11:16am
all relevent
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 11:44am
Steve, still waitin on you to send me his contact info.
Boat Dr. in my post above I had already ruled out the 'shade tree' repair, all I'm currently debating is slicing apart the coupler or the shaft.
