  New Posts New Posts RSS Feed - epoxy resin reaction
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2012 at 3:12pm
Fair enough Pete - I poked at your steamer, what goes around, comes around!
Straight from the Brunstucky Skool of Cobble:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2012 at 3:55pm
Pretty Slick Chris. Now that is thinking outside of the box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2012 at 4:01pm
Chris,
Cool! However, I sure hope no one from NIOSH sees that thing! At least I didn't have to worry about any agency issues with my steamer - I doubt the state fire marshals division of boilers would be too concerned!
connorssons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 2:18am
Go Vinylester! No proublems for me!
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 8:58am
SAFETY DATA SHEET Revision Date: 03/31/2008
Print Date: 12/7/2009
MSDS Number: R0402382
DERAKANE MOMENTUM® 411-350
EPOXY VINYL ESTER RESIN
40210
Version: 5.3
1. IDENTIFICATION OF THE SUBSTANCE/PREPARATION AND OF THE
COMPANY/UNDERTAKING
Ashland Regulatory Information Number 1-800-325-3751
P.O. Box 2219 Telephone 614-790-3333
Columbus, OH 43216 Emergency telephone 1-800-ASHLAND
(1-800-274-5263)
Product name DERAKANE MOMENTUM® 411-350 EPOXY VINYL
ESTER RESIN
Product code 40210
Product Use Description No data
2. HAZARDS IDENTIFICATION
Emergency Overview
Appearance: liquid,
WARNING! FLAMMABLE LIQUID AND VAPOR. MAY AFFECT THE CENTRAL
NERVOUS SYSTEM CAUSING DIZZINESS, HEADACHE OR NAUSEA. MAY BE
HARMFUL IF INHALED. MAY CAUSE EYE, SKIN AND RESPIRATORY
TRACT IRRITATION. PROLONGED OR REPEATED CONTACT MAY DRY SKIN,
CAUSE IRRITATION AND BURNS.
Potential Health Effects
Routes of exposure
Inhalation, Skin absorption, Skin contact, Eye Contact, Ingestion
Eye contact
Can cause eye irritation. Symptoms include stinging, tearing, redness, and
swelling of eyes.
Skin contact
Can cause skin irritation. Prolonged or repeated contact may dry the skin.
Symptoms may include redness, burning, and drying and cracking of skin, burns and
other skin damage. Passage of this material into the body through the skin is possible, but
it is unlikely that this would result in harmful effects during safe handling and use.
Page 1 / 10
Page: 2
40210
Version: 5.3
Ingestion
Swallowing small amounts of this material during normal handling is not likely to
cause harmful effects. Swallowing large amounts may be harmful. This material can get
into the lungs during swallowing or vomiting. This results in lung inflammation and
other lung injury.
Inhalation
Breathing of vapor or mist is possible. Breathing aerosol and/or mist is possible
when material is sprayed. Aerosol and mist may present a greater risk of injury because
more material may be present in the air than from vapor alone. Breathing small amounts
of this material during normal handling is not likely to cause harmful effects. Breathing
large amounts may be harmful. Symptoms are not expected at air concentrations below
the recommended exposure limits, if applicable (see Section 8.).
Aggravated Medical Condition
Preexisting disorders of the following organs (or organ systems) may be
aggravated by exposure to this material:, respiratory tract, skin, lung (for example,
asthma-like conditions), liver, central nervous system, male reproductive system,
auditory system
Symptoms
Signs and symptoms of exposure to this material through breathing, swallowing,
and/or passage of the material through the skin may include:, metallic taste, stomach or
intestinal upset (nausea, vomiting, diarrhea), irritation (nose, throat, airways), central
nervous system depression (dizziness, drowsiness, weakness, fatigue, nausea, headache,
unconsciousness) and other central nervous system effects, loss of coordination,
confusion, liver damage
Target Organs
Overexposure to this material (or its components) has been suggested as a cause
of the following effects in laboratory animals:, mild, reversible kidney effects, effects on
hearing, respiratory tract damage (nose, throat, and airways), testis damage, liver damage,
Overexposure to this material (or its components) has been suggested as a cause of the
following effects in humans:, mild effects on color vision, effects on hearing, respiratory
tract damage (nose, throat, and airways), central nervous system effects
Carcinogenicity
There was no increase in cancer in rats exposed to styrene by inhalation.
However, there was an increase in lung cancer in styrene-exposed mice. The relevance
of the mouse lung cancer to humans is uncertain. Styrene did not cause cancer in mice in
Page 2 / 10
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 9:32am
Ok how about wood then. Just joking! on the vinylester.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 9:55am
Wood alergy chart
But, only 2% will have a reaction to eveb the "bad" woods. I've done several projects with Cocobolo (4 star rated) and never had a problem. Even my last project (rolling pin) was on the lathe where when sanding you get all the fine dust. I didn't even bother putting on one of my 3M dust masks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2012 at 12:53am
Pete! a CC rolling pin, how cool! just picture it with an old script CC badge attached! ill take a batch of those cookies.
