  New Posts New Posts RSS Feed - 85 2001 LVL Stringer Project
 Post Reply Post Reply Page    <1 678910 13>
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2012 at 9:56am
Kris - maybe a glass removable floor section is in order!
You really set the bar high!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2012 at 12:12am
Nice work Kris
Big Pappa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2012 at 2:54pm
I wanted to be laying carpet this weekend but the place I was going to get my glue from sold all that he had just a few hours before I got there last week. Good news is he is supposed to have more in tomorrow so I will be laying carpet next weekend.
Since I could not lay carpet it was time to work on cleaning up the engine and getting it ready to be put back on the boat. I started with making a booth for sand blasting in to contain the sand and keep from making such a mess in the driveway and getting sand all over the place. It is just a 1/2" pvc frame with poly over it. It worked great!!
Then it was on to pulling the engine mounts so they could be blasted and painted. Plus since I am sure I am going to have to do a good bit of adjustment to get my alignment right I wanted to make sure things were as clean as possible so that the engine could be adjusted as easy as possible. I must say the front mounts had a lot more adjustment than I thought that they did!!
Next it was on to taping up the engine.
I had quite a few places where there was rust on the engine and I did not want to completely disassemble the engine so I could blast, or sand them all down. So I took my air grinder and knocked off as much as I possibly could (Pictures above was after this and ready for paint) then I shot on some primer that converts rust so that it is safe to paint over. Here is the engine after being painted with the rust primer.
After getting the engine painted it was on to sand blasting. I was able to get one of the exhaust manifolds and a front and rear engine mounts blasted. By then it was time to clean up. I am shooting to finish up blasting the mounts and get them all painted as well as getting the engine painted. Then I will be ready to put the carpet in this weekend.
I also have my engine cradle back from being repaired so as soon as I get the engine painted I will get the cradle installed. I am nervous about drilling a bunch of holes in my brand new stringers!!! Then I can lay the carpet and start getting ready to put the engine back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2012 at 2:58pm
By the way those are old plugs that I had from when I painted the engine for my bronco (Same 351W). My good plugs are sitting safely waiting to go back in after painting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2012 at 3:02pm
That would be awesome!! Thanks
Originally posted by NCH20SKIER NCH20SKIER wrote:
Nice work Kris
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2012 at 4:45pm
I went out and put a coat of paint on the engine yesterday afternoon and will put the final coat on tonight. I am also going to continue sand blasting this afternoon and hopefully get the mounts finished being blasted so I can start painting them and get them back on the engine so it is not hanging on my engine lift any longer.
That bring up a question, when I re assemble the engine mounts do I need to put any kind of lubricant or anti seize on the shafts going to the mounts on the block?
I made Discount Inboard Marine happy this morning placing an order for a bunch of hoses, gaskets, bolts, maintenance items, etc... so I can get everything put back together. Should be like christmas around the house in a few days.
Stay tuned I will post up more pictures soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2012 at 9:41pm
Be careful sandblasting.I'm assuming your standing inside? Wear a really good resperator and tell me your not using regular sand.You don't want to get this
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2012 at 10:00pm
Yes, Silica sand is big time bad!!
Today I just dumped the first batch of abrasive I had in my blast cabinet. It was Black Beauty. Very cheap but it does wear out. I refilled it with 36 grit garnet and will see how long it lasts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2012 at 10:08pm
I am sanding outside in this enclosure I made. 6' X 4' X 6'
I am using a small blast gun so I have to stop often to let this air out and to help keep my compressor cool.
To answer your question yes, I am using a 3m respirator with prefilter and a pair of goggles or a full face shield, along with 3/4 sleeve gloves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2012 at 10:10pm
I thought of making myself a cabinet but I did not want to take time away from trying to get the boat completed to do it. I will build one one of these days and make blasting a lot more simple!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2012 at 2:03am
Kris when it's time this place has info and parts for kits. I have had one of their built ones since 94 and could not be happier. Build the biggest one you can,you'll never know what you want to put in there. As for the media I have used everything but plastic and walnut shells. For aluminium I like glass beads, for rusty steel I like the silicon carbide followed by the glass beads. Silicon carbide does last longer but does wear out your nozzles and if not caught in time will go thru it and start eroding the gun too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2012 at 10:11am
I bought my cabinet off ebay. It was only about $125 including shipping. However, it was a cheapy made in China but works. The only issue I've had is the O rings in the gun getting dislodged. It was also a PITA putting it together especially since the first time I put the top with the window on upside down. That required me to unscrew what had to be half of the 500 screws/nuts that come with it!
The garnet seems to be cutting about the same as the Black Beauty. I'll see it to stays sharper longer.
My gun came with ceramic tips. Unless the steel tips are carbide or Stellite, the ceramic will hold up longer.
Gary,
My next step in media will be the silicon carbide. The cost is a real kicker though!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2012 at 11:23am
Gary,
Yes it is expensive Pete but lasts much longer, so I bought a abrasive reclamer,it mounts on the side of the cabinet.I do use a carbide nozzel but silicon carbide media will still wear it out,just not as fast.I do use ceramic nozzles for back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2012 at 7:19pm
Awesome thanks for the info guys!! I will definitely be looking into these for my cabinet in a few months!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 3:10pm
I was able to get my engine mounts put back together last night after blasting and painting them over the last couple of days.
Then installed them back on the freshly painted engine.
I also bought some of this stuff, Roberts Temporary Carpet Protection, to go over my carpet once I get it installed for a little protection until I get a little closer to being finished. As I was in the boat last night I decided to put a layer down to see if it would protect my bilge from scratches and things until I had the engine and rear floor in. I think it is going to work pretty good.
I wish I would have had this stuff when I started and covered the entire top of the boat from the windshield to the Transom and the tops of the trailer fenders. That would have saved me a lot of clean up that I need to do now.
Finally I started cleaning up the Carpet trim to see how hard it was going to be and it went pretty quick, to my surprise. The key is to have ample acetone on your rag as you rub it down!! I took a 5' piece and went from this.
To this in about 15 minutes.
My carpet glue is supposed to be in today so that means that tonight and tomorrow is all about getting the carpet installed in the boat. Once that is done it is time to start throwing parts at the boat getting everything installed in preparation of putting the engine back in next weekend.
Anyone have any last minute carpet installing tips for me?
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 3:20pm
Make sure you leave 4-6" of carpet unglued around the edges where you'll put the trim. Once the trim is glued to the carpet then you can actually glue the remaining carpet down. Other than that, it's pretty straightforward.
What did you use for a silver top coat? We're priming with Cast Blast but need to source something that's close to the original silver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 3:22pm
Looks fantastic BTW. Top notch work there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 3:29pm
Thanks!!
I used this stuff. Rustoleum Engine Enamel I think it is the cast aluminum color. It is a little lighter than the stock color but I like it.
Thanks again!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 3:34pm
Also does anyone know of a source for the decals on the valve covers? One says Pleasure craft and the other has timing info on it.
When I was unmasking the engine the one that says Pleasure craft pulled off about half way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 3:47pm
Tim said that DWcar can get them or has them. I haven't looked into it yet, but we're about ready for them as well.
I'm headed to the river now, maybe Tim or DWcar will see this thread. Otherwise, I'll inquire over the weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 4:21pm
Wow, great work. I need to repaint my engine this winter and fix a leaking rear seal. You may want to consider changing your damper plate out since you have the motor out of the boat.
More time and more money, but I would change it.
Great build
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 5:06pm
Great build
Donald
Thanks!!
Is there a way to inspect the damper plate? I have spent quite a bit on this project so far and would rather not just throw more money at it if I do not have to. (Looked at skidim and looks like a new plate is around $200) What kind of life expectancy do these have? The boat has a little under 800 hours on it right now if that helps.
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 5:20pm
its probably about time. You can get them cheaper from ebasicpower.com, skidim is over priced. I think I paid like 90. Check the springs and housing for cracks specifically. There was a recent thread with the part number. I forget what it is right now.
cphase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 5:25pm
Try this Link BP.
Thanks,
Jeff
82 SN
Arch Linux
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 5:32pm
Thanks for the links guys. This is the tag on my trans, I just want to make sure to get the correct part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2012 at 6:02pm
Oh and just a note, the picture above was before painting. It was a pain to get that paint off the tag without removing the tag paint. It now looks clean as you can see in a picture above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2012 at 11:30am
Kris,
A tip I picked up over on the OWWM.com site since they are always dealing with old tags is to soak the tag overnight in water and dish soap. The paint will come right off without removing the original dye/paint on the tag itself. I truly believe it would even work with Eric's "deluxe" trans rebuild when he even paints the tag for you!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2012 at 12:20pm
Well, I'm off to try out the silicon carbide. I'm not happy with the garnet I just refilled the cabinet with. I don't feel it lasted as long (stayed sharp) as the Black Beauty. Plus, ether it's the humid weather or the garnet absorbs more water moisture. I'm having clogging issues in the gun and suction tube. I'm also finding that it takes more PSI to do the job. It sure will be nice when I get up north with a good true 5 HP compressor and the refrigerated air dryer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2012 at 12:42pm
Kris,
Good to know, Thanks for the tip!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2012 at 12:43pm
Let us know how things go.
