$600 (+-) Oil Change |
Page 12> |
84 BFN ![]() Newbie ![]() Joined: August-02-2007 Location: United States Status: Offline Points: 22 |
![]() ![]() ![]() ![]() ![]() Posted: July-17-2012 at 3:08pm |
Hi:
I’ve been trying to remove what’s left of my oil filter for 2 weekends. My boat is a 1984 Barefoot with a 454. When I attempted to remove the oil filter, it essentially crushed when using the oil filter wrench. The oil filter body was about as thick as or maybe a tad thicker than a aluminum can. Long story short and about $100.00 later the only part left of the oil filter is the base. I took the boat to a mechanic and he said that he’s going to have to pull the engine loose ($600 +-) in order to get to the filter. Does anyone know of a better alternative - other then dynamite? Thanks. |
84 BFN
Longwood, Florida |
Wow. Who installed the filter, Superman?! I guess that makes a good case for only installing it hand tight.
I cant think of anything else that would be helpful- now that the body of the filter is gone, youve lost pretty much all your leverage. No way would I be paying anyone $600 to pull my engine out of the boat. With the right tools, its a quick and easy job. Hopefully that amount includes engine removal, oil filter removal, engine reinstallation and alignment, if it does come to that. Where are you located? Add your location to your profile so others can see- maybe someone close to you has a helpful idea. |
I'm guessing the 454 filters are a little tougher to get to than the 351s?
When this type of thing happens in Auto repair, guys would take a blade type chisel, and set it at an angle. Then tap, tap, tap to bite in a little and put some rotation. It requires a skillful hand. |
The filter location on the engine isnt really any more inaccessible on a 454 than a 351w... but the v-hull boats like the BFN have their engines set down on the primary stringers, which are 6" lower than the floor. It can make access a little more difficult.
rcthorpe ![]() Groupie ![]() Joined: February-28-2012 Location: Gobles, MI Status: Offline Points: 45 |
Post pictures. It might be interesting to get some ideas once we can take a look at it.
I’m located in Longwood Florida.
The location of the filter gives almost no leverage. I tried getting a screw driver on the base but the oil filter location on the block has about a 1” lip around the filter. The way my luck is going, if I attempted to pry a edge of the base down I would probably end up cracking the block. |
84 BFN
Longwood, Florida |
That's why I don't go to any of the Uncle Jiffy oil change places anymore. I have damaged a few oil filters removing them after a gorilla with an impact wrench and prybar tightened it on at the lube shop.
89Martinique ![]() Senior Member ![]() Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
this is why you oil the rubber ring for the oil filter! who ever installed the oil filter didnt oil the ring and now its a b!tch to get off. good luck
But when you get a new filter. OIL THE RUBBER SEAL!!! |
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
grim007 ![]() Groupie ![]() ![]() Joined: January-09-2012 Location: portagelakes oh Status: Offline Points: 57 |
On top of filter are small drain holes, i had to place two screws in holes 180* apart and used a screwdriver to twist out the piece that was left, i don't know if you have the clearance for something like that, good luck and keep your patience.
shaken not stirred
NEDLUTZ ![]() Groupie ![]() Joined: November-26-2007 Location: Seekonk Ma. Status: Offline Points: 69 |
I had this happen on my 87 BFN,and we used a pair of needle nose pliers and a screwdriver.(use a pair pliers that you don't want to keep, because they might twist depending on how tight it really is.)
Is the oil filter outlet on the block completely open? It seems like there is a cross pattern (best way to describe it)- at the base of the block oil filter opening and the oil filter base sits on that. I like the pliers method - but am concerned about the opening in the block.
84 BFN
Longwood, Florida |
In regard to the needle nose pliers: If a needle nose pliers is good, a needle nose Vise Grip might be better:
Dreaming ![]() Platinum Member ![]() ![]() Joined: May-21-2010 Location: Tacoma, WA Status: Offline Points: 1870 |
Pictures would definitely be helpful, but without seeing your situation, i would suggest a pipe wrench. maybe a strap style wrench would work as well?
cloth type strap wrench |
![]() this is what it should look like. |
If worse comes to worse & you have to pull the engine, it can be done for far less than $600. You can rent a hoist at a rental shop for maybe $50.
It would be a full afternoon of R&R, but you would get to clean under the engine! |
Crud! I didn't want to do this! All this hassle for a stupid cheap a#$ oil filter! Would I have to re-align the transmission?
84 BFN
Longwood, Florida |
Fl Inboards ![]() Grand Poobah ![]() ![]() Joined: January-20-2008 Location: United States Status: Offline Points: 2077 |
Call my friend Bull 407 855 2115. He has B.I.M.P mobile ski boat repair in Orlando. He is also known as Mr. Bigblock as he has one of the coolest blown drag drop top camaro's in Florida. I am sure he can get the boatback up and running oil filter and all.
Chances are yes. |
harriss28 ![]() Senior Member ![]() ![]() Joined: July-24-2010 Location: Titusville PA Status: Offline Points: 128 |
Would it be possible to have someone weld a big nut onto the remaining piece of the filter. Then the filter could be removed with a socket.
Yea! Lets "Weld" on it while it is in the boat!! ![]() Sorry! No welding in Boats!!! Fiberglass does not weld well but it does burn nice and hot! |
oldcuda ![]() Senior Member ![]() Joined: June-22-2010 Status: Offline Points: 474 |
Just use a 4x4 with a block on one side and a bottle jack on the other side and a chain in center to lift back of motor/trans enough to get access to whats left of filter.This way you only have to take two big nuts off rear mounts and loosen fronts and of course coupler to propshaft.This way you leave motor mount bases alone and alignment is minimal.Usually get a grip on whats left of filter with a pipe wrench.If I was going thru this I would be installing remote oil filter at same time.very easy with this motor and never have this problem again
64stang ![]() Newbie ![]() Joined: June-25-2012 Location: Wisconsin Status: Offline Points: 38 |
Make a tool. Get a new filter with the same drain hole spread diameter on the base. Now take a nut and weld it onto a 3-inch plate and then weld 6, 2-inch rods onto the other side of the plate using the new filter as a guide. The length of the rods depends on how much of the threaded feed is sticking out of the block. The shorter the rods the stiffer the tool will be. Now take that tool and remove the old filter base, it will have enough purchase easily. Considering the cost of this tool, I would never remove the motor if I did not absolutely have to.
ononewheel ![]() Gold Member ![]() Joined: June-21-2011 Location: B Status: Offline Points: 776 |
If this method does;nt get it off the block, you are not doing it right. Long chisel? Get that plate to bend even, and you are almost home. I have used a chisel to cut from the holes toward the large threaded hole, started tearing the plate, and it will loosen before you have to tear into the threaded part. Oh yea, I swear and get mad. 20 MF'ers and that filter is good as off. If that doesn't work, I'd take it to the oldest longest standing auto shop in town(not a dearship), talk to the guy that has turned wrenches for 25 years, get him a bottle of his favorite booze, $50, and you will be boating in a couple hours. He has the tools, knowhow and this is minor compared to the crap he deals with everyday and doesn't get to charge boat yard prices. |
If we let the professionals do everything it takes all the fun out of youtube
OverMyHead ![]() Grand Poobah ![]() ![]() Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
So, what brand was the filter?
1987 Ski Nautique |
The oil filter was a generic POC.
This is the tool that I purchased on the internet. It had another piece which I eventually removed. I found that the holes for the bolts line up with the holes in the oil filter. I’m using hardened bolts and they are bending or breaking. I think that there is a partial obstruction in the opening of the block. I originally used bolts that were going into the oil filter holes about 1”, but it seemed that they were getting hung up on something inside the block opening. I have since shortened the bolts so they are going into the oil filter only (about ¼” +-). Now it’s a real pain with almost zero leverage. ![]() ![]() ![]() |
84 BFN
Longwood, Florida |
Maybe take a hacksaw blade and slip it between filter and block.The more seal you can cut the less it will take to turn it.I know fire and boats dont mix but I have cut rubber seal with a red hot razor and filter base spins right off
if you haven't gotten it by now just call Bull
I would be concerned about a hacksaw damaging the flange on the block!
Thanks, I called Bull & left a message.
A hacksaw wouldn't work. There is a 1" flange on the block that encompasses the oil filter base, plus I'm really paranoid about damaging the block. This job should've taken an hour tops. I'm now going on my third weekend… |
84 BFN
Longwood, Florida |
Hang tough man and don't do anything rash that will cost you more. you'll get this and be boating soon!!
shaken not stirred
Page 12> |
