  New Posts New Posts RSS Feed - SN 176
SN 176
 Post Reply Post Reply Page    <1 234
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 8:42am
Ken,
Once again, I'n glad it worked out for you. Using the Dremel must have taken a few! If you ever get somthing from one of the cheap import tool places like HF or NT, tack on a hole saw kit. They aren't expensive and will come in handy.
For exiting holes that need enlarging, you use this arbor adapter with two hole saws.
I'm surprised White Lake didn't suggest it but I guess they don't have one ether and just grind out the holes. with a "pro" marina!
kmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmac Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 8:25pm
That is a great idea. I love the small diameter hole saw being threaded upside down. Wish I had done that.
kmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmac Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 8:30pm
kmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmac Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 8:32pm
Not the best picture but the older port is on the left. Can sort of make out the size difference between the two.
kmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmac Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 8:59pm
The guys at White Lake were a big help. I don't think any of us expected the difference in outside diameter. I know they would have used a proper hole saw if they did the install - I think their point to me was that what I did with that crazy dremmel job would be OK!
kmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmac Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2012 at 7:39pm
Update:
Took the boat out and all was well. No water leaking through at all. Also the boat handled MUCH better. Nearly night and day between the two rudders. A lot of hoopla with changing out the rudders but I am glad that I did it. Thanks to all for their help
spring river footer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spring river footer Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2012 at 2:32am
would you like to sell your old rudder? thanks todd
kmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmac Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2012 at 6:27pm
sure. Would be happy to. The rudder is fine but the port would not be something you would be interested in in that it took a little work to remove it.
Ken
B_Bob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B_Bob Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 6:31am
Just bought a 96 ski nautique 176. Does anyone have pics of the back seat of an air tique 176 or know where I could get one?
Madcap View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madcap Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 9:27pm
Hi Brent -
Glad you are enjoying the boat. I have a '99 Air Tique, and the back seat is exactly as pictured here (from the brochure section of this site). I can get to my boat this weekend. Are there any other pictures you need?
'99 SN Air Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote B_Bob Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 11:20pm
Thanks MadCap. That back seat is pretty cool. I'm trying to figure out if i can modify my seat to do the same, or find one to install. How is it held up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madcap Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2012 at 3:07am
Ahh, I think I see the issue. Are you looking to modify the seat to convert to a sun-pad? I just noticed that your '96 does not have the armrests (which are not depicted at all in the brochure photos). If so, you have a bit of a project.
The armrests are hard plastic over-coverings surrounding a long and quite substantial L-stock aluminum brace underneath, which I presume is bolted to the interior cap. They are about 3" wide by 12" long. The padded upholstery is formed/stitched around, but not underneath, the armrests. The underside of the seat bench has tongue brackets that slide into the armrests, thus interlocking under the aluminum (there are slots in the face of the armrests into which the tongue brackets slide) while the bench bottom sits on top of the armrests, forming the sun-pad when raised.
The key would be to raise your seat and see if the width of the bench seat will overlap the hypothetically installed armrests. There should be little room from the padding of the seat to the padding covering the gunwale. From your picture of the '96, it appears that there is a taper or angle to the gunwales, so I am concerned there is too much of a gap. However, I can't imagine that CC changed the molds on these 176's at all over the years.
All that said, I rarely raise the seat to the sun pad position ;-). Without a backrest upon which to lean, it's a bit precarious up there, it's not level, and if you want ballast, people are better (and far more portable) than water sacs.
Goodness, I hope I was right about your question!
'99 SN Air Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madcap Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2012 at 3:40am
Perhaps a picture is worth a thousand words...
'99 SN Air Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote B_Bob Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2012 at 4:51am
Great info. Looks to be more trouble than it's worth, especialy if it's something rarely used. I was looking to put in a ballast, but may just make my buddies sit on the sac! Does your boat have a 3 blade or 4 blade prop? mine has 3 and pulls well, but top speed is'nt great and i seem to get some cavitation when turning hard to the left. I've read that switching to a 4 blade can help in these areas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madcap Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2012 at 10:31am
I have a 4 bladed prop, never any cavitation. We have the same engine, and it gets up to 42-43 WOT with 2 adults aboard and a full tank. That's plenty fast for what this boat is intended to do. I'm thinking of doing the rudder swap mentioned earlier in this thread, but really haven't had any complaints from short line slalom skiers, just complements. Their big heavy plate-dragging Malibu's are better for wake skurfing, but I always get the call when they want to ski. What a great little boat!
'99 SN Air Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote B_Bob Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 3:47am
Anyone have the numbers off the stock 4 blade on a 176? I have a stock 1996 rock'n the 3 blade.
watrski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote watrski Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 3:47pm
What HP in your 176?
Post Options Post Options   Thanks (0) Thanks(0)   Quote B_Bob Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 3:27am
It's the 351 HO so it should have 285hp
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 11:27am
You do not want a 4 blade prop for that boat to cure those issues. They were the hot ticket 8-10 years ago and that info is still out there, but it is now outdated. A modern cnc machined 3 blade would be the best solution. A 4 blade oj might have a slightly better slalom wake though.. typically at the expense of a littel top end and hole shot. Also.. 285hp if it is a 351HO. Great little watersports machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B_Bob Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2012 at 9:26pm
Thanks for the advise. Hard to know what to follow with so many opinions out there. Any recomendations on make, type of prop? i'm only doing about 38-40 mph WOT. pulls well when boarding and skiing. Also is it normal for the boat to be so loud at WOT. I've been on many boats, but this one seems excessive. Any idea why i have some vibration and noise when turning left, but none when turning right? Other than that I love the boat. Too much fun!
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2012 at 11:58pm
Not sure what muffler they would have put in the 176 but if it is the Hull Hugger like they put in the '96 SN's, they are prone to cracking and that may be your issue.
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
