Show Me Your Spare Tire Mount (early 90's SN) |
gsyogi
Senior Member Joined: July-04-2012 Location: Denver, CO Status: Offline Points: 109 |
Posted: August-24-2012 at 4:35am |
I purchased a '94 SN (shown on its trailer) and am having a spare tire and hanger mounted to the trailer on Monday (welded). I am looking for the proper placement. I thought I saw an earlier string on this topic; however, I was unable to locate it. As always, thanks in advance!
Also, does anyone have the precise specifications for the "steps" that originally sat in front of and behind the fenders on this trailer—I would like to make and replace these!? |
Brian,
I'm curious why you want the mount welded on? There are several bolt on aftermarket brackets available. I'd say the best suited for your trailer is the one that angles the tire outward so it would fit near the bow on the tongue opposite the jack stand just forward of the "ski Nautique" tag on the trailer. Take a look through the diary section. You'll most likely find some pictures. |
Brian,
Regarding the length, I know they are special to the trailer but I never realized they were 7 leaf. |
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
Just make sure you have enough length to it on the outrigger post. Mine is bolt-on RH side as far forward as I can get it and on steep ramps the bow of the boat will ride on it ever so slightly. I put metal on my side steps.
LilRichard
Groupie Joined: July-30-2012 Location: Tampa Status: Offline Points: 78 |
Hey - something we agree on! |
1989SN2001
Senior Member Joined: October-01-2010 Location: Canton, GA Status: Offline Points: 122 |
Here's mine. I like the way it is mounted, but not where it is. Everything is great until the truck and trailer are at more than about a 30 degree angle to each other, and then I can't open the tailgate. I'm going to move it this winter. |
dmiracle
Senior Member Joined: July-22-2008 Location: Johns Creek, GA Status: Offline Points: 300 |
Brian,
Regarding the steps, a lot of members on here have replaced them with diamond plate as a permanent, no rot solution. I personally prefer the look of the carpeted step so when I restored my trailer, I cut replacements out of doug-fir. I did mine in one piece which may or may not have been correct (the PO had already removed the rotted originals when I purchased). I don't have dimensions because the boat is up at the lake, but here are some photos. I also added 6 coats of spar varnish after cutting all holes, etc...before adding carpet. One thing to be careful with is the curvature angle of the very front of the step where it hugs the rail. I did not get mine perfect and there's a very minor gap there that's hardly noticeable with the carpet. Also, Ram-lin is still around and will sell you the original carpet and new fenders if you need them. You can find a bit cheaper elsewhere but they won't pass the Pete test :). |
Doug
dmiracle
Final install....
Doug
dmiracle
One more....
Doug
mdvalant
That trailer is beautiful.
pepatrick
Senior Member Joined: July-26-2012 Location: Cumming, GA Status: Offline Points: 102 |
Glad to see another Avalanche pulling a Nautique in Forsyth County..
gsyogi
Doug,
Wow. Your trailer is stunning! I would like to restore mine to look JUST LIKE yours ... any chance you could share how you got it to that point? Too bad you didn't make a template for those steps! I will see what I can come up with, but again, I am curious about the steps that you took to get that trailer to look like it does ... fantastic (feel free to PM). |
gsyogi
Peter,
I looked through the diaries ... great tip. Looks like there are several mounting options (I am inclined to prefer the position in front of the bow, directly across from the trailer jack). As for the welding, I have a "top notch" local trailer outfit that suggested that the welded option would perhaps be more secure? Any concerns other than increased cost with going that route. Alternatively, could you (or perhaps another CC Fan member) point me to a manufacturer or part # of a bolt-on mount? As always, thanks in advance! |
harddock
Do you know of one made for 6 lug rims. I know this could be re drilled but it would be nice to take one out of the box and use it. |
Kevin, Even though it doesn't state 6 lugs, the picture looks like there are 3 holes drilled at 120 degrees from each other. I give etrailer a call. |
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
http://www.etrailer.com/Trailer-Cargo-Control/Fulton/FHDSTC0101.html
Sorry about the lazy link. Bought this mount for my 93 Sport Trailer. Painted it black and mounted on the starboard side, up front under the bow. It was recommended by TRBenj and worked great for me. |
MartyMabe
gsyogi
Started work on my '94 trailer over the weekend ... my hope is to produce a trailer that looks as good as Marty's or Doug's; anyway, here is a picture of the cardboard templates that I crafted—next step marine plywood. I made a tracing of the templates on some craft paper if anyone is interested in them ... (my feeble contribution to this site as I am learning)!?
KRoundy
Brian,
I'd love a copy of those templates. I'll send you a PM. Kevin |
Dreaming
Bringing this thread back from the dead a bit... While Kroundy had these templates, I scanned them and made a CAD file/PDF copy of them... I don't think I can post them here, unless they can go in the reference section, but I am happy to share so you don't have to pay the $10 shipping. Since diamond plate would not want to hang over the edge of the trailer frame, this will likely work only as a rough template for that application.
Air206
I am VERY interested....... Need to adjust for a V drive setup.... 91 BFN. Thanks man! Steve Before: |
Dreaming
Steve - PM your email... its a pretty large file, if you have a fedex/kinko's or a large format printer, you should be able to get them printed pretty easily.
Trailer layout looks to be really similar to the pattern. |
Air206
Marty:
How did you do the Diamond Plate? I am toying with the idea of diamond plate ..... got my plastic bow stops already........ |
KRoundy
This reminds me - Brian, I need your mail address. Sent you a PM. I'm ready to return your templates, but your address was covered up by a sticker and I can't read all the numbers.
74Wind
I've got a v-drive, curious, why would one need to adjust for a v drive setup? |
1974 Southwind 18
1975 Century Mark II |
bhectus
Pretty sure the side steps are a little different.
Air206
We'll see - I now have the template...
The guide posts are different on the V-drive and I'll report on any other differences......... |
Air206
Ok after looking for a bit...... they are quite different back of the fender and the spacing b/n fender and bunk is much narrower........
I will work on a second template....... when the trailer comes back from blasting and paint, I need your help Dreaming.... scanning and digitizing...... |
Dreaming
Steve - No problem... I can scan and digitize; however, I'll need an original to do that from. If you can scan it locally and just email me a JPG file or a PDF file and some dimensions, it may be cheaper than snail mail for a tube of paper. I'm happy to do it either way. For others who go down this road in the future, I think it would be really helpful to have the outline of the trailer frame (for cutting diamond plate) and then a second outline for the overhanging wood/carpet style.
