Another BFN Rebuild |
Post Reply | Page <1 2627282930 31> |
No, but if I could find one big enough, Id slap it on. I suspect that little 11.5x15 2-blade that we tried on the Tique is better suited to the lighter boats that can get out of the water- but who knows. Since that prop seems to be comparable RPM-wise to the small boat props (12x13 OJ and 12.5x12 Acme 3-blades) due to its smaller diameter and minimal blade surface area, I suspect it will be waaaaay too small on a big block.
storm34
Well don't leave out this video....
kapla
nice sound!
wow that a dirty neutral! |
Bri892001
It's a scary fun ride
I was glad to see it (feel it, hear it) in action. |
TX Wind
Senior Member Joined: March-29-2011 Location: near Dallas Status: Offline Points: 334 |
Tim,
Enlighten me...wouldn't a 14" diam. prop get a better dig for the cavitation issue? |
TX Wind
For the record Tim, those videos are great. The sound of that 454 made tears come to an old barefooter's eyes. What a fantastic job.
The more blade surface, the better, when it comes to avoiding cavitation (so I would think) so yes, a larger diameter prop might help some. An increase in pitch seems to be more effective though- the 12.5x15.25 612 cavitates less than the 13x14 and 13x13 wheels.
No room to run a 14" prop though... the original 13x15 Federal was within 1/2" of the hull and left a lot of gel and rudder port damage. The 13" diam Acmes offer a bit more since their blades are raked back a good bit- but still less than 1". Starting somewhere around '81, CC notched the keel aft of the strut (by ~5/8") to allow the use of the 14" props. Most 454 BFN's made after that point came with 14x14's. |
wakeboardin2k4
Platinum Member Joined: December-14-2006 Location: Hopatcong, NJ Status: Offline Points: 1117 |
You guys comfortable with notching the keel?
We ran a 15x12 on an MXZ last weekend at a wakeboard competiton behind a LS3 corvette motor making 450hp....still can cavitate that thing. |
We added ~5/8" of glass to the inside of the hull in that area in case we want to notch the keel. But I'm not overly eager to tear the boat back apart just yet. There aren't really any rh 1" shaft props any bigger in diam than 13" in the sizes we're looking at, anyways.
15x12, that's crazy. That's a tiny prop for 450hp, even for a 1:1. I'm guessing that's a v-drive with some kind of reduction to boot? |
wakeboardin2k4
Ya its acme's newest prop for wakeboarding. Its a 1.52 I believe with the vdrive. It did 38mph on top end at 5500rpms. But we had that boat loaded with 1350 factory ballast, 2200 in fat sacs, and about 2000lbs in people weight plus the wedge down (theoretical 800lbs) So call it 5500lbs of ballast in a boat that weighs 5000lbs dry. Still got on plane like a champ!
TX Wind
Tim, I'd be interested in what you figure out. I have long term plans for the 67 BB that I have. We are looking at a build that will put out similar HP numbers to your 454. I thought that Mastercraft put out a 14x18 RH prop for the powerslot but I was mistaken. We have one of those lying around and they are LH.
The current setup on my 67 is actually LH. With the scarcity of the BB in those days its possible that Correct Craft put out a few LH rotation boats. I might be inclined to leave it LH. I was going to convert but sounds like it could be a bad idea? I think my prop on the 67 is a 13x16 but I haven't looked at it in a while. |
I've driven a classic CC with a LH prop and would not recommend going that route. Handling was quite disconcerting at times. An overpowered boat would give you more than enough reasons to be scared of going fast, I wouldnt add handling abnormalities from a LH prop into the mix.
wakeboardin2k4
Slap a 1.23 to that bizzzoat and then you can run standard rotation parts
(assuming theres room to accommodate the longer trans) I agree that would be preferable... Though the cost of the 1.23 (plus new shaft, prop, etc) isn't insignificant. Proper rh motors in these old boats are just plain cool though. |
tbeard
Senior Member Joined: April-26-2012 Location: Fort Worth TX Status: Offline Points: 379 |
Tim, Awesome project ....That motor hits like a muscle car! (A sound we all love) You did an awesome job....as explained through the thread the research, design and selection of engine components is as much work as the build if not more and it is nice to see it come together as planned. Very encouraging!
Thanks.......Tom
TX Wind
I can see your point Tim. I'd still love to know what you resolve. |
A few more updates and lessons learned as we enter spring of 2013...
1. The cavitation noted above was actually transmission slippage. A fresh rebuild this spring solved it, as well as the terribly dirty neutral shown in the video. 2. On/off nature of the secondaries is now resolved as well. As discussed here, we swapped to a different secondary diaphragm housing (with a pressed in brass insert) and went 2 steps heavier on the spring (white to purple) and we can hold any speed we want. 3. As Ive said a few times when people consider foamless stringer rebuilds, any drain point is also an intrusion point! Found a battery box mostly full of water this spring, so we emptied it. 10 minutes later, its full again. Strange, considering the boat was on the trailer... in the garage. Turns out that the (now drain-less) battery box was the low point every time the boat was stored on the trailer and lift (boat sits a bit nose-low) and thus, a good portion of the water that made its way into the boat drained to the battery box rather than the bilge. The bulkhead on the front face of the batt box (shown below) that was originally meant to be a drain point *just in case* any water made its way under the floor, did just the opposite and let water in instead. Apparently the o-ring seal doesnt quite work as advertised. ~40 gallons of water later, the boat seems to ride a bit higher in the water and has picked up a few mph. So, not all bad news. For now, we'll just be more careful to keep the nose higher when the boat is stored... but on future rebuilds, a few things would help prevent this from happening. Installing a battery box drain is one of them. Moving the drain access point to another (higher) location is another. |
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1423 |
Great update Tim....thanks for sharing
Lets have a go
DHart
Senior Member Joined: August-04-2011 Location: Maine Status: Offline Points: 239 |
What does that make your top speed now? 65ish? |
About time Dave, Tims been waiting all week for someone to ask that question
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
Someone else sort of quasi kind of asked that question earlier this week. I was going to provide what I believe was the answer based on a conversation Tim and I had at WL, but decided it was his place, not mine, to provide. Still true. |
DHart
He better brag about these top speeds while he can before a faster BFN pops up .
My guess is he's had the picture all loaded up on photobucket ready to link since monday morning.. and that he has a while before he has to look over his shoulder for another bfn.. .
75 Tique
"Will you still need me, Will you still feed me...."
Apparently Larrys info is out of date.. thats what he gets for leaving early
75 Tique
Figured as much...that'll teach me.
quinner
Larry, your a couple shy... more like where you get your kicks....
Ha, I was only semi-disappointed that no one had asked yet! I wasnt going to bring it up, but since Dave thinks our time at the top will be limited, we might as well enjoy it. Like CQ implied:
We'll see how repeatable that is... my guess is that White Lake was providing pretty optimal conditions with the fairly cool water and low altitude. A little chop, a full tank of gas and a few bodies in back didnt hurt either. Ran 66 on both runs we tried there- if we see a consistent 64.x at home this summer, we'll be pretty happy. |
storm34
Tell us about how it handled at those speeds?
Ready to hunt down some big rollers on Green Lake again? |
DHart
Wow that must be a thrill! Have you experienced any undesirable behavior running fast? Would love to see a video of a speed run if one exists.
