  New Posts New Posts RSS Feed - Dash pod questions.
Dash pod questions.
ononewheel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Topic: Dash pod questions.
    Posted: November-20-2012 at 4:12am
If anyone knows, it is you guys.
If we let the professionals do everything it takes all the fun out of youtube
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 7:24pm
Too late.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 7:32pm
I suspect it has more to do with the dash change that occurred between 1993 and 1994 (on all models).
What kind of shape is that '93 dash in? I may be interested if it wont work for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 8:07pm
Yea
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 8:10pm
Oh,   I scored an old airguide from the scrap yard, one I have not seen before.   I got to get that pic up somehow. It's got red on the dial.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 8:17pm
Check Nautique Parts.com which is White Lake Marine in White Lake NC. I was on there site last night and I saw many replacement dashes. However, I did not see if they have what you need.
Donald
N2Deep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N2Deep Quote  Post ReplyReply Direct Link To This Post Posted: November-22-2012 at 1:12am
If TRBenj doesn't take the dash I really need one for my 91 SN - let me know and I will take it.
Thanks,
Craig
1991 SN pulled by a 2010 Tundra
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: November-22-2012 at 2:34am
Wow, I would have guessed they were the same.   There was a guy on PN who made a mold for a 93 SN dash and made one out of fiberglass. I've always liked the idea, just a bit time consuming, i guess that might make a good winter project for you. What part didn't work out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-23-2012 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-23-2012 at 8:37pm
Ironically, the dash pod might be the only thing I cannot replace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 3:26pm
This might be the only thing to do then short of buying a boat.
The car audio guys build a basic frame for things and cover it with felt or spandex to get the shape they want and them coat that with resin to make it hard. Once you have that they you can lay some fiberglass on it until you get it solid enough to do the job. That may take a little time and sanding to get it right, but you have one to look at to get started. Depending on how perfect you want it you could either use that or go a step further and make a mold from it and make the final version out of the mold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 6:38pm
I believe Kristof made his tower speaker housing that way too.Turned out real nice.
River Monsters View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote River Monsters Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2012 at 10:43am
Anyone have a fix for the mounting holes on a dash pod that get torn out? I have a nice dash pod, but the mounting screws are all torn out. Seems like that could be fixed without replacing. More of a nuisance than a big problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2012 at 12:50pm
Mine have a small metal insert rivited in the dash that act as the threads. It shouldn't be terribly hard to fill the holes and drill new holes for some new inserts. Might even be possible to use some T Nuts behind the dash, I haven't looked into how thick the glass is back there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2012 at 1:12pm
Originally posted by ononewheel ononewheel wrote:
Thanks to Tim I think I have it figured out.   I bought a pod and panel for a 1992 ski nautique, which is different from the excel.
Correction- 1992 Sport Nautique. The 1gen Sport had a different dash than all of the other CC models.
I still have an interest in the gauges- no rush on my end either!
scarbs View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote scarbs Quote  Post ReplyReply Direct Link To This Post Posted: November-27-2012 at 5:58pm
ononewheel,
There is a member on the Planet Nautique site who successfully created a mold and new dash pod out of fiberglass for a 1993 Ski Nautique. He posted some pictures and it looks pretty good. Apparently, he has been working on creating molds for other years and models and is planning on releasing a carbon fiber version of the dash pods in the new year. I don't know him--I just ran across is DIY post today. His handle is 93nautique0710 and he posted his phone number for anyone interested in a dash pod--423.444.9858. Maybe he can help you.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: November-27-2012 at 6:21pm
Anyone have a good left side picture of a 89-91 sport dash? I think I have an NOS pod for one upstairs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 4:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 6:28am
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 3:28pm
yikes!   glad everyone is OK.   was that a Subaru in your 4th pic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 4:49pm
Saab
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 8:42pm
Yep,
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 8:45pm
By the way,
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 9:22pm
Looks like a mess Seth, Do you have a plan and timetable to get things back together at home?
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 10:16pm
Wow,glad your all ok
