Classic Nautiques |
Post Reply | Page <1234> |
Gary, You do realize that anything found on the internet is the absolute truth!! |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3241 |
I know everyone has their favorite oil, and I agree that you need ZDDP. I am not trying to be disagreeable or dismiss Gary or Pete's advice, they, and others here, are Correct Craft experts, something I am not.
Oil analysis shows Valvoline VR-1 to have 1200 to 1300 PPM of ZDDP. I am sure it is good oil, and it is the least difficult to find. I prefer and use Redline 40WT (15W40) race oil in my old Willys and some of my friends vehicles with antique flat tappet engines. At 2500 PPM of Phosphorus and 2400 PPM of Zinc, it has twice as much ZDDP as Valvoline VR-1. Although probably not necessary, I will use it in my Mustang (1970 Ford 302) when I finish it this summer. Remember, most racing motor oils have less detergent and require more frequent oil changes than "regular" motor oil, Valvoline VR-1 and Redline included. With their reduced level of detergent, the oils will not keep contaminants in suspension as well as conventional oils. Redline 40WT oil |
You found these guy's on line and they told you they were very capable? Be careful,you should check out local car shows,talk to the Mopar guy's see who they recommend. Your alot closer to So Cal too,there has to be someone there that knows Mopars |
Tonali_III
Senior Member Joined: August-30-2004 Location: St. Louis, MO Status: Offline Points: 412 |
I remember "260". That was the greatest fuel that Sunoco put out. Imagine being able to get that kind of octane simply by selecting it at your Sunoco gas station.
1974 Southwind 20
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6752" rel="nofollow">1972 Mustan |
62 wood
Peter,
I mess a lot with old cars and trucks and hang with a lot of "car buddies" on a daily basis. (a lot of them still drag race) Like us, they are all aware of the loss of zink in oil. Most with flat tappet engines will run the additive. When building an engine, we usually use a roller cam in the rebuild. Easer to do than in a bacerds motor. Another thing.... in the last few years is most are running E85 in their race cars. A lot has changed since the days of "260"! |
peter1234
i would trust any local engine rebuild shop . most of those guys that have been in business have worked on everything ever made.
guys . how come going to street rod events , cruise nights hanging around a life time of motor heads no one ever talks about zddp for classic cars? |
4mor
Newbie Joined: December-07-2012 Location: Peoria, Arizona Status: Offline Points: 30 |
A few thousand hours? What kind of a boat was it in? Do you know which make of water pump it is using...a Sherwood or Jabsco?
4mor
I found both engine repair shops on-line under "Chrysler 318 marine engines" and I have talked to both on the phone. Both are very capable engine rebuild shops familiar with the "poly" engine which is clearly different than post 1976 engines. I am open to other suggestions. I am looking for the best, most capable shop familiar with the requirements of marine engines.
65 'cuda
My 318 poly has a "few thousand hours" on it! Quote from the original owner. Still runs well!
I'm not understanding why you have to travel so far for engine work. |
Yes |
4mor
I would love to have your extra 318 poly, but right now, I don't know where I could keep it. I know that my engine need to come out of the boat for a close inspection to see why my last oil sample analysis had the high iron, chrome and lead readings. Something is not getting the lubrication that it needs and, so, the inspection before I ruin it. Not sure if I will pull the engine here (Peoria, Az.) and ship it to repair shops that are knowledgeable about the ploys or take the boat and engine to them. One of the shops is U.S. Engines in Kent, Wn. the other is S & J Engines in Spokane, Wn. Not looking forward to a trip to either place, especially this time of the year so, most likely, if I make the trip, it would be more like the middle of April. Also, and maybe you can help me...I not sure if my poly is a reverse rotation engine. Looking at the front of the engine when running, it turns counter-clockwise. Is that reverse rotation? Anyway, lets stay in touch and maybe we can solve both our problems.
65Cuda
Groupie Joined: September-28-2012 Location: Matthews NC Status: Offline Points: 97 |
still tinkering with the idea on just sending the extra engine out to get rebuilt and then selling (318-Poly)...not sure if there is any interest out there for it.
4mor
I will. Thanks
65Cuda
let me know if you are in the market for a parts engine.
4mor
Wow! Sounds like a wonderful boat. I will do all I can to keep the original 318 in the boat. A lot of members are telling me that keeping the boat original is the best way to hold its value. I am still exploring my options with the hot oil sample taken on Nov. 6,2012 showing excessive chrome, iron, and lead. So, something is wearing out faster than it should and I need to find out what before I ruin the engine.
Tonali_III
GO MOPAR!!!
1974 Southwind 20
74Wind
For what it's worth, I've got a Chrysler 360 in my 1975 Century; never been rebuilt and still runs great. Go Mopar.
1974 Southwind 18
1975 Century Mark II |
Tonali_III
The 312 you built and shipped to the UK sounds FAB-U-LOUS!!
My aunt's neighbor had a Thundercraft with a 312 in and a jet drive. That sound brings back memories. Are you near Nawlins? (A friend of mine said that's how New Orleans is supposed to be spelled.) |
1974 Southwind 20
Tonali_III
I just caught the video on Youtube that was made of the repairs to a kayak.
Billy, I must say, you are a card. I truly enjoyed it. And I truly look forward to your words of wisdom. I like the part about "flame-able" and "in-flame-able". That was sweet. And you're right. It doesn't make any sense. |
1974 Southwind 20
Tonali_III
Apology accepted and I am sure I will learn a thing or two as well.
And to be completely honest, my dad always used Fram and we never had an oil related failure. |
1974 Southwind 20
boat dr
The design refers to the "head / valve/ spark plug location" The head design alone is the major factor here, not block size as you stateed above. Slang in the Old Days for the poly was "Semi-Hemi" and the Saw Tooth valve covers were too cool.... |
boat dr
Is this the total content of your research on Fram filters ???? Or did they pay you for that endorsment ? I say again, hang around, you may teach us a new trick or two about these old boats. Most here have a low opinion on Fram, sorry to bash your research. As for your Grandfather, I have to agree. But: Youth is wasted on the young and Wisdom on the OLD |
Tonali_III
Fram ad "pay me now...or pay me later".
I have had zero problems with a Fram in the 34+ years I have been operating gasoline internal combustion engines. And while I don't have quite the experiences that you have, my experiences has been...learning experiences as well. However, as my grandfather said, "The day a man that is through learning, is the day they better be burying him." Wise old guy he was. |
1974 Southwind 20
boat dr
[QUOTE=Tonali_III] Thanks, Billy. I appreciate your advise on recommending products to "gearheads-in-training". I myself normally research a product for independent lab studies prior to using them. I use a Fram PH8A or their heavy duty version on my 440.
Hang around a while, you gotta lot of learnin' to do.....Billy If you do indeed research products before you use them, why would you use a Fram filter.They were at the bottom of the pile in research data.. |
65Cuda
also the reason when I found my extra engine, I had to buy it...parts are tough to find for a poly. I only pulled the manifolds off right now but hope to attempt to start it in the coming weeks.
Silver15
Senior Member Joined: March-24-2010 Location: Orlando Fl Status: Offline Points: 398 |
Poly=Polyshperical similar to how Hemi=Hemispherical. It has to do with the contour of the head. I have the same engine and have seen the bottom of the heads.. they're a strange shape. (poly heads)
2000 Air/Sport
1978 T16 |
Tonali_III
A "poly" engine has to do with the basic design of the Chrysler 318. While I am not an expert in this area, I believe the "poly" 318 was made before 1967 and has to do with the design of the block. When I was a kid, we used used to call them "big block 318's". I do know the "poly" engine has to do with the physical dimensions of the block.
Copy and paste the link below to get the proper definition from MOPAR. http://www.allpar.com/mopar/a-engines.html |
1974 Southwind 20
4mor
Yes, I love skiing behind my '66SN, that's why I'm willing to do what is necessary to keep running. Question. What is a "poly" engine?
Tonali_III
BTW, here is the link to Rislone's product:
http://barsproducts.com/catalog/view/22-engine-oil-supplement-with-zinc-treatment-4401 We all can judge for ourselves. |
1974 Southwind 20
